Question about Kenmore Elite HE5t Washer
I accidentally pulled out the dispenser drawer, and the small gray handle fell off. I do not see where to put it back on, and there is no diagram in the manual. Can you please tell me?
I accidentally pulled out the dispenser drawer, an - 76e168f9-8102-4849-83b5-896ca97383f2.jpg f176ce23-cf8e-49c8-b065-13335f8803a4.jpg
Hope the above photos are helpful
Posted on Mar 20, 2014
    New Friend:
It goes over the last vane on the back left of drawer
Posted on Mar 19, 2014
A quarter and a penny are in my lg bleach dispenser how do i get them out
Are they where you can see them??.. If they fell down the "chute" you will have to remove the back or top off the washer.. bleach will corrode the copper in the quarter and the penny will corrode overnight!!
Jul 17, 2017 | LG Washing Machines
Kenmore washing machine model 970 c44102 00
Refer the control panel diagram at this site.
SEARS CANADA Washer Control panel Parts Model 970 C40042 00
Explode the diagram part and use the magnify cursor to see the parts of the dispenser. You need to pull the drawer out by lifting up slightly and then releasing its front edge from under the latch bar. Put it back in same way by inserting at a slight angle and then pushing in and straight. If you want you can take the top cover out (with proper screw driver) and pull the whole dispenser out. But I think you should be able to simply pull the drawer out and lean it.
Aug 31, 2014 | Kenmore Washing Machines
Diplomat washing machine
Try Sliding the Soap Dispenser Drawer Lock to the RIGHT and then pull straight back... It is located under the handle
Mar 03, 2014 | Washing Machines
Conditioner rise on the waa24270gb
Pull the drawer all the way out (pull out until you get restriction, then press on the middle, just above where it says 'MAX' for fab cond and this will allow the drawer to come out fully)
Where you press to get it out, pull this up and you will see a fixed cylinder in the drawer and a larger cylinder attached to the pivoted portion, ensure the drawer is clean of detergent and fabric conditioner residue, particularly inside the larger cylinder, use an old toothbrush (I have an old washed clean mascara brush that perfect for the small crevices etc). When you put the drawer back together the large cylinder sits over the small one and the top should clip in position via two small plastic tags.
Whilst the drawer is out, look into the machine and up into the top of the dispenser housing. On the left and right you will see several smalls hole, in the centre above where the fabric conditioner section is you will see four small square holes, this is where the water enters to dispense the conditioner, if it is particularly grubby in here use a scourer or toothbrush to give it a clean. Once it is clean you need to get a cable tie and feed it through all four square holes until you see it appear at the back of the dispenser housing, give it a little wiggle and pull it back out.
Replaced the drawer, add a small amount of conditioner to test and run on a rinse/spin or freshen up cycle- should be 18-22mins on display. Check the conditioner has been dispensed. Hopefully, this should sort it. Let me now if you need any further help.
Feb 25, 2013 | Bosch Washing Machines
I accidentally drop my detergent lid in the softener tray. how will i remove it ..i tried to open the machine but i dont know how.
If it went in the hole at the back it will come out inside the drum. You may be able to pull out the dispenser drawer and check behind it, usually pull out and lift, or there may be a tab under the drawer to push to release the drawer
May 15, 2012 | Kenmore HE2 Plus Front Load Washer
I need to reassemble a 1974 Fisher-Price toy cash register
Fisher Price cash register
I am assuming that you have removed the base to unjam the drawer, and a brown plastic lever fell out of the white assembly inside and you can't work out how to put it all back so it works. It took me three days to figure it out.
On the inside of the base is a long coiled spring. First hook this back over the end of the central drawer runner. Have a ruler or similar flat item handy to release it later.
Take the body of the cash register and insert the narrow end of the brown plastic lever through the white plastic assembly, until it engages with the handle mechanism. You will then feel resistance when turning the handle. There is a flat metal strip in the middle of the assembly. On the side of the brown lever is a small projecting peg. Put this behind the metal strip. Put the thicker end of the lever through the rectangular gap in the white assembly.
Place the drawer into the body of the cash register so that the back of it engages with the V shaped notch on the plastic lever.
Hold the drawer and body together with one hand and carefully lower them on to the base. While there is still a small gap under the drawer, insert the ruler to release the coiled spring. This will engage with the projection under the drawer.
Push everything together and replace the screws. Job done!
Nov 22, 2011 | Fisher Price Toys
A mouse died in the powder dispenser of my samsung J845
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 17, 2009 | Washing Machines
Frigidaire gltf2940e front loading washer - dispenser drawer magnet replacement
When you are looking at the drawer, the magnet stands upright on the far right side just inside the outer front casing about halfway down. There is a small plastic clip that holds it in place. You don't need to take anything apart to reinsert the magnet, just open the drawer, but it may be easier to see the location if you pull the drawer all the way out of the hole.
Nov 02, 2008 | Frigidaire GLTF2940E Front Load Washer
Washer - soap dispenser door - Magnet fell out... where does it go
I had the same problem. If you turn the dispenser so that the front faces away from you, look on the left side in the front. half way up there is a space with what looks like a plastic clip that might hold the dispenser to the front bezel. This actually holds the magnet, which can be installed without taking the dispenser apart. Be sure to install (pop in) the magnet vertically so that the long part of the magnet sits next to the right side of the dispenser opening (when viewed from the front) when the drawer is closed.
Oct 22, 2008 | Frigidaire GLTF1670A Front Load Washer
My door lock magnet fell out and I don't know whee to put it back on the dispensr mechanism tomake t lock
I found it! If you are looking at the drawer from the back the magnet sits in the pocket in the far left. The plastic extends out like a clip (to hold the magnet in place). You depress that when placing the magnet in.
hth.
Kate
Aug 15, 2007 | Kenmore 43042 Front Load Washer
Kenmore Elite HE5t Washer Logo
32 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
