Question about Tomtom GO 910 GPS Receiver
Down load data from Tom Tom 910
Is it possible to down load stored data from a tom tom 910 in car unit following an RTA ?
  • David Deacon
    David Deacon Mar 19, 2014
    Is it possible to obtain data such as speed for a given recent period of time like a data logger. I would like to download information so it can be seen what speed the car was travelling just before the accident occured
    Sergeant:
    Champion:
  • Tomtom Expert
  • 373 Answers
Yes but as a member of the public you will not have the appropriate software or equipment.
Your insurance company will help especially if it helps their claim or the Police will assist you gathering evidence for a prosecution.
Info gained will be speed, time (set by sat gps receiver) not what time you say it is and exact location with 3 square metres and direction of travel.
Hope this helps with your question.
Posted on Mar 20, 2014
E61N
  • 515 Answers
SOURCE: Tom Tom 910 map update with 920 maps?
Yes, this is possoble.
Make sure you:
- Have updated to last navcore v7 version
- Have updated TomTom Home to latest version
Then buy and upgrade map through TomTom Home...
Find latest version of TomTom Home here:
http://www.tomtom.com/support/support.php?ID=3&Language=1
Posted on Apr 10, 2008
SOURCE: how to reset tom tom 910
the reset hole is hard to find... If you are looking at the back of the unit, it is in the upper right hand side of the liitle plastic protrusion at the top of the semi-circular opening above where you can see the exposed circuit board.
Posted on Nov 25, 2008
  • 74 Answers
SOURCE: need to down load a new map on my tom tom one third edition
Use Tom Tom Home to find new maps and updates.
If you haven't got Tom Tom Home then download a free copy here:
http://www.tomtom.com/services/service.php?id=16&tab=87
Peter
Posted on Jan 29, 2009
SOURCE: tom tom home does not see my tom tom go 520
Hi canal_boat_m
Try this solution:
STEP 1 Un-install Tom Tom Home from your PC
STEP 2 Click on the link below:
http://tomtom.com/lib/img/cs/S4S/files/RemoveRegEntries_TTGOv1.exe
This will download a little removal program for the Tom Tom Home program.
A Black window will appear briefly then close.
• Make sure that you have got Administrator rights on the PC. Otherwise you may not be allowed to connect new hardware (especially the case when using office computers)
• Reboot your PC
STEP 3 Visit Tom Tom website and download the current new version of Tom Tom Home and install it to your PC
STEP 4 Connect the TomTom
• Make sure the device is fully charged before connecting it to the computer. Ideally a mininum of 4 hours charge.
• Reset the device using a paper clip (see http://www.tomtom.com/6965). When resetting, keep the reset button pushed in for at least 20 seconds, but DO NOT turn the device back on just yet.
• Ensure that your TomTom has power connected to it. There should be a green light on the TomTom unit. If your device came with a Home Charger, please make sure that is plugged in to the TomTom also.
Your Tom Tom should ask you to 'Connect to Computer' if it does tap YES.
SOLUTION:
Your unit should now be recognized by your PC.
IF IT DOESN'T then follow the instructions below:
1. Connect your unit to your PC;
2. Copy two folders to your PC (namely 'Raster' and the one which holds all your maps - probably called 'United Kingdom and Eire';
3. Using Windows Utility, right click on the Tom Tom drive unit and select Fomat;
4. Switch off the unit and soft-reset it with a paper clip (but hold it in for at least 20 mins) and then re-connect it and power it up;
5. Tom Tom Home should now detect the unit and your unit should ask you to 'Connect to Computer' so tap YES;
6. Tom Tom Home will now say your device needs updating - and if you apply all the changes it will restore it to Factory Finished!
7. Then all's needed is to replace the two folders you backed up and any other items like mp3's and sounds, pics, etc.
Posted on Apr 22, 2009
  • 373 Answers
SOURCE: charging the Tom Tom - unit shuts off with car charger plugged in
The shut down' problem is caused by a faulty 'USB' charger socket
Swap out the socket and make sure you resolder ALL 5 terminals and the 4 pcb clamps.
Only attempt this if your skilled enough. A botched repair will not work and cause more even fatal damage to the pcb.
Sorry if I just depressed you but that's what need to be done.
TomTom support lie and tell you its the navcore, NOT
I have carried out this repair myself and it did cure the problem.
Posted on May 15, 2009
My Tom Tom one starts off ok and then after about 3 minutes the voice stops but the instructions are still on the screen. Each time I turn it off it starts correctly then the voice goes. Help
try this it worked for me , hold down the reset button on the bottom of the tom tom down for 15 seconds then when done hold down the power button for 5 seconds , the tom tom will reboot from bios , as i said it worked for me good luck
Jan 18, 2010 | Tomtom GO 910 GPS Receiver
Unit will not come on
Make sure everything is fully charge and if you can try to change the battery to check if its a problem with the battery...
Hope that helps..........
Sep 30, 2008 | Tomtom GO 910 GPS Receiver
Dispite connecting and updating my tom tom 910
It is asking you IF you want to connect it to the computer. There is no problem with that. Every time you connect it to a USB port of a computer you are asked if you want to connect it to the computer. If you want to do so Tap Yes; if you don't, tap No. It will do what YOU ask it to do.
Frequent connections to a computer will ensure that your unit has the latest software updates, map corrections through MapShare.
Dec 30, 2009 | Tomtom Go 910 (Europe, USA and Canada...
Tom tom 910
Stip down your tom tom unit, google for instructions and there is a set with pictures, But if not,
1, take the front screen surround off first, be gentle and prise it of with a flat screw driver, then unsrew the chassis from the plastic cover (4 x torx screws under the rubber feet)
2, unscrew the motherboards (torx again) and unclip the cable for the battery, and remore the eject mechanisum for the unit.
3 you may hadve to unscrew the harddrive and front screen if memory serves me well, but not to hard to do at all and my skills are basic but backed up by curiosity :o).
Jul 03, 2009 | Tomtom GO 910
Tom Tom 910 connection
send it back its nacked.demand they repair or replace its a common fault they are aware of point them here if they argue dont accept fob offs or their **** service these units are a waste of time there is no easy fix like new mounts or bungs etc
Jan 16, 2009 | Tomtom GO 910
Update 910 tom tom
i have a same problem. i have garmin nevigation.input 10-30vdc 1A(Max)
output5Vdc 1A
Fuse spec: 1A 250Vac can this working again
Aug 27, 2008 | Tomtom GO 910 GPS Receiver
TOM TOM 910 won't charge/turn on
there is a little push button on the back. use a niddle and push that down at the same time hold the power button. you will hear the unit turning on itself and then it should work fine
Aug 10, 2008 | Tomtom GO 910 GPS Receiver
Tom Tom 910 software
I don't think the Tomtom 910 has a SD card slot. Check the model # of your GPS again.
Apr 01, 2008 | Tomtom GO 910 GPS Receiver
Problem with conection tomtom 910 to PC
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Feb 22, 2008 | Tomtom GO 910 GPS Receiver
Tomtom GO 910 GPS Receiver Logo
52 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Jon Piercy
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
