Question about Maytag MAT12CSD Top-Load Coin Operated Washer
Maytag neptune commercial washer change the price
Maytag MDE21PDAYW and MAH21PDAWW
Amigaman
  • 248 Answers
SOURCE: maytag washer door boot
   Remove 2 screws holding door hinge to cabinet and remove door.  Then remove 2 screws opposite these. Grab front panel with thumbs at area of screws you removed and pull outward with thumbs. Panel will pivot forward.  Remove panel from lower clips.  At top of exposed area remove 2 5/16 screws.  Remove brackets under them.
  Open dispenser and remove 4 screws.  Careful not to drop in dispenser.  Remove dispenser frame assembly.
  You can now raise top of washer to a 90 degree position.
   Now back to front exposed area.  Grab boot where it contacts front and peel out of groove.  Also remove two screws holding light assembly and remove cover.  Remove all 5/16 screws holding front assembly and the ones on top area where it is on a bevel.  Remove front assembly by folding up and onto top.
  Now we are at the boot.  Remove spring and wire assembly holding boot to drum.  Make note on boot position and spring position.  Remove boot.  Install new boot onto drum.  wrap wire around drum with ends at top.  Now the fun!  Hook spring to on end of wire and using vise-grips,  pull to other end to hook into wire.  It can be done,  honest.
  Now just reverse to reassemble.  should be instructions with boot.   Good luck!
Posted on Oct 21, 2007
  • 96 Answers
SOURCE: maytag neptune tl
Code OP means lid is open. If it really isn't, then the problem is with the switch that sense whether the lid is shut or not. Could be bad switch or bad connection.
Posted on Jun 08, 2008
  • 1294 Answers
SOURCE: i have a maytag neptune washer the water will not drain out of it
First drain as much water from the drum as possible and unplug from the outlet. Then there are 2 screws left and right under the front lower panel at floor level. Undo those two screws. Pry the front panel DOWN from the door panel. Once the lower panel is removed you will see the pump and pump filter on your right. The pump filter is to the left. It has a large turnscrew. Be ready with a pan or something to catch the water from the open filter! Screw this counterclockwise until it comes loose. You will now be able to remove the filter and all the debris. After cleaning, re-screw the turnscrew. Before you put back the front panel test that it is clear by doing a wash. If it still doesnt drain you must remove debris from the pump itself. The pump is between the pump filter and the pump motor on the right. Undo the white clips from the motor and the retaing clips attiching the filter to the metal washer body. Then turn the motor clockwise to separate it from the filter. Refit carefully after job is done. And fit outlet tube a correct height, not too deep. <courtesy tzotsi>
Posted on Mar 10, 2009
localwonder
  • 6784 Answers
SOURCE: my maytag neptune washer will stop working and
HI, this error code is signaling an issue with the fill actions. Your washer seems to be having problems when it try's to fill the tub with water.
First, make sure there's water getting to the washing machine. Make sure the water faucets are open all the way.Check for kinked hoses as well.
If the hoses are fine and, the faucets are fully open, this will confirm a inlet water valve malfunction. you will need to replace this failed component in this case. it has failed.
Posted on Jun 17, 2009
Illeagle
  • 525 Answers
SOURCE: Maytag Neptune washer has bad odor, city water.
There is no filter in your washer that would cover the odor issue.
The website link below will give you all the information concerning odors in a Maytag Washer
http://maytag.custhelp.com/app/answers/list/kw/odors/p/293/r_id/108284/sno/1/search/1/session/L3NpZC9RRDdZdDhEag==
Posted on Jul 18, 2009
How do i replace Maytag Neptune front load washing machine bearings
The machine obviously must come apart. See this youtube video:
Dec 13, 2013 | Washing Machines
Need to know what light bulb to use in Maytag Nepture washer
how do I get to the light bulb on the Maytag Neptune front load washer, to change it?
Feb 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
We have a maytag neptune washer and on evey setting, it's telling us d5 - what does it mean?
D5 means blocked coin 1 or coin drop control circuit failure, coin recognition and price display disabled while blockage persists.
Nov 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mold on rubber gasket on Maytag Neptune washer -- how do I get rid of it?
you can not the door boot has to be replaced there is a black commercial one available although unsightly it will not cause any harm
Aug 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Need to reset price for washer and dryer
if its not working board might be bad
May 18, 2009 | Maytag Washing Machines
Won't cycle to the next step
maytag neptunes are the worst appliances to get. i worked for maytag and the neptunes are over price and break very easy. plus the cost of repairs are very expensive. i would recomend getting a new washer. youve put enough money into this one and getting it fixed is going to be expensive. especially when the fix is only temporary. something else is going to leak or break.
Feb 02, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAT12CSD Top-Load Coin Operated Washer Logo
64 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
