Question about Canon Cameras
I bought Canon digital camera powershot A4050 8 months back now the lense is not working and give the message of "lense error" need yours help and where i can repair it ( Dubai, Sharjah),
Power shot canon A4050 is lense is not working,
poolseman
  • 206 Answers
SOURCE: Blank black screen for my canon powershot S1 IS digital camera
This is a common problem with S1 IS and it is caused by faulty CCD sensor. Note that you can playback captured images without any problem but in capture mode all you get is blank screen. Will have to go to Canon but note that Canon repairs these models free of charge when it is the CCD sensor that stops working.
Posted on Sep 14, 2007
SOURCE: Problem with canon powershot SD1000
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty , or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
If you found these Canon repair instructions useful and have managed to solve the E18 problem, write us about how you did it. We're looking forward to your emails. Also, please use the links bellow to bookmark us on Del.icio.us and Furl.
Bookmark This Page on: Del.Icio.Us / Furl
Posted on Feb 29, 2008
zohail
  • 1223 Answers
SOURCE: Lost my Canon PowerShot G9 Digital Camera Solution CD-ROM
All related software for ur camera See drivers and download section
Here
Pls rate me WELL !
Posted on May 18, 2009
  • 102366 Answers
SOURCE: lens error, restart camera for canon power shot SX120 IS
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 14, 2010
SOURCE: Canon PowerShot SD780 IS camera lens error. :(...
I did the same thing and it works only be restarting it now but it works lol. I threw it agianst my bed . SO BEAT THE **** OUT OF YOUR CAMERA..then restart and it should work..*** made **** what can you say
Posted on Mar 07, 2010
Canon powershot zoom lense is stuck how can i get it to
There are a few things you can try. Here is an excellent blog about lens errors and stuck lenses, and it covers what can be tried to free it up:
They say about 50% of lens problems can be fixed trying their suggestions. Hope you're one of the lucky ones! Also, if nothing works, get an estimate before having it repaired. Often, it's just better to get another camera.
Jul 09, 2010 | Canon PowerShot A540 Digital Camera
I have a A640 powershot approx two years and has had little use over this period. I took it to a family event recently and took approx 100 photograghs before my lense became stuck. This happened as I was...
There are numerous suggestions on-line elsewhere for this common problem with Canon lenses. Does your display give you an error message? If yes, google that error message and you should find many suggestions for fixes. I know some places actually advocate just forcing it back into the properly aligned position although I think that should be a last resort. I have not done this myself but there are many who have fixed these cameras successfully. Good luck
Jun 24, 2010 | Canon PowerShot A640 Digital Camera
When turing on my Canon SX100IS camera it opens the lense then closes and gives me an E24 error. I am able to replay phones on my SD Card but not take new pictures since the lense retracts
you get this error message E24 because your lens is slightly out of alignment. Cycling the camera on/off several times will serve to help the lens to work it's way back in alignment.
Even though your battery may be fully charged, as a Lithium Ion battery ages, it begins to lose capacity so you don't have enough power to take any still . Try a different battery.
Clean the battery contacts with a pencil eraser. Sometimes, a dirty battery contact can prevent the battery from providing all the current the camera needs.
Hope this helps.
Jan 24, 2010 | Canon PowerShot SX100 IS Digital Camera
Lense will not go in and out... message at start up is "lens error, restart camera"
The lens of your camera has been stuck.
You need to go to Canon authorised service center. They will replace the optical assembly.
OR
You can give it to an expert for repair, he can repair it without replacing the optical assembly.
Aug 11, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon A540 powershot freezes with Zoom lense still out.
Probably the most common failure for all digital cameras, a lens error. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 08, 2009 | Canon PowerShot A540 Digital Camera
Canon ixus 75 digital camera reset?
Hi
What you are seeing is just an error message, starting your camera again won't do anything unfortunately.
You need to replace the lens, we have your lens repair available on our site for about $75! If we can help please let us know.
Thomas
Owner- Darntoothysam com
Apr 07, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
I have a canon powershot tx1 and i just got a 'lens error, restart camera' message and my lens is stuck. i just bought it a month ago and haven't mistreated it at all. how can i fix it?
I have a canon powershot a470nd i just got a 'lens error, restart camera' message and my lens is stuck. i just bought it a month ago and haven't mistreated it at all. how can i fix it?
Jul 24, 2008 | Canon Cameras
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
