Question about RCA RS2025 CD Shelf System
How do i reset rs2025 to get cd to open
Trying to open cd drawer and get reset msg
How do I fix this CD Changer Drawer problem?
flip upside down and shake or pull it open,or look for a reset/release hole and use a paper clip to open it
Apr 15, 2015 | Audio Players & Recorders
The display flashes "closed" and I can't open the cd drawer when pressing the open/close button. Is there a reset please ?
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
Apr 08, 2015 | Audio Players & Recorders
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
Copystar 2050 DUPLEX CANNOT BE COMBINED
this is most often seen when the default drawer is disabled...dashes instead of paper size. to reset drawer try touching 10871087 then 906 and the start button this resets the disabled drawer. also make sure no paper is stuck behind the drawers.
Aug 11, 2009 | Kyocera Copystar CS2540 Copier
Cannot open cd drawer
If it will not open by itself, open up a small paperclip and push it into the little hole on the front of the cd rom. This will release the latch, and allow the drawer to open
Mar 16, 2009 | Gateway Computers & Internet
Need help opening my CD changer?
When you turn on the unit, pushing eject or the open/close button should work. If it doesn't work then the unit is not working. See if you can send it back.
Nov 17, 2008 | RCA RS2025 CD Shelf System
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
RCA RS2025 Bookshelf Stereo CD Player Hangs Up
Ok,
Look for a reset button at the back or may be at the front head of the cd changer.It is a very small 1mm hole.If you find it insert a paperclip in it,press and hold it for 1 min.This will reset the unit.If you still face the problem then just unplug all the cords of the changer for 1 hour and then plug it back in.
Sep 03, 2008 | Audio Players & Recorders
CD drawer will not open or close
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
Try manually opening the drawer. There's a little hole on the front, Insert a pin or bent paper clip in the hole with the machine "on". Should open for you.
Jul 16, 2007 | Teac GF-650 Turntable
RCA RS2025 CD Shelf System Logo
85 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
