Question about Irons
Tefal aqua speed autoclean 270 thermal cutout needs replacing where can I get 1 ??
Blown thermal cutout
Tefal pro express steam generator iron. When in use the handle gets really hot. I have to put a cloth around it to use. Help.
try to reduse the temperature setting first, if it still does the same then the thermal switch mechanism is not cutting off the switch at proper temperature
need to replace the thermal switch mechanism
Oct 23, 2017 | Tefal Irons
Tefal iron steam generator
Steam irons can become clogged with mineral deposits. Use distilled water in the iron to minimize these deposits.
To clean the iron , use 1/2 white vinegar and 1/2 water. pour in iron and place iron on steam. The iron may require a few cleanings.
May 11, 2014 | Tefal Irons
Tefal clothes iron model "Superglide
sparking can be cause by lightning/spikes and broken wires/ wrong voltage.
if u use it in usa at 100v, the current is doubled and will melt the cables.
so:
please discontinue to use it. its not worth your life.
Sep 12, 2011 | Tefal Irons
My tefal aqua is not taking out creases but i can see steam coming out of the iron I have tried the instructions according to the manual for cleaning but still no good please help
Some creases cannot be removed with any steam iron.
Dampen the area with the creases or place a wet press cloth over the area and try again.
Feb 20, 2010 | Tefal Aquaspeed 170 Iron
Seeking stopper for Tefal pro 2500 1875 steam iron/generator
I too was looking for one
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=146230&query=tefal%20stopper
cost £20.99
Nov 01, 2009 | Tefal Irons
Tefal Pro Express
  1. solenoid valve blocked
  2. swich for steam broken
  3. you forget it in turbo steam mode and you have steam all the time
ps see below on link turbo button
http://www.gostore.com.au/~ebay/krups/tefal/proexpressturbo/TefalProTurboAuction(3).jpg
Jun 22, 2008 | Tefal Ultraglide 1549 Iron
Insufficient steam
Try a commercial De-Scaler.
If your in a hard-water area. the iron will be heavilly scaled-up.
If there is a steam surge button, on the iron. Face it downwards and push the button several times.
Mike @ Compurepair.
Feb 18, 2008 | Tefal Aquaspeed 170 Iron
Not getting hot
The thermal cutoff device blew and must be replaced. It acts like a fuse when the iron gets too hot. Thay are very
cheap and it would be well worth replacing. Hope this was helpful.
George
Jan 10, 2008 | Irons
Irons Logo
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
