SAMSUNG 51E8000GFXZC thint vertical line on left screen
A fine line in my plasmade 51 inches Model SAMSUNG 51E8000GFXZCN since that time of other line this are added which makes that I now have a vertical line of 1/4 inch from top to bottom left of the screen I did all possible settings but nothing changes.Please help me .thank's Donald
    Genius:
  • 1,039 Answers
The plasma panel is bad. If this is out of warranty it will probably be cheaper to replace the tv.
Posted on Mar 19, 2014
circuitcity
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
  • 103 Answers
SOURCE: samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Posted on Mar 05, 2008
  • 4234 Answers
SOURCE: Panasonic TH-50PZ77U 1 1/4" inch vertical line
This problem is usually the ribbon cable connection at the top of the stripe. Reseat the cable first. The other possibility is the panel itself, but that is rare.
Keep us posted.
Dan
Posted on Apr 30, 2008
SOURCE: Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
I also have the same problem I phoned Samsung today to explain the tv was only 14 months old, they didn't wanna no because it was out of warrenty by 2 months. I am getting a black solid line down the left hand side of the screen. I ended up phoning Dixons were we bought it from, they have told me to get an independent engineers report done & send the report to them within 14 days. Dixon told me it was a known problem with Samsungs. They said they will fix it free of charge if they can if not they will send vouchers to the same value of the television. So beware stay clear of Samsungs.
Posted on Nov 07, 2008
roety
  • 585 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Posted on Aug 19, 2009
SAMSUNG 51 INCH PLASMA , BOY THREW HIS BEAN CUSHION AT IT AND NOW EXACTLY HALF THE SCREEN HAS VERTICAL LINES OTHER HALF PICTURE IS FINE .ANY IDEAS WOULD BE APPRECIATED .
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
May 01, 2017 | Samsung Televison & Video
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Red dots on Samsung 51 inch plasma
Usually either the main board or the power board--if set is 6 months old---no warranty?
Mar 18, 2012 | Televison & Video
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
51 big screen apex tv, convergence or verticle IC?
If the lines are thin and close together running horizontally, it may be the vertical driver, but that usually takes out the resistor and sometimes the diode in the B+ for the vert. Also you must replace the caps that caused the problem in the first place.
Feb 05, 2008 | Apex Digital GB5108 51" Rear Projection...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
