Question about Sharp EL-2630P Calculator
Calc tape feeds crooked :(
Even after a correct fed tape and use, all of a sudden the tape will feed crooked and stick. Any help is appreciated!
    Top Expert:
  • Sharp Master
  • 40,418 Answers
The tape feed path may have to be cleaned.
Posted on Feb 05, 2017
Auto Document Feeder
Make sure the paper is not damp, make sure the paper is not sticking together around the edges. Adjust the paper guides.
Dec 14, 2015 | Canon PIXMA Office Equipment & Supplies
My X2250 will not feed the single sheet of paper evenly. When looking at the...
Printer would not feed paper no matter how many sheets were in the bin or how clean the printer. I even cleaned the roller. The issue was I just needed a little more tension on the roller that pulled the paper in.
I removed the rear access door (see manual). Off to the left near the feeder roller you will see a spring. What I did is mover the spring to the END of the plastic arm that it is attached to (if it is missing have a bigger problem). If you have moved your printer around a bit, the spring may have slipped down on to the arm and is no longer sitting at the end. This will extend the spring another 1/16 of an inch ...and that is all all it took for me. My printer will now feed a single sheet of paper with no issues. BTW: I put a drop of glue on it after so it would not slip off.
on Sep 28, 2008 | HP PSC 1610 All-In-One InkJet Printer
Paper is being fed through the printer crooked. Almost like the paper feed wheel is not working properly, being pulled down in the right side, but not on left = big mess
You probably have a piece of paper stick in the pickup carraige. Get a flshlight and a tweezers and see if you can CAREFULLY pull out any pieces of paper...
Feb 16, 2010 | Canon MP610 Photo All-In-One Printer
Paper feeding crooked and jamming in my Canon IP6600D printer.
Try doing a thorough cleaning of all the rollers in paper path making sure that there also no scraps or obstructions in the path.
Aug 31, 2017 | Canon Pixma iP6600D InkJet Photo Printer
Paper Jam
there maybe some obstruction on the paper path, inspect visually any sign of abnormality in this area, replacing the ink would not cause this.
it is touching something thats why t is crooked, either small piece of paper, dirt, caked ink, or hardened ink on the roller, feeding unit may have some plate mis adjusted, misaligned feeeding tray as well. try this
Aug 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Register tape
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle. Looks like >
Then, place the paper into the slot where the paper feeds into in the back. (Paper will get fed under the printer assembly) and then hit the PAPER FEED/ADVANCE button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Feb 13, 2008 | Sharp EL-2192Rll Calculator
Print Problem?
There are two small "hooks" that feed the tape through on the tape cartridge. Make sure the tape is fed through both hooks.
Jan 15, 2008 | Dymo LetraTag QX50 Thermal Label Printer
Crooked printing on HP C3180
good paper also try instalinga fresh new driver from website and unstall old one 1st before u install new one maby try runing cc cleaner also free tool u can dl online free form
Jan 07, 2008 | HP Photosmart C3180 All-In-One InkJet...
Images coming out crooked when in copy mode. A hardware problem?
Ensure the guide for the plain paper onto which the image is printed, are pushed up fully. It is possible that the paper is being fed into the paper feed path at an angle if the guides are nut pushed up.
Jun 22, 2007 | Brother MFC-640CW All-In-One InkJet...
Auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
Sharp EL-2630P Calculator Logo
139 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
