Question about Polk Audio XRt12 XM Radio Receiver
Led light will not work can this be replaced ?
Display light is not working
My kobo glow is still working but the light isn't - can it be repaired?
I assume you're talking about the light behind the display. It can be repaired, but do weigh the labor cost against the price of replacement. Possible failure causes: bad connection between main board and display, LED driver chip failure, open LED. Best case: somebody didn't properly latch the LED cable connector on the main board and the cable has slipped loose. Worst case: the driver has failed but is not available on the open market, or an LED has failed and the display turns out to be permanently assembled with glue so you can't pull the back off to find and replace the bad LED. (I don't know if this is the case because I've not had this model apart before.)
Feb 26, 2018 | Tablets & eReaders
Tip
Nokia Asha 305 display light problem solution
With article and troubleshooting guide solution for Nokia Asha 305 display light problem solution Problem: No display lights, Dark display. Solution: Change LED, Change connector, Make jumper. phonetolls mobile repairing Nokia Asha 305 play light solution Article on this topic Thanks for checking out this Solution. Phonetolls.blogspot.com contents provide include dozens of cell phone artical additional, pictures, with hardware and software troubleshooting guides for you. Support us like and connect with this blogger for latest newsletter please follow me. By Admin shahid abbas. Troubleshooting guide Open display back panel carefully and change lights red marking here in this. Remember one thing to do this job, please be ensure that light controller integrated stage is working well then change or check LED (light emitting diode) on display. There are 4 LED with series you can check faulty LED with check meter. At connection with meter probe LED lights show us. There on light emitting diode(LED) Regulated voltage are equal to battery voltage- 4.2. There are series of LEDs if missing one LED then All series is damaged. Warning! During working on this trick if accidentally your handset may have dead or faulted we are not responsible for that please read our privacy policy., ,
on Jun 24, 2015 | Cell Phones
LG 55LX6500 55 inch LED TV display gone, but sound works.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Jan 02, 2016 | LG Televison & Video
On my GE Profile Microwave the led is lighted and shows the time correctly and displays the led buttons. When I press on the led buttons nothing seems to happen. Also, after some idle time, the led panel...
The touch panel has malfunctioned, Suggest replacing microwave unless you want to attempt repair. If so you will need a replacement touch panel for it.
Jun 14, 2017 | GE Microwave Ovens
S5603 display light not working
the display light led or the driver ic for the led is damaged .. u can easily replace it at any service center.. this ic is not that costly just a couple of hours work may fix this problem
Aug 24, 2012 | Samsung Star 3G GT-S5603 (16 GB) Cell...
Screen/Monitor not working after moving treadmill
+11v LED - Indicates there is +11 volts supplied to the display board. If this LED is not lit verify the following: 1. The display cable is damaged or pinched, disconnect the display cable and verify if the LED lights up. If LED lights up replace the cable. After the above has been verified and the +11 LED is still “OFF”, the MCB should be replaced.
Jun 14, 2010 | Startrac Fitness Products Star Trac 4500...
Radio display
There is no bulb in the radio to replace it is LED display you will have to replace radio.
Jul 29, 2009 | 1999 Mercury Cougar
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
DISPLAY LIGHTS NOT WORKING
If the display is burnt out then the low voltage board will have to be replaced.
Feb 02, 2009 | Viking 48 in Built In Professional...
Polk Audio XRt12 XM Radio Receiver Logo
56 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
kdigby
kdigby
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
