Question about Janome Memory Craft 10000
Button hole maker keeps telling me to put the BH lever down, when it is already down.
I've had problems getting my button hole maker (Janome10000) to work. Even though it may make two or three button holes it at some point will instruct me to put the BH lever down...when it is already down. I've tried pushing back up and back down, starting all over, and it sews two or three stitches and stops and tells me to pull down the BH lever. (Even though it is down)
    Habit-Forming:
  • 45 Answers
Check the screw on the pressure plate. It may be loose
Posted on Mar 19, 2014
SewTechWayne
  • 186 Answers
SOURCE: The Reverse stitch button
The feed mechanism needs to be oiled. Take off the bottom cover and look for any place where two parts move against each other. Some binds can be very difficult to remove. Try spraying everything with a light weight oil (I like Tri-Flow) and let them soak over night. Then manually try to move the feed dogs with your hand. Hopefully it will break loose.
Posted on Jan 30, 2009
  • 323 Answers
SOURCE: my button holes aren't consistent -backing up doesn't work proper
It sounds as though you are using the Memory button hole setting which sews the BH forward on one side(leg of the button hole ) and backward on the other side. You have button holes on Numbers 11-16. I think #16 is the one you are trying to use but the others are easier. Put the button in the special foot, pull the BH lever down( It is located on the left side of the machine towards the rear of the machine ).Select #11 and the machine should sew both legs in the same direction. This machine has always made great button holes.
sewman7
Posted on Apr 06, 2009
SOURCE: i can't seem to get the buttonhole attachment to
I am so excited to share this with you. I was having the same exact problem and I found the solution here: http://kraftykuka.blogspot.com/2008/11/benjamin-button-hole-maker.html
the answer was pulling down the button lever! i hope it helps you too!
Posted on Nov 09, 2009
  • 108 Answers
SOURCE: stuck in stitch pattern was making button hole
i was able to find one at www.ifixmachines.com
Posted on Feb 15, 2010
  • 1116 Answers
SOURCE: I cant get the machine to sew a buttonhole.
I am not familiar with your machine, but some buttonhole attachments require a lever be lowered and inserted into a tab.
Review your manual to see if a step was overlooked.
Posted on Mar 07, 2010
I have th brother sq and can't get the button hole maker to work it always comes up E3
does your sewing machine have a buttonhole lever to pull down
before startting a buttonhole?
Dec 15, 2012 | Sewing Machines
My buttonhole is not working I hear a beep when i press down on the foot to go, what am I doing wrong
I get the same beeping when I forget to pull down the buttonhole lever
if you have the automatic buttonhole & the buttonhole foot that you have to put a button in,,check & see if there is a buttonhole lever that has to be pulled down, it will be a lever to the left of the needle bar
Aug 07, 2011 | Singer 7436 - INGENUITY
One step button hole instructions Singer model 3827
Insert the button into the special button hole foot. put the foot on the machine.Pull down the button hole lever( It's near the presser foot lever towards the back of the machine). Place your needle where you want the button hole to be. Select the button hole pattern and press on the pedal. Watch for the end of the button hole.
sewman7
May 15, 2009 | Singer 7422
Machine will not complete a buttonhole, keeps showing error code 6L. No error code listed in manual. Machine will only do first half of buttonhole and then shows code and stops.
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
Apr 16, 2009 | Sewing Machines
My button holes aren't consistent -backing up doesn't work proper
sewman7
Apr 01, 2009 | Janome Memory Craft 9000 Computerized...
Buttonhole
Dud you pull the button hole lever down so that it engages the foot?
sewman7
Jul 17, 2008 | Necchi 3102 Mechanical Sewing Machine
Automatice Buttonhole attachment
I'm going to assume the button fit into the button hole foot to measure the length of button hole. If this is correct, then there is a lever very near the presser foot bar which needs to be pulled down to be engaged by the bh foot. Let me know if this is correct.
sewman7
Jul 15, 2008 | Kenmore Sewing Machines
Machine Won't Sew
It sounds like the sensor on your buttonhole lever is out of adjustment.Contact the people listed on your warranty papers for repair.
sewman7
May 21, 2008 | Singer 7422
I have emerald 183 and i can't figure out how to use the buttonhole feature. it keeps sewing just one side. also where exactly do i put the button?
Make sure you have pull down the arm that will engage the button hole mechaizm. Put a button in the back of you button hole foot, attach foot, reach up on the left side just below the light and pull the lever down, choose the button hole , lower tension to 3 and sew out the button hole. The button hole foot should push on the arm when it gets to the end and complete the rest of the button hole. If the columns do not match then it has to be serviced by a husqvarna dealer.
Sew Technologist
Apr 21, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
