Question about Kids Deluxe Fire Truck Pedal Car Red
Can not order parts
I neeed the dome head nut for steering wheel the side ladders and the bell were can i order them
    Sergeant:
  • 329 Answers
Have you tried eBay? Or Google this toy and try to find the manufacturer. If still in business, you could contact them. If not, you may have to follow the breadcrumb trail of who purchased it, when, and where it stands in today's business world. I would say the ladders and bell are the easiest replace. Any woodworker worth his salt could recreate these ladders. And the bell looks as though most any vintage style bell will work. It's the dome head nut that has me stumped.
Posted on Apr 11, 2014
Remove steering wheel on 85 dodge diplomat
Disconnect the negative battery terminal. Remove the horn pad on the steering wheel-Phillips head screws from the back side of wheel. Then loosen the nut on the steering wheel center. Mark the steering wheel to column shaft position, so the wheel goes back in exact same position on the shaft. You may need a steering wheel puller to get the wheel off the shaft, not always, but sometimes the wheel is on pretty tight. Do not hammer on the wheel to get it off, use a puller if needed. These pullers are at parts stores and not expensive.
Dec 31, 2013 | 1985 Dodge Diplomat
Can't Remove Rear Wheel from mobility Scooter
take 2 bolts out of the wheel remove center bolt use steering wheel puller for sale at auto part store for cheap comes with bolts in different sizes you may need to buy longer bolt and nuts and washers put bolts through puller then through the to bolt holes in the wheel adding nut and washers to back side the axle should have a center hole turn puller shaft clock wise with a adjustable wrench the wheel will pop of with ease good luck
Nov 12, 2012 | Electric Mobility Health & Beauty
I need to know how to replace tumbler 1993 honda accord 5-speed
That is not the key part of the switch, it is the electruical switch the key cylinder operated.
Instructions
    • Set the front wheels to point forward and remove the key from the ignition.
    • 2Disconnect the black battery cable and then the red battery cable, in that order, using a wrench unfasten the two torx bolts securing the lower lid on the steering wheel using a ratchet and torx bit. Pull off the red shorting connector from the underside of the lid and put the lid aside.
  • 4Reach through the steering cover opening, unplug the air-bag electrical connector and insert the red shorting connector to the air bag side of the unplugged connector.
  • 5Unfasten the three glove-box mounting screws and put the glove box aside using a Phillips screwdriver.
  • 6Unplug the passenger air-bag electrical connector and insert the red shorting connector located next to the connector into the air-bag side of the unplugged connector.
  • 7Pry off the small cover behind and on each side of the steering wheel using a small flat-head screwdriver.
  • 8Unfasten the torx bolts under the small covers using a ratchet and a T30 torx bit and remove the bag assembly from the steering wheel. Place the bag in a safe place away from your working area with the cover facing up.
  • 9Unplug the horn connector located on the upper side of the steering wheel assembly and the cruise control switch located off center and towards the right of the steering wheel assembly.
  • 10Make alignment marks on the steering column shaft, at the center of the steering wheel, and the steering wheel assembly so that you can reinstall the steering wheel in the same exact position. Use a marker.
  • 11Unfasten the steering-wheel retaining nut on the center of the assembly using a ratchet, ratchet extension and socket. Hold the steering wheel steady with one hand as you remove the retaining nut.
  • 12Rock the steering wheel carefully from side to side as you pull the wheel off the center shaft. If the steering wheel is stuck, install a steering wheel puller on the assembly and detach the wheel from the shaft.
  • 13Remove the upper and lower steering column covers using a Phillips screwdriver.
  • 14Unplug the ignition switch connector.
  • 15Insert the key into the lock cylinder and turn the key to the "On" position.
  • 16Unfasten the two ignition-switch mounting bolts from the steering column using a ratchet, ratchet extension and socket. Then remove the switch from the steering column
  • Aug 09, 2012 | 1993 Honda Accord
    2000 chevy how do you take out the steering column
    Pull the air bag fuse...
    Then get all that stuff on the steeringwheel (there is some philips head screws in the back side of the wheel)
    When you get it off, there, you will see a nut, remove the nut, and you will need a steering wheel puller, to get it off. They cost about $10 at the auto parts store.
    There is sets of bolts to bolt the puller to the steering wheel, and then put the long bolt through the center of the puller, and tighten it up, until the steering wheel comes off.
    It's not hard to do, or require any special skills.
    May 11, 2012 | Chevron Cars & Trucks
    My pram will not steer it goes all over the place. You can push it in a straight line, however when trying to turn it will not steer around, I have to lift it up off the ground and turn it on the back...
    You don't mention what make / model you have. Try turning stroller upside down ( without baby in it *-) ) and spin each wheel to see if it runs freely. Try to rock the wheels from side to side to see if there is any play in the axel. On a flat smooth surface do all wheels touch the ground? If the front wheels swivel do they rotate freely without any side to side play? Some strollers have nuts you can adjust others just have Silver domes. Try tightening nuts till wheels get tight then back off just enough so they spin freely try taping domes on tighter using a large socket from a socket set and a hammer so the pressure is around the edge of the dome and not in the centre where it would dent. Silicon spray is the best lubricant for strollers.
    May 11, 2011 | Baby Gear
    A headset wire stuck (wound) in crack of steering column in 1998 Contour. How do we retrieve it? Can the wheel be dismantled?
    Yes - the steering wheel can be removed, just be prepared for the wire to be smashed or mangles and unusable. Look on the back side of the steering wheel - you will see some small holes for the retaining screws for the center piece of the steering wheel. If your model has an airbag in the wheel you will need to disconnect the battery to prevent activating the airbag.Remove the panel below the steering wheel to access the harness for the airbag and unplug. Now remove those retaining screws and the center piece of the wheel. Now you will see a large nut on the center shaft of the column.Before you remove the center nut, look at how many threads are exposed above the nut before removing. Lock the steering wheel and remove that nut. Now you will need a steering wheel puller. Find the fasteners that fit your wheel and mount the puller, Turn the puller shaft 3 turns and try to remove wire - if it won't come out then you'll need to completely remove the wheel to extract the wire. Place the wheel back on the column shaft and use that center nut to re - install the steering wheel. You may need to place that nut socket over the shaft around the threaded part and tap lightly to seat the wheel far enough to use the nut to seat the wheel back down. Press steering wheel until it sits where it did in the beginning. Re - install center piece, plug in airbag and replace that lower panel. Your local auto parts store may have a steering wheel puller for rent - if not, they are not expensive to buy ( should be less than $10.00 USD).
    Hope this helps!!
    Dec 03, 2010 | 1998 Ford Contour
    How to remove and replace rear wheel tire on my mtd self propelled lawn mower model #126-478n134 part #634-0020 tire sized 8 inches.
    Part # 634-0020 is listed for the FRONT wheel. Your post asks about the rear wheel. I was unable to determine if the same part number fits the rear.
    FRONT
    1) Remove plastic hub cab with a screwdriver around the outer edge.
    2) Loosen the shoulder bolt in the center of the wheel (My guess is that you will need a 3/4 inch socket).
    3) Leave the bolt and all washers/bushings together and remove the entire wheel assembly as a unit (the bolt serves as the axle).
    4) Note the component locations and install the new wheel exactly as the old came off. Do one side at a time to be sure the reassembly is in correct order.
    Working from the bolt-head to the mount hole, the assembly should go as follows: Shoulder-Bolt, Wave-Washer, Wheel-Bushing, Wheel, Wheel Bushing, Bell-Cone Washer, Mounting-Hole.
    REAR
    2) Straighten and remove 1/8 inch cotter pin from center of axle and slide ratchet-spur off the axle while making note of the tooth direction.
    3) Slide the remainder of the wheel assembly off the axle.
    4) Remove the small shoulder bolt from the ratchet-pawl and note the direction. Remove the ratchet-pawl and ratchet-plate from the wheel. On the inside of the wheel is a "pem-nut" which may need to be held with pliers.
    5) Reassemble Ratchet-Plate, Pawl, Pem-Nut, Spur and Cotter Pin in the reverse order.
    As was mentioned before, doing one at a time will help keep the parts in the proper order.
    Hope this helps!
    Sep 30, 2009 | Mtd 22" Yard Machine Push Mower
    Cant remove steering wheel from john deere rx 95 lawn mower
    At the bottom of the steering wheel you should see a screw that goes crossways through the steering wheel and shaft. It will have a nut on one side and a phillips head on the other. Do not try to unscrew this bolt! Use a punch and tap it out from the nut side being careful not to damage the end of it. It is serated and will not turn with a phillips screwdriver. Once this is removed the steering wheel should just pull off. If it doesn't, post your model/serial number and I will check to see why.
    Sep 23, 2009 | Garden
    2000 Mercury Villager: Is there a shift lever adjustment? When placing foot on brake pedal and pulling shift lever rearward it doesn't feel like the transmission is completely disengaging and it is...
    You may have a loose shift linkage in the steering column. Remove the upper and lower plastic covers behind the steerong wheel (5 or 6 philips head) and see if you have any loose torx head or allen head screws. Ea
    rlier models had this isue.
    Also, go to this site for Villager Quest help.
    http://autos.groups.yahoo.com/group/villagerquest/
    Here's adjustment procedure too
    SECTION 307-05: Automatic Transaxle/Transmission External Controls 2000 Villager Workshop Manual
    GENERAL PROCEDURES Cable Adjustment —Shift Control
    1. Place the gearshift lever in PARK (P) position.
    1. Raise and support the vehicle. Refer to Section 100-02 .
    1. Remove the splash shield.
    1. Loosen the shift cable nut.
    1. Position the shift linkage in PARK (P) position.
    1. Tighten the shift cable nut.
    1. Move the gearshift lever through the entire shifting range.
    1. Verify that the engine will crank with the gearshift lever in PARK (P) or NEUTRAL (N) position.
    1. Adjust the transmission range (TR) switch as necessary, refer to Section 307-01 .
    Item Part Number Description 1 043B13 Driver side air bag module 2 — Steering wheel nut 3 3600 Steering wheel 4 — Radio volume control cover 5 — Air bag sliding contact electrical connector access panel 6 — Cruise control cover 7 14A664 Air bag sliding contact 8 13K359 Multifunction switch 9 — Tilt wheel lever 10 13318 Turn indicator cancel cam 11 — Steering column assembly 12 — Steering column mounting bracket nuts (4 Req'd) 13 3C695 Lower column shroud 14 — Steering column opening cover nuts (3 Req'd) 15 — Steering column lower yoke bolt 16 3N725 Steering column lower yoke 17 — Steering column clamp bolt 18 3C695 Upper column shroud 19 7210 Gearshift lever
    May 05, 2009 | 2000 Mercury Villager
    Kids Deluxe Fire Truck Pedal Car Red Logo
    56 people viewed this question
    Top Dexton Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Dexton Vehicle Part and Accessory Expert? Answer questions, earn points and help others
