Question about Redi-Remote TOSHIBA Replacement Remote Control for 72799183, MW27F11, AE006991, MW24F11, MW20F11
Some channels no sound
Can view but cant hear
I can only hear a sound when i try to play any videos in facebook
install latest flash player . also update your browser. you can download latest from this site. click here
Jan 13, 2012 | Cell Phones
Sound on speech is really really low, but music is fine (music within film is perfect) but I cant hear the dialogue
Perhaps if we knew the make/model we could dive into the manual (as you should do) and figure it out. As a hip-shot, I'd guess the center channel is adjusted too low or the center speaker is malfunctioning or undefined.
You don't say what you hear the dialog from. Mostly it would be the center channel, but sometimes it is shared across the front channels.
Feb 28, 2010 | Samsung Audio Players & Recorders
Im not sure if its the computer or the speakers but i cant hear anything?and there on and look fine,just cant hear anything?
Make sure the speaker connection is connected in back of the cpu. Check device manager to see that the audio and all hardware is working properly. Open up sound from the control panel classic view sound to see if sound is working. Just a couple of ideas.
Nov 30, 2009 | Dell Dimension 4700 PC Desktop
Bought an MXL V88 Mic and i hear no sound ,not working
go to control panel> hardware and sound> sound; click recording tab, select USB Audio Codec, select Properties, click Advanced tab, select 2 Channel 16 bit 44100Hz and then hit apply. You have to make sure you have the 2 channel option selected. otherwise the computer just recognizes one channel and assigns it for playback. HTH
Apr 09, 2009 | Audio Players & Recorders
I can't hear the recorded video!
At first, when you were not able to hear sound in playback on Camera LCD view, it was problem of Built-in Speaker defect. Now you can't hear sound on TV as well, it means Sound Processor IC is defective. You need to contact Sony Service Center for proper repair.
Aug 17, 2008 | Sony Handycam DCR-TRV25 Mini DV Digital...
Cant talk through mic
Sounds like a bad or miswired mic. Try a new mic ( use the proper cobra mic ). If the problem still continues, check all the swiches on the front of the radio and make sure you don't have any cold solder joints ( broken lead to board connections ). Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 19, 2007 | Cobra 29 WX NW ST 40-Channels Base CB...
No Signal through on my main TV input.
This may be the tuner or IF module that is failing. It may also be a voltage supply fault to these modules. It is impossible to accurately speculate without actualy troubleshooting the set.
Jerry G.
Nov 10, 2007 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Only left/right have sound during the test
all of the channel are resonding to the test. but you cant notice it bec 5.1 speakers, each channel are designed to respond to a certain frequecies.  the L/R channel your talking about have the mid-range frequecies so it responds clearly compared to other channels...
hope that helps...
Oct 16, 2007 | Logitech Z-5500 Computer Speakers
Redi-Remote TOSHIBA Replacement Remote Control for 72799183, MW27F11, AE006991, MW24F11, MW20F11 Logo
19 people viewed this question
Top Redi-Remote Televison & Video Experts
David Payne
David Payne
ray gallant
Are you a Redi-Remote Televison and Video Expert? Answer questions, earn points and help others
