Question about Quikut Division of The Scott & Fetzer Co, Fremont, Ohio - U.S.A Quikut Knife, Original Package, Double Blade, Fork Tip
Broken electric knife
I have been GE electric knife. I was wondering if you have any replacements for this? Cat.#_K15
9" electsric knife EK700
Sounds like the small cam that drives the blades is broken...and any resistance to it stops the blades from moving. Use a phillips head screw drive to open the knife and inspect the drive cam. It can be replaced if broken.
Jim
Mar 10, 2014 | George Foreman GR10AWHT Indoor Grill
Wondering if I can reverse direction on a GE 5 hp cap start cap run AC motor? The Cat. no. is 9038.
Hi
I think this situation is possible,however suggest that you make contact with your local electrical workshop, and they will give you all the help you need.
As a maintenance fitter have come accross this situation on numerous occassions, so suggest that you look for someone who has an open mind and looks outside the circle.
Hope this helps.
Cheers
John
Jul 10, 2011 | Electric Air Tools & Compressors
GE 1540 handle...bottom fastener is broken. How
remove w putty knife the inter face. you can see the screws at this point ,. just remove screws and reinstall handle . pop interface back in **** . you can get a brake down of how this fits on sears web sight . **** / hope this helps ( it;'s not a hard job /time 1/2 hr / mm .
Dec 22, 2009 | GE Spacemaker JVM1540 Microwave Oven
My GE Profile Dishwasher circa mid 1990s will not completely drain. I took the drain cage off and found pieces of broken glass and old food remnants in it. I used a shop vac to **** it all out....
Sounds like there is. It is common to find objects or small pieces of cloth stuck in the water pump. Remove the water pump and disassemble it and reinstall it. Or purchase a new water pump and replace the old pump.
Oct 22, 2009 | GE 24 in. Profile PDW7800 Built-in...
I need a replacement electric cord for a GE Coffeemaker
Hi. go onto eBay and look for Corning coffee pot parts. bobbyone
Jun 16, 2009 | Faberware FCP240 Coffee Maker
Agitator / spin cycle not working
HIthanks for your question. yes the belt could be broken. remove the front panel, use a puddy knife at each corner about 2 inches from the corner, shove the knife inbetween the top & front. push in. remove panel. belt is in the centre. thanks
Oct 15, 2008 | GE WBSR3140DW Top Load Washer
How to replace the solid element on a ge modelJ37SVWX electric range
removing burned out solid element on heartland stove and replacing with new one..It is enclosed with a chrome ring on stove top
Nov 14, 2007 | Ovens
Spacmaker xl sensor
Same goes for me. I can get most of the trim off but not the area near the hinge. ! It will cost $100 for GE to come out, and I already own the new handle. Come on GE tell us the secret.
Oct 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Quikut Division of The Scott & Fetzer Co, Fremont, Ohio - U.S.A Quikut Knife, Original Package, Double Blade, Fork Tip Logo
210 people viewed this question
Top Quikut Division of The Scott & Fetzer Co, Fremont, Ohio - U.S.A Home Experts
Donni Steen
Tom Chichester
Are you a Quikut Division of The Scott & Fetzer Co, Fremont, Ohio - U.S.A Home Expert? Answer questions, earn points and help others
