Question about Electrical Supplies
Generator honda em 1500
I have an old Honda EM1500 it starts no problem but not producing voltage I think it is the avr but unable to buy a new one due to it's age, so looking at replacing the capacitor but the details have worn off. Any ideas what capacitor to use?
  • 1,381 Answers
  • 83 Answers
SOURCE: Honda EMS 4500 Generator - High Voltage Problem
As far as I can tell on the wiring diagram for this generator there is no voltage regulator unless it's incorporated with the auto throttle unit.
To lower the voltage you need to lower the speed of the generator engine. To do this there should be a screw on top of the engine under the tank when your facing the recoil. This screw presses on a arm that controls your governor. Turning it in (righty tighty) will increase rpms, turning it out will lower them. You should see the voltage change on the voltmeter.
Posted on Mar 31, 2009
  • 154 Answers
SOURCE: Honda EM 2500. What oil does it require and does
30 weight
Posted on Jun 14, 2009
SOURCE: I have a honda generator em2500x voltage problem
Cummins P2200, 2KWatt, it starts fine, but after a couple of minutes, it gives quite high voltage output, meter needle goes beyond 300v, engine speed seems high since throttle is increased, indicator light on generator also becomes bright, after a minute or so, things come to normal, sometimes takes few minutes to come to normal, situation is same, with/without output load. this happens within initial 15 minutes after startup, afterward everything is normal.
Posted on Aug 14, 2009
jan mczeal
  • 632 Answers
SOURCE: generator starts but does not generate power
  1. Check for any blown fuse and replace. It can be traced directly from the output lines.
  2. Check field excitation. The field excitation is supplied by the battery to the excitation coil through a pair of carbon brushes. If the brushes are worn out, no excitation field is supplied and no output is generated. Replace carbon brush if found worn-out.
  3. Use an analog multitester to check the continuity of the carbon brush and the field coil.
Posted on Sep 25, 2009
SOURCE: Honda ems 4000 generator starts and runs great, but no power
At the controller, you need to see if it is actually sending electricity out of the Generator/Alternator, have a look where the leads from the power making unit mates, (Think of it as a motor in reverse) onto the board. There should be an AC Voltage there, then, work back, or out from there, trace the Voltage until it stops, thats the problem... Check the Breaker isn't tripped or faulty too.
Posted on Mar 22, 2010
Regulator voltage generator honda EM 1900x
Type honda em 1900x owners manual into your computer search engine, it will bring up sites to get manual.
Apr 25, 2016 | Honda Electrical Supplies
Honda EM1500 Generator not producing 240v how do I flash the fields I dont have a circuit diagram
Hi Richard
Not even the Service centres get circuit diagrams any more.
Proprietary Info I guess.
Is this a Sign Wave or Inverter Model.
Dont Flash the fields.
Probably an Alternator Stator controlled by the Rotor Field via brushes & controlled by regulator.
Then it may connect to a Semiconductor Solid State Inverter to give clean power for electronic devices
Good Luck
Jan 08, 2016 | Honda Electrical Supplies
Honda ec2200 generator
replace the avr,Honda ec2200 generator avr,or buy a used power head, HONDA EM2200X GENERATOR POWER HEAD USED , this is a chinese genset,it will take awhile to find a new avr,therefore get the used powerhead or scrap it for an american generator.de0da0dc-62d5-499c-871d-ba3a22ce8223.png
May 21, 2014 | Honda Garden
Power went out motor goes no volts why
If the fuses are good, your AVR (Automatic Voltage Regulator) may have failed or (less likely) you may have lost the residual magnetic field in your armature. With the generator off and your circuit breakers closed, plug in a corded 120V drill into one of the household 120V outlets on the generator. Spin the drill's chuck quickly, by hand, several times; This introduces a small electric current to your armature, "field flashing" the generator. Start the generator and check if the generator is now producing voltage. Sometimes this works, sometimes it doesn't. If no voltage, then it's likely your AVR has failed. You can purchase these online at ebay for about $35.00-$50.00. Buy a couple of them; these AVRs have a high rate of failure.
Apr 28, 2014 | Kipor Kde 5000ta Diesel Portable Generator
Black max 7kw generator high voltage output
Those voltage readings MAY be normal.
The AC waveform may cause your meter to read inaccurately. You would need to use a TRUE RMS meter to accurately read the voltage.
The siple meters actually read the AVERAGE voltage and then are calibrated to mulltiply it by the "form factor" for a sine wave. OFTEN these generators don't produce a clean sine wave. A square-ish wave will read higher on the garden variety meters.
Compare the brightness of a lamp comparing to when run on your utility.
The frequency depends on engine speed ... yours is running a bit fast...check it under at least half load and if off, adjust the govenor slightly.
May 01, 2010 | Briggs & Stratton Power Products 5,550...
Mar 22, 2010 | Electrical Supplies
Am not getting electric to generator, its a Honda GX270 9 hp, Thanks for any help
Voltage regulator, rotor, or stator are at fault here. Flash the fields F1 and F2 to see if you can produce voltage. Flashing consists of connecting positive from a battery (9V or 12Vdc) to F1 and negative to F2 while genset is running. If voltage increases, then you will need a voltage regulator. If voltage does not increase, then you will need a new generator end.
May 03, 2009 | Honda Electrical Supplies
Voltage output is only 50 volts instead of 120 volts
If you need troubleshooting help for your Honda or other portable generator there's nothing better than a handy schematic. This detailed diagram will help you troubleshoot your portable generator. In publications or online you may find a variety of schematics for Honda or other portable generators.
One handy book, which can be ordered online and delivered straight to your home offers troubleshooting guidance, including a number of schematics, for Honda, ATI, Coleman, Generic, John Deere, Mitsubishi, North Star, Porter Cable and Robin Subaru portable generators.
The book, entitled, Small AC Generator Repair and Service Manual - 1st Edition Volume 2, is discounted for under $30 on one Web site.
This portable generator troubleshooting publication is 420 pages, replete with schematics in the former of illustrations and diagrams.
Jan 25, 2009 | Honda 3000 Watt Portable Generator
Honda generator em 1800
Honda generators are very reliable and are easy to adjust. The best way to check for proper output is to use a meter that can check cycles and voltage. Set meter to htz or freq and adjust the engine governor to 60 cycles. When the engine is turning 3600 rpm it is at max power and the generator may be producing ac voltage ranging from 115 to 125 at 60 cycles. When you draw power from the generator the engine governor will try to overcome the stress and maintain 3600 rpm. The engine must be well maintained to produce full power. Service oil, filter, plug and valve adjustment. Some engines have a spark arrester installed in the muffler that may become blocked with carbon. If engine is producing full power and voltage/amps is low then check brushes, capacitors, and/ or voltage regulator. Most problems occur when too much power is requested from rated generator. Example, trying to connect an 1800 watt air compressor to generator. The compressor may draw double the stated wattage upon starting and cycling. For longest generator life, It is best to use only 75% of rated output. On an 1800 watt generator use max wattage 1350. If you actually need to use 1800 watts then the best generator would be a 2500 watt. enjoy
Nov 28, 2008 | Electrical Supplies
Electrical Supplies Logo
108 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
