Question about Toshiba 52HMX84 52" Rear Projection HDTV-Ready Television
My Toshiba 52HMX84 will not turn on but blinks 9 times on red light
I hit the power button and television tries to turn and fan turns on for 2 seconds then tv shuts down and red lamp flashes 9 times anyone hear of this issue? Thank you !
techman
  • 3130 Answers
SOURCE: Toshiba 57H81 Blinking power light
This sounds like the typical toshiba power regulator ic fault. it begins with an str##### Its not something a handyman should try to tackle. It should be repaired by a quilified repair person Sorry Good Luck
Posted on May 22, 2006
  • 65 Answers
SOURCE: Toshiba TN43V71 intermittently shut off
needs converge ics
Posted on Dec 09, 2006
SOURCE: toshiba theaterview red light blinking
new power supply
Posted on Nov 10, 2007
SOURCE: TV is not powering up and red light keeps flashing
I had the same red blinking led problem on my Toshiba Theaterview tv. I resolved by:
- Unplugging the tv.
- Press several times (3 or 4 times) the tv Power button.
- Plug the tv back in and press the Power button once to turn the tv on....tv worked!!!
I've had the problem before and tried unplugging the tv for a couple of days and that had also worked, but I this recent solution seems to be faster.
Erick
Posted on Jul 14, 2008
ginko
  • 19396 Answers
SOURCE: toshiba 46H84 tv turned off light blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
The green light on the front flashes 9 times, the unit powers down and then turns back on then the green light flashes 9 times again. It just continually does this and never stops. During this time the red...
You probably need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 10, 2010 | Toshiba 52HMX84 52" Rear Projection...
Turns on and off then back on then off
Discovered bulb had blown out.
At power on button, red light and green light flashed and no picture was present. I opened side panel after unplugging tv and let the bulb housing cool, then removed the bulb and discovered it had blown. Luckily I had a replacement bulb from the purchase, replaced it and it worked again.
Oct 01, 2009 | Toshiba 52HMX84 52" Rear Projection...
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV doesn't turn on, red light flashing
numder of flasing indicate error code . so i need how many flash you can see when power on the tv using front power butten then i will suggest the solution
Jan 15, 2009 | Sony KV-32S45 32" TV
Red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
Jan 11, 2009 | Sony KDF-E55A20 55 in. LCD Television
Panasonic PT43LC14 wont turn on
hi sir im tech in electronics ,if you go to change the lamp for another check the fan that is running cool sounds like the fan does not refresh the lamp and it burn again .
Jan 11, 2009 | Panasonic PT-50LC13 50" Rear Projection...
50" philips won't power on. get the 4x red blink led light
i have fixed 3 of this tv, with that exact problem in the last 2 weeks, needs a power supply, you can try to unplug it again, plug it in, hit the power button, as soon as it turns green, unplug it again, after 15 seconds , plug it back in, if power doesnt turn on by itself, turn it on, if it turns red again, emediatily hit power again, may have to hit power a few times in a row, but most of the time you can get it to come on this way, once it is on, it should run ok, until you turn it back off, but not a fix, needs power board
Jan 10, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Sony KDP-65WS550 flashes when you try to turn it on
No the DLP units can flash more than 8 times. 9 blinks mean Zero Crossing detector which means diode number D6166 or D6114 is open they are on the A board.Let me know if you need any further info.
Feb 23, 2008 | Televison & Video
Toshiba 52HMX84 52" Rear Projection HDTV-Ready Television Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
