Question about YouTube Computers & Internet
Fix a brake light on a town and country van
My brake light on the driver side is not working I changed the bulb but not resolved
  • 41 Answers
It's easiest to take the car to an automotive specialist. They have the tools to diagnose the issue in seconds as compared to tearing your car apart. Alternatively, you can get an ohm-meter and the manual for your specified model and do the work yourself, but it's a long...tedious... process that really isn't worth it. If you spent the same time making money as compared to working on your car, the cost would be cheaper to have a pro do the work.
Posted on Mar 19, 2014
1998 chrysler t&c brake lights wont work
you will need to get on your knees and look up under foot area drivers side , at the bake of your brake pedal is a switch , which is activated when you put your foot on the brake . replace this and things should be fine .
Mar 28, 2014 | 1998 Chrysler Town & Country
Brake lights on 1999 Chrysler town and country van does not work, any suggestions
Check fuses, wires and bulbs, finally check brake switch, generally is located backside brake peddal.
May 11, 2011 | 1999 Chrysler Town & Country
My brake lights wont work at all light bulbs has been replaced and fuses been checked its a 1996 chrysler town & country
Brake light switch can be checked with a test light. Since the 3rd brake light is not working That's probably the problem.
Feb 15, 2011 | 1996 Chrysler Town & Country
How do you change the brake lights?
you need to remove the case from the van. Pop the hatch and remove the screws on the inside of the light and the case will come out with a little wiggling. The bulbs will have a clip which you will need to remove. Then the light will also have a tab you need to push in and the bulb will turn out counterclockwise. install is the reverse of removal.
Apr 26, 2010 | 2005 Chrysler Town & Country
How do you change the bulb in the driver's side front dome reading light
On teh back of the headlight housing there is a interlocking bulb holder that your wires are attached to. Disconnect the wires, Unscrew the Bulb holder and replace old bilb with new one. Reassemble and reattach the wire socket.
its works in 2001 chrysler.. hope so it works in 2005 model also
rate it if it resolves your problem
Jan 08, 2010 | 2005 Chrysler Town & Country
How do you wire up a trailer harness to a 1999 Grand Voyager?
Your earth is bonding properly. Make sure you have a good bond that is fixed either to your chassis, with all rust, sealent and other cotings are removed frois should dolve your problem.m the fixing. Th
Jul 25, 2009 | 1996 Chrysler Town & Country
Tail light out replaced both brake & tail lite bulbs nothing
It sounds like your brake light switch is out.  It's located on the brake pedal and is relatively easy and cheap to replace.  Let me know if you have any questions.  Thanks for rating my response and for using FixYa!
May 27, 2009 | 1997 Chrysler Town & Country
How do I change the brake light and signal in 2005 town country
Open the tailgate and on either side you'll see 2 screws holding the tail light assembly. Unscrew these and the assembly will come off. It might take a little prying if it has never been removed before. Each bulb is in a base attached to the assembly from the back. Turn the base 1/4 turn and pull out to get access to the bulb itself.
Feb 14, 2009 | 2003 Chrysler Town & Country
Tail light does not work
I hope you arent letting a simple thing like a burnt bulb ruin your day??Im not sure what you have checked so far but start with replacing the bulb,check the connector very good as this has been an issue on many makes and models
Jan 28, 2009 | 1996 Chrysler Town & Country
Computers & Internet Logo
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
