Question about Whirlpool GS2SHAXL Side by Side Refrigerator
Where are the lights located
The lights have gone out, so where are they located
    Problem Solver:
  • 7 Answers
The lights are controlled by the control board behind the fridge. If you unplug unit and inspect the control board you will see a burnt spot on the control board. if so you will need to replace the control board.
Posted on Mar 20, 2014
Is it worth getting my swan teasmade repaired, only 3 years old. Only light working.
may not be as bad as u think? ur cold control may have gone bad and shut everything down. ur compressor relay gone bad, can be repaired inexpensively. some fridges even have a type of fuse usually located in back that GOES OUT
Mar 08, 2015 | Swan Refrigerators
Vw T5 caravelle. my interior lights at the back have gone out completely front interior still works fine,also rear back light is out all the time. When I lock the car the indicators flash to show car...
-Check the relay. It might stuck on.
-Basic check:
-Leave the hoop open and locate the relay. Then lock the car
and now remove (Unplug) the relay. If the light is gone
then the relay is bad. (It stuck on On Position)
Good luck
Mai
Nov 11, 2013 | 2004 Volkswagen Jetta
Brake lights have gone on my honda civic 1.5i 1995. I have located fuse box but it doesn't say which one covers the brake lights!
The fusebox lid/cover usually has the fuse layout inscribed on the reverse side - look for location of fuse, labelled TAIL or BRAKE lights.
Cheers,
"If this has helped you in any way, please rate this solution"
Jul 02, 2010 | 1994 Honda Civic
The LED light has gone out on my odomoter. How or
I own a 2001 Buick LS, I had the same problem ,Odometer lights and I fixed it myself. Here is a YouTube video that may help. Let me know how it goeshttp://www.youtube.com/watch?v=84FAjLxoK00
Another site where I originally located the very helpful information is RegalGS.org look under topic: Instrument Cluster Fix-Write Up.
http://www.regalgs.org/forum/viewtopic.php?f=45&t=31452
Jan 05, 2010 | 2001 Buick Regal
1994 chevy silverado tail lights and dash lights have gone out where is the fuse located? which fuse?
on a panel at the side of the dash or under the dash at the emergency brake. TAIL LIGHT OR REAR LIGHT FUSE
Dec 18, 2009 | 1994 Chevrolet Astro
Rear brake lights remain on.
check the brake switch. it controls a brake relay which may have fused contacts.
Aug 15, 2009 | 1996 Mercury Villager
No brake lights , everything else works
Sounds like your brake light switch, located on the brake pedal, has gone out. Shouldn't cost to much at auto parts store. Thanks for using fixya.
Jun 25, 2009 | 2001 Chevrolet Blazer
All lights work, except the brake /tail lights,the L.E.D. brake light on top works
The third break lights are LED and the circuit board may have gone bad or the solder may have gone bad. The circuit board is built in the third brake light and is a seal unit. You may have to replace the unit, there is a relay for the third brake light and that is located on the glove box behind the panel that say's relays. There are three relays in there, the center is for the fuel pump and the two out side are for the A/C and third brake light. Just swap them around and see if the brake lights come on. Good luck and keep me posted.
2001 F-150 Supercrew AC dash lights gone out
You have to remove the center dashboard bezzel out. Is held in place by pressure stubs only. After that, you remove the A/C control head. Look for a disconnected wire first. The tiny bulbs are located in the control's back. Feel free to email me for a diagram
May 13, 2009 | 2001 Ford F150 Styleside SuperCrew
Whirlpool GS2SHAXL Side by Side Refrigerator Logo
57 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
