Question about McCulloch Garden
The saw wont stay running. I start it with full choke and throttle but when I try to close the choke it just dies. I can get it to start with half choke, but again it will die when the choke is off. The plug, filter and carb are clean and free of any excess oil. I do not know how to keep it running. Help please
  • 520 Answers
Sounds like the carb needs to be rebuilt. Those tiny jets will clog easily and need to be replaced. The diaphragm is also a large part of bogging and dieing. Hope this helps.
Posted on Jun 14, 2009
Just starting to use this spring, and having fuel starvation issues. I ran it this winter a couple times and it ran properly.
add a little carb cleaner to the gas and try letting it run on half choke for a while longer .
Mar 28, 2015 | Garden
My dr 200 wont start when cold with full or half choke i jump start it and when it warms up the choke works fine....the mind boggles thanks guys
Are you giving it any throttle when you try to start it, yu shouldnt, keep throttel completely closed when using hte choke or you will flood the engine
Mar 30, 2014 | 2001 Suzuki DR 200 SE
Choke trigger on the handle will not lock to start the chainsaw
more information please..
To lock the choke on:-
1. depress dead mans trigget on top of back handle
2. squeeze throttle trigger fully in.
3. slide on switch fully down to 'full choke' position. 'it should stay there'.
4. Pull saw over until it fires once.
5. click 'on' switch up one position to 'half choke'
6. pull saw over again, saw should start running and be revving high.
7. 'blip' throttle, saw should stop revving and run on tick over.
Dec 31, 2012 | Stihl MS181 14" Chainsaw
Husqu51 starts once but dies then just turns over
take off the muffler and try it if ok then open it up and clean the carbon from the screen
Apr 02, 2012 | Garden
2nd use of chainsaw pp3516avx, it won't start, choke lever will not stay extended. I followed the instructions to start and nothing works
The choke system is connected to the half throttle position, if you lift the throttle trigger the choke pull will automatically return, whilst trying to start do not lift the throttle trigger, the starting procedure is, pump the primer bulb as many times as it takes to 3/4 fill the bulb, pull the choke pull fully out, this will switch the saw on and engage the half throttle, crank the engine until it fires once, do not continue to pull,it will actually not run on full choke, if you do continue to crank with the choke fully out, you will very quickly flood the engine, now push the choke fully in, now crank the engine until it fires up, lift the throttle trigger once, this will dissengage the half throttle, and it should now come down to idle.
Mar 19, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Chainsaw wont stay running
check crankshaft seals,maybe sucking air. most of the time the seal on the starter side. hope this helps.
Jul 09, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need carb h/l ajustemts and idle controle ajustment
This does take a little time to get it just right. Start at one full turn for the h and l. Work on the high first and after you get the H running work on the Low. They have to work together. So if you get it to idle and run at full throttle but it hesitates when you pull the trigger just adjust the low a little higher.
May 02, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
730 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
