Question about Dyson DC28 Animal Bagless Upright Vacuum
Brush stopped spinning and is sparking
HiI hoovered a shoelace up by mistake, and it started sparking, removed it, now the brush wont turn round and it is sparking, please help
  • Official Brand Answer
  • 2,572 Answers
Hi there Amanda, it's Jack at Dyson.
Unfortunately it sounds like the shoelace jamming the brush bar may have caused damage to the cleaner head. It's probably best if you can give our freephone Helpline a call so we can take some further details. If your machine is within our 5-year guarantee period, our experts can confirm if we're able to replace the cleaner head for you.
You can reach us on 0800 298 0298. Calls are free from UK landlines, and we're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends.
We'll look forward to speaking with you.
Posted on Mar 20, 2014
Testimonial: "Hello, Jack Thankyou for your help, it has stopped sparking and now the brush just wont spin when I press the button."
  • 1 more comment
  • AskDyson
    AskDyson Mar 20, 2014
    Hi Amanda,
  • AskDyson
    Even if the machine is no longer sparking, we would still strongly encourage you to get in touch so we can help check everything is correct with your DC24. If you haven't been able to reset your brush bar the cleaner head may need to be replaced.
  • Amanda Doherty
    Amanda Doherty Mar 20, 2014
    Thankyou Jack for all your help, as my Dyson is under Guarantee, I have an engineer on his way, and yes it may be my cleaner head, Thankyou.
My hoover F5515 was working fine but when I pulled out the tsnk to remove dirty water and place it back and turned it on, brushes stop rolling.
Hello Sonny! If the dirty water tank is not put back on securely it will prevent brushes from spinning. Take off the dirty water tank and replace it making sure it locks onto the cleaner and is flush. Now check your brushes for obstructions. Remove all hair and debris from the brushes. If the brushes still will not spin take your cleaner into a Hoover authorized service center for repair. Follow the link to locate the nearest service center in your area. Hope this was helpful!
Service Center Locator
Oct 19, 2014 | Hoover F5505 SteamVac Spot Vacuum
Hoover steamvac 50 stopped spinning
Hi! The brushes can stop spinning if something is obstructing them such as carpet fibers, hair, dirt or debris. Remove the brushes from the cleaner by grasping the plastic outer housing and pulling firmly away from the cleaner. Remove any debris and run it under running water to clean. On the back of the brush-block assembly there's a plastic drive pin that rotates all the brushes when turned. Turn the drive pin and ensure that all brushes are making a complete 360° degree turn. If the brushes are getting stuck or if a brush falls out then the brush-block will need to be replaced. Follow the link here to order a replacement brush-block for the Steamvac Search Results. Below is a list of models this brush will fit.
F5912-900, F5914-900F5915-100, F5915-900, F5915-905, F5917-900, F5918-900, FH50041, FH50042, FH50043, FH50044, FH50045, FH50046, FH50047, FH50048CA
Hope this helps!
Jun 20, 2014 | Hoover Vacuums
Dc24 has started sparking
Hi Amanda, it's Jack at Dyson.
Mar 19, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover max extract brushes wont spin
Check that the brushes are not jammed up with hair and fluff.
Remove the brush from the housing and clean throughly including the bushes/inserts and belt
Hope that helps
Feb 09, 2014 | Hoover Platinum Carpet Cleaner With...
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brushes won't spin
First, please be sure to unplug your Steam Vac and remove both the clean water and the dirty water tank.
There should be a square stem that sticks up in the center of your brush assembly. If this stem is broken you will need to replace the complete brush assembly. If the stem is good; turn your cleaner on it's side and check in the area where the brush assembly goes (with the brush assembly removed). In the center of this area there is a square hole where the stem from the brush assembly goes. The square hole is in the bottom of the turbnie that spins your brushes. Using a large flat blade screw driver (not so large that you'll damage the hole), stick it in to the square hole and try to spin it. It should spin freely, if it is very hard to spin or won't spin at all, your turbine is bad and will need to be replaced.
Hoover part number for brush assembly:48437022
Hoover part number for turbine: 43191008
May 19, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brush part not spinning
The hoover savvys have a reset button on the top of the hood, its to keep from destroying the belt. Simply press that button and the brush should start to turn.
If this does not solve the problem it is more than likely the belt (rubber band thingy :) ) in this case pull the bottom plate off again, but this time lift the brush out and slide it to the side and out from the belt. Then look inside the machine and get the belt off of the motor drive gear. Once the belt is out turn it inside out and make sure the teeth to the belt are all there. ( if they are not there will be burn marks.) If it is missing teeth simply replace that belt and you're back in business.
If it is not the reset and it is not the belt, some of those machines had bad switches in the handle. You will find that there is a circut board in the top handle which sends power to the vaccum motor but not the brushroller motor making it seem as if everything is running just fine. You will not be able to buy just the circut board, they come as an assembly and include the whole handle. Unfortunately there is no good way for someone unexperienced to tell wether there is power to the brushroller motor or not. In this case a Hoover service center would be able to assist you though you may end up paying a small labor fee.
Jun 04, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Spin Scrub Brushes won't turn
If the brushes quit spinning, either the brush block shaft that goes into the turbine broke off, or the turbine is bad. This unit is tricky to take apart and then put back together again. But pull the brush asm off, then start taking out screws. But if after you pull off the brush block, look up where you will see a small square hole, turn unit on and if not turning, usually the turbine is the cause and will have to be replaced.
Jan 13, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Dyson DC28 Animal Bagless Upright Vacuum Logo
164 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
