Question about SVP New Pp003 Portable Pocket Projector
SVP Pocket Projector won't turn on
My SVP Pocket Projecter Pp003 has been working fine up until recently. I charged it last night and today it will not power on, no matter how long I hold down the power button. What do I do?
My watch won't stay charged
Your watch needs a new capacitor ( rechargeable battery of sorts) take it to a jeweller unless you have tools and know how.
Dec 22, 2013 | Citizen Eco-Drive BL006056H Wrist Watch
Westclox
Well Melissa, you have about a hundred parts or more in the watch. If anyone of them is dirty, broken or whatever your watch will not run. You need to go talk with a watchmaker (not a jeweler) about your watch. If your watch hasn't been "overhauled" in the last ten years then that is most likely what is indicated. Watch oils and greases evaporate or turn to a scummy mess which may be the problem. Or you may have a broken balance staff. Or you may have rust and dirt built up to the point the watch can't overcome it.
Dec 21, 2011 | Elgin AU13 Antique Pocket Watch
I took our my battery last night to charge, i reinstalled today, and i get no lights when switched on, nor any power from battery. i took out battery when i noticed that the extension cord used to plug in...
Take the battery to an auto parts store and have it tested, that would be the first step, just because you charged it doesn't mean it is charged.
Apr 15, 2017 | Watches
How do I set the time on an old Regina pocket watch. I can wind it and it runs well. The piece to wind the watch does not pull in or out to set the hands.
If you can wind your pocket watch using the crown, but you cannot see any way of setting the watch, you probably have a "lever-set" movement, though it's possible you might also have a "pin-set" movement. Do you see a little button you can push in, either at 1-2:00 or 10-11:00 on the watch case? If you, you have a pin set watch. Push and hold that little button in while you twist the winding crown, and that will let you set the time. End of problem.
Setting the time on a lever-set watch is a bit more complicated and will require taking off the front bezel of your pocket watch--the metal ring that holds the watch crystal in place. Pocket watch cases of this time are usually made in 3 pieces: the bezel, the main case body, and the back. The procedure used to remove your bezel depends on the type of watch case you have.
Take a close look at the front of your pocket watch. Do you see any hinges at the bottom (that is, below 6:00 and where the bezel meets the main case body)? I suspect that you won't, as double-hinged cases are usually associated with an older style of pocket watch, but it's worth checking. If you do see little hinges for the FRONT (it's more likely that the back will be hinged), then look for a little lip on the bezel that's used to pry open the front. Pull on that to open the case.
If you don't see hinges, which is what I expect, your front bezel unscrews. You can try to do this with your bare hands, but it's a lot easier if you have a bit of "gripping" rubber so your hands don't slip so badly. I have a small rectangle of shelf non-slip stuff that works perfectly for this. Turn the bezel counterclockwise. It may resist a little bit at first due to accumulated dirt, but then it should easily screw off.
Once you have the bezel away from the face, look closely at about 2:00 on the watch dial. Just at the edge of the dial, you should see a little lever or button. GENTLY pull this away from the watch face until it stops. Now, when you turn the winding crown, you should be able to set the time. Once the time is set, gently push the lever back to its prior position. Now, you should be able to wind the watch without changing the time.
Be very careful when screwing the bezel back onto the watch body. These parts typically have very fine threads, and it's easy to cross-thread the pieces. Don't force the two pieces together; once the threads catch properly, the front bezel will screw on easily without resistance.
An older style of pocket watch required the use of a little key to set the time from the back of the pocket watch movement. However, these watches were also wound by the same key, so the fact that you're able to wind this watch with a crown suggests to me that your watch doesn't use this system.
May 27, 2011 | Watches
My Lady Ambassador watch stops every night between 11:45 and midnight (I do not sleep with it on.) In the morning, I reset it and it runs fine - until night time. The watch is less than a year old.
Does your watch have a date change?
The date usually changes about this time and it could be this that is stopping it working. Having it serviced could solve the problem, it it hasn't had any attention for a long time.
Sep 20, 2010 | Wittnauer Watches
I have recently bought a Tag Carrera Calibre 16 and now the date will not change when i turn the knob. It was working up until this week. Seems like its stuck. Help
Take it back to the nearset dealer or service center. It will still be under warranty and they should fix any problems free of charge.
Do not attempt any repairs yourself, as it will invalidate the warranty.
Sep 06, 2010 | Tag Heuer Watches
Recently I bought a 1914 gold finished hunter cased Elgin pocket watch . I love it ! but when I bought it the crystal was out and I have two original crystal replacements perfect condition , but do not...
Congratulations on owning a great watch, I also collect these fine pocket watches.
RECOMENDATION:
Seek professional help.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 21, 2010 | Elgin Circa 1904 Watch
E010 S95986 HSB power cell does not hold charge
Change the capacitor. This is the thing accumulating the energy. As the ordinary batteries, it may go bust, so, all you have to do is to replace it. There is no such a name as power cell in Citizen EcoDrive watches - there are CAPACITOR. Capacitor absorbs the energy from the light sensitive panel(s) and dispenses it in the ordinary battery manner. Advertisements are saying that you will never have to change the battery - that's right, because there are no batteries at all. Instead of battery there are CAPACITOR, but nobody says it will last forever. Rate me, plz.
Mar 05, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
My seiko stops overnight but works during the day
if the watch is solar power it may not be getting enough to last through the night. if it is battery powered it may just be stuck when in certin postion like upside down or somthing
Jun 03, 2009 | Seiko Kinetic watch
SVP New Pp003 Portable Pocket Projector Logo
Top SVP Watches Experts
Ansel Alberto
Ansel Alberto
Are you a SVP Watch Expert? Answer questions, earn points and help others
