Question about Ovens
Neff b45e42.0gb no power
No indications when power turned on
I have Neff double oven the top oven has the fan going and this is displayed in the clock area
This is what was posted on another site, hopefully it will help you.
E005 indicates a communication problem.
Basically, the electronic boards were unable to talk to each other.
If powering off and back on cleared this then it's likely it was a software glitch and "rebooting" sorted the problem out.
If it does happen again and won't clear, you will need to check the wiring between the boards inside the appliance and possibly replace the boards.
You can't prevent spikes in the mains that may cause spurious errors I'm afraid. (which is what I think may have happened in this case).
Hope this is of some help
Let me know how it goes or if you need more help
Thanks
Jan 31, 2017 | Neff Ovens
Have a neff oven U14M42.3gb, tried using the preset operation mode to cook whilst out. But when I set it up the cooling fan stays on, all the videos and instruction say it should switch off.
This was posted years ago on another site, hopefully it will help you too.
Thanks
Jan 29, 2017 | Neff Ovens
NEFF OVEN B1593. I have an oven neff b1593 and it's been locked.i don't how to unlock it.
Unplug the Oven from power for 5 minutes and see if it resets and the door unlocks.
Oct 24, 2016 | Neff Ovens
My neff oven b1322.1 is showing c03 code since moving , I now can't set the timer and clock etc can anyone help to solve this?
The C03 error indicates that the timer button is stuck or not responding. Check if the buttons can move freely; you may need to remove the rubber cover by prying it up. If the buttons move freely, sometimes the error can be cleared by unplugging the oven (or turning the unit off at the circuit breaker) for several minutes (up to 30 minutes). Turn the power back on. Then press and hold the Timer button for more than 180 seconds (3 minutes). Some people have reset the timer by setting the function selector to "interior light on" instead of pressing and holding the timer button.
If none of these actions work, then the timer clock needs to be replaced. If you add a comment with the full model number of your oven, I may be able to give you the part number. NEFF doesn't list a B1322.1; there are several B1322N1 models. There will be addition numbers in the model number and there may be some extra letters as well. See http://www.neff.co.uk/store/spare-parts to get a picture of where the rating plate is for your unit. That will have the full model number.
I hope this helps.
Oct 01, 2016 | Neff Ovens
Neff B1644 Oven Fan Issue
096825 is the part number for circo fan grease hardened in the motor bearing is making it stiff the motor has little torque to overcome resistance the grease melts at high temps allowing motor to turn. time for a replacement comes as complete unit with new blade.
Jan 28, 2014 | Neff B1644 Electric Single Oven
Neff oven element glows white
It sounds like the wrong replacement element for the power it is getting. If you are using a 220Volt stove, the element MUST be for that voltage and NOT for 110 Volts.
Jan 23, 2013 | Neff U1721 Double circotherm Electric Oven
My Neff Main Electric oven does not heat up, the fan is running, the thermostat light is lit and I have replaced the element. ???? One of your experts states that it could be the temp control or the High...
If the thermostat light is lit, then it cannot be the temp control, as this what is causing the light to work, indicating that the power is there . I f I were you, I would ascertain that you are getting a feed to the element.
If you are, then new element is faulty, if no feed then you need to trace the wires back to thermostat and work from there.
Jun 06, 2010 | Neff U1721 Double circotherm Electric Oven
My neff oven error -5-. How do i turn this off?
I also had an error 5 on my Neff B1691 cooker. This indicates that a child lock has been set. To unlock you just push and hold the central control button in for about 7-8 seconds. Do the same again to set the lock again...
Mar 21, 2010 | Neff B1421 Electric Single Oven
Neff B4562 Pyrolytic Cleaning Not Working
You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
May 01, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Neff oven B1641 child lock
I actually had the same problem and got the solution. Maybe its a bit late, but hopefully there will be somebody who find this useful as well.
Its not an error. The -5- indicates that the oven is "children protected".
- Put the left ON/OFF switch into its OFF position (the left switch)
- Turn it quickly 3 times: one click to the left and then one click back to right again [light position, Off position]
=> The message disappers.
If you do this again, the protection is switched on again.
Greetings from Germany
Jun 25, 2008 | Neff B1641 Single circotherm super...
Ovens Logo
24 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
