Question about LG Cell Phones
My LG flip-phone automatically set itself to voicemail response.
Cell phone does not allow me to answer; automatically sends incoming calls to voicemail. How do I undo this automatic voicemail
SOURCE: lg ax355 cell phone not receiving incoming calls
Have you tried rebooting the phone as I experienced a similar issue
Posted on Jan 08, 2008
  • 31 Answers
SOURCE: Auto Answer
Hello PattiPaige,
The feature to disable answering the phone when you open the flip can be found under:
Settings & Tools
- Call Settings
- In Call Setup
- Answer Options
- Set option to Off
This will disable the flip from answering the call when opened.
As for increasing the font size, i don't believe there is an option to do so. If I become aware of one I'll try to get back to you on.
Hope this helps,
cHiPz
Posted on Mar 24, 2008
SOURCE: not recieveing incoming calls go straight to voicemail
call cricket cause sometims that would happen to my phone but it was just because they messed up my bill and got it confused with someone elses
Posted on Apr 28, 2008
SOURCE: I need to block incoming calls to my LG 260 cell phone.
I got the solution:
First, go into Settings < More < Restrict & Lock [Enter your lock code]
Second, go into Limit Calls < Incoming Calls < Special #'s only
Third, go into Settings < More... < Security < [Lock code] < Special Numbers and [Add the numbers you want to block]
Posted on Nov 05, 2009
  • 5 Answers
SOURCE: i cant answer an incoming call, the screen goes black
you need to recalibrate the proximity sensor. this is what stops you from pushing buttons when you are in a call ect. to do this go to main menu > phone settings > proximity calibration. from here you can recalibrate the screen which should fix the problem
Posted on Apr 16, 2010
How to send incoming call to voicemail
You have to set up a call forwarding when busy. Ask for your voicemail's phone number at your mobile phone provider, they will help you out quickly with it!
Aug 17, 2012 | LG Attune
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
How do I set up voice mail
Call services From your phone, you'll be able to access and change the settings of various call services for your phone.Contact your mobile operator to find out about the availability of call services. From the Home screen, press MENU and then tap Settings > Call. Fixed Dialing Numbers Restrict outgoing calls to a fixed set of numbers. To enable this feature, you must know your SIM card's PIN2 code.
Voicemail service Shows the current voicemail service being used.
Voicemail settings Specify another voicemail number aside from the voice mail number on your SIM card.
Clear voicemail notification If you have a notification of a new voicemail, you can clear the notification with this option.
TTY mode Enable this mode to connect and use a compatible TTY device with the phone.
Hearing aids Enable HAC (Hearing Aid Compatible) to amplify in-call volume.
Phone settings Edit the call reject message, choose whether to open the message editor when you reject a call with a message, and choose whether to allow automatic saving of an unknown contact number when a call with that number ends.
Cell broadcast Enable or disable receipt of cell broadcast messages from your service provider.
Cell broadcast settings Configure channels and language for cell broadcast messages.
Call forwarding Select how you want your phone to handle busy, unanswered, and unreachable calls. You can also set the call forwarding option for all incoming calls. Call barring settings Choose whether to block various categories of incoming and outgoing call.
Additional settings Enable or disable operator services such as caller ID and call waiting.
Jun 28, 2011 | HTC Inspire 4G Smartphone
When someone calls me my phone does not ring but alerts me that I have a voicemail. It is going straight to voicemail.
check your incoming calls settings and see that you did not choose it to divert to voice mail number
Mar 28, 2011 | LG Xenon GR500 Cell Phone
If i want to reject some call. thn how could it b possible
Without a specific make and model from you, I dont know about your phone specifically, but most cellphones,if you press the End Call button while the phone is ringing, it will reject the call.
Most cellphones send the caller to voicemail when the call is rejected. Some simply cut the caller off.
I am almost certain that this will work, I have yet to see a cellphone that doesn't.
Make sure you have Any Key Answer turned OFF in your Call Menu...
Some phones let you choose which activity answers incoming calls. Most options are Answer Key to answer, Any Key To answer, or Flip Open to answer. Choose the Answer key Only to pick up calls.
Then, when you press the End Call button, your caller will be rejected....
Good Luck!!
Feb 01, 2011 | Cell Phones
My lg 410g phone does not ring when there's incoming call but goes directly to voicemail
the reason the phone automatically goes to voice mail is simply because the phone has sim card has been set to do so.
The solution is for you to deactivate the voicemail.
That is when you will be able to receive your call properly.
To deactivate the voicemail, all you have to do is to dial ##002# and send.
it will deactivate the voicemail of your phone and you will be able to receive your calls aswell as your phone will also start to ring out.
take care
Jun 18, 2010 | LG Cell Phones
LG CHOCOLATE: identify phone number of incoming voicemail
try transferring the calls from ur mobile to the voicemail when u r not available....
in call settings u might have an option of forwarding the incoming call after so many particular number of rings... forward the calls to ur voicemail numbers using this and then u ll have the numbers in ur recieved calls list.
this might work but is only a temporary solution
Jun 15, 2010 | LG CHOCOLATE VX8500 Cellular Phone
I cant answer an incoming call, the screen goes black
Apr 10, 2010 | LG GC900F Cell Phone
Time consuming incoming automated phone call
With a CallPilot voicemail system, you could have the system recognize the caller id info of the call and send it directly into a mailbox, eliminating the need for your digital answering machine. That's the only option I am aware of.
Hope this helps.
Mar 28, 2009 | GE 29869GE2 Digital Answering Machine
Setting the voicmail
Voicemail or telephone answering device (TAD). There is a BIG difference. Voicemail is product of your telephone service provider. If you have voicemail, most providers have a solution to this that you must arrange through them. If you have an answering machine, you can set your Brother to TAD mode. In TAD mode, if your answering machine picks up, (you must set your answering machine to answer in less rings than your fax), your fax will "eavesdrop" to listen for the fax tones from the sending machine. If it hears these tones, it will disconnect your answering machine and accept the incoming fax. If it does not hear the tones, it allows the answering machine to record the incoming message. If you are home. If you answer the call and hear a tone every 2.5 to 3 seconds, that signals an incoming fax. Simply touch *51 on the keypad of the phone you picked up on. You will hear some shrill tones. That is your fax machine attempting to receive the incoming fax. Hang up the phone you are on and it will receive the fax. In any case, make sure that the receive mode is NOT set to AUTO. Set the receive mode to TAD or MANUAL. If these instructions were not clear enough, let me know and I will send you DETAILED instructions. You can find the manual here: http://www.brother-usa.com/Data/Documentation/Fax/User/UM_FAX2820_FAX2920_MFC7220_MFC7225N.pdf If you need additional assistance, please let me know before you rate this solution. Ed
Jun 29, 2007 | Brother IntelliFax-2820 Laser Fax
Cell Phones Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
