Question about Ovens
Kenmore stoves Help when my oven is plugged in it is running at top temp. Tried to unplug and reset but when i plug it in the oven starts automatically and goes straight to 500 degrees and won t shut off unless unplugged. need to know the name of part so i can order it! Please help I got 3 hungry little girls! LOL.
    Habit-Forming:
  • 45 Answers
Do you have it in clean mode? Otherwise sounds like your temp control is out
Posted on Mar 19, 2014
localwonder
  • 6784 Answers
SOURCE: oven will not get out of the self-cleaning mode
Ok, unplug the unit for 5 minutes to reset the main circuit board. if the error continues to plague the unit, replace the control board.
Posted on Jun 01, 2009
watugot
  • 290 Answers
SOURCE: Kenmore Oven and stove not igniting
If both top and oven are not igniting, then most likely you need an ignitor board. I should be located behind the left side of the console as you are looking from the front of the stove. I will look it up to be sure. There should be a tech sheet on the back panel of the stove to help in checking the boards.
Thanks/Mike
Posted on Dec 03, 2007
MNTECH
  • 1543 Answers
SOURCE: GE True Temp oven won't turn off.
The sensor is a part number WB23T10002 and goes for about $60. The paper inside the control area of the oven will state the normal resistance values of it. (probably about 1080 ohms at room temp, about 2650 at clean temp.) If you cut a lead to it, you would just get a F3 code, and if you cut the other and wire them together, just get a F4 code, so that wouldn't help diagnose the problem, but if you could use an ohm meter on the probe it would. BUT the oven should not come on without it being set to bake, SO I conclude that the ERC is indeed the problem (with the welded electrical contacts), which is a part number WB50T10043 which might go for about $125 or so. If you are careful when you replace it, you can probably peal the faceplate (part # WB27T10125) off and reuse it, so you should just need the ERC.
Posted on May 07, 2009
  • 547 Answers
SOURCE: oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Posted on Aug 04, 2009
TheMobilian
  • 8220 Answers
SOURCE: My Hotpoint gas oven won't turn off unless I
My neighbor had that happen. Replace the oven control
Posted on Dec 19, 2009
Testimonial: "Thank you for the advise. I will give it a try."
How do I unlock a Kenmore stove/oven? I've tried to unplug to reset, but didn't work
Is it on clean? If so keep it plugged in and let the cycle run. If not its the board.
May 03, 2017 | Kenmore Ovens
Electronic control panel went blank and oven is beeping
The first thing I would do, because it is an "electronic" control panel is to unplug your stove, wait about 30 seconds, then plug it back in. Your Control panel may just need a reset and reboot.
If it is difficult to get to your plug-in, then go to your household breaker-panel box, and flip the switch for your stove to the off position for at least 30 seconds, then switch back to on. ...That's the same as uplugging and plugging back in at the wall.
Hope this helped hun ;-)
Oct 03, 2015 | Ovens
I have a frigidaire self cleaning oven and range top. while i was baking the temp just suddenly went off and the door was locked. tried pushin lots of buttons, nothing happened. so i unplugged it for a...
Hi, try opening the door and looking for a little black switch on the right or left side, that the door actuates this is the door switch, while the stove is plugged in, hold this switch in and see if the lock moves.
Sean
Mar 26, 2011 | Frigidaire Ovens
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My "Probe" keeps beeping. I tried cancelling...no help. Tried heating oven at 400 degrees as suggested by one person (to take out the humidity....)for 15 mins. Helps for awhile but then starts beeping...
The top oven the stove will lift up,with effort,and fold back,unplug first,and see if it needs cleaning and the sensors are in there I think,clean them,try to unplug it to reset,see if that helps.
Nov 20, 2009 | KitchenAid Ovens
Oven doesn't work, stove does
Aug 04, 2009 | Ovens
Kenmore oven not working
Hi, You need to unplug the stove, take the back panel off and check continuity on the bake element or after the back panel is removed, plug the oven back in, and turn oven to bake. You should get 240Volts to the two terminals on the bake element. If you have 240 Volts, the element is bad and needs replaced. I can ship you the new element.
Hope this helps
Vic
May 08, 2009 | Ovens
Oven does not work
According to the manual, the self cleaning latch could be stuck.
If the oven door is open, press STOP/CLEAR to clear display, then depress and hold switch plunger for 6 seconds (Located in the upper right corner of the oven front) and the oven door will unlock.
If the oven door is locked, press STOP/CLEAR to clear the display then apply pressure to the upper right corner of the oven door and the door will unlock. If the "F" code reappears, contact a Sears trained repair specialist.
Sep 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore, f2
I can help but I need a model number
Kenmore are made by many different manufacturers of their appliances..
F2 error is most likely a oven sensor problem . your over sensor has to low or high Ohms or you Electromic oven control thinks it has to high of an Ohm reading. replace oven sensor and or control
let me know if this helps
Jun 06, 2008 | Ovens
Ovens Logo
57 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
