Question about Gb Electrical Measuring Tools & Sensors
No power in cig lighter
Can not charge anything
    Habit-Forming:
  • 28 Answers
There is normally a 20Amp fuse that protects this unit. Check your fuse box for blown fuses. WARNING: If you remove power from the battery - then you may have to return to a seller to re-enable passwords to drive radios/cassettes etc; unless you have authentic manuals.
Posted on Jul 12, 2014
On my 2006 dodge stratus my cig lighter won't work
Normally this would be in your owners manual.
The power for the outlets may be on the same circuit with the horn.
On some models there is an accessory relay that handles the outlets.
There should be a 20amp fuse in the box in the engine compartment that feeds the circuit. You may have to check all of the 20amp fuses to find it.
Jan 17, 2013 | Cars & Trucks
Blew a 25 amp fuse for the cigarette lighter, replaced it with a new one but still not getting any power from the cig lighter, is there another fuse hidden somewhere??
No power from the cig lighter if you have a voltmeter youll have to test it for power at its harness behing the cig lighter, just to let you know that cig lighter also wears out and a replacement may be it the fix for you,also there is only one fuse for it
Jun 04, 2011 | 2006 Pontiac Montana SV6
Does not read obd plug, so it cannot pass inspection, a/c does not work or turn on neither does the cigarrette lighter
often times if you fix the cig. lighter (replace fuse) you will be able to read obd. uses power from that fuse to power up scan tool. make sure no pennies or anything in cig lighter blowing the fuse.
Aug 19, 2010 | 1997 Toyota Celica
Overloaded my inverter -now only works when hooked to car battery
It sounds like the fuse that protects you cigarette lighter is blown.
After you have replaced the fuse, check the voltage again. 0.015vdc would not have powered anything that in manufactured to operate on 12vdc.
When powering anything over about 250W, I would suggest connecting directly to the battery to avoid overloading the lighter circuit.
Nov 07, 2009 | Vector VEC1024 400 Watt Power Inverter
Cig lighter works 4 cigs but wont charge satnav however much i twiddle about with it, help!!
Try checking the fuse inside the charger. Ths may be blown. Have you tried another charger in its place ex. cell phone or radar detector? If works for the cig lighter should charge.
Nov 05, 2009 | 2001 Ford Focus
Cig lighter on 2004 solara will not work fuse box
fuse may be named room fuse or accessory fuse
Oct 05, 2009 | 2004 Toyota Solara
Cigarette lighter plug not working
hopefully nothing serious. if you can, make sure your wires did not burned or got too hot.Visually inspect them. Then, if you have a voltmeter check to see if you getiing power to it. no voltmeter? Go to your nearest auto parts store and ask for a test light. Back to the lighter, if you have power on the wires or wires leading to the back of the lighter, more than like it you lighter burned out.  No power on the wires? make sure wire did not get fryed or burned, all wires look good? check fuses again.  worst case scenario, can't find problem ? you can run another wire from your fuse box to the lighter.
May 13, 2009 | 1994 Toyota Celica
Battery charging
Cig-lighter offers 1A current. The battrey will be fully charged for 4 hours if the unit is not used.
Jun 15, 2008 | Garmin nuvi 200W GPS Receiver
Measuring Tools & Sensors Logo
60 people viewed this question
Top Gb Electrical Measuring Tools & Sensors Experts
danoyachtcap
danoyachtcap
Trevor Turner
Are you a Gb Electrical Measuring Tool and Sensor Expert? Answer questions, earn points and help others
