Question about Microsoft Windows Vista Ultimate Edition
I am trying to key text beginning with non-sequential letters/numbers. I cannot make Word quit changing what I key to sequential letters.
Word overrides what I key and inserts sequential letters/numbers instead.
    Sergeant:
  • 396 Answers
I am unsure which version of office you are using. This is a function of auto-correct. You may need to turn it off to stop this behavior, and turn it back on, if you need it to help you compose documents.
( My directions will be using Word 2007, which is what I have installed on my system.)
You need to open the Word Options panel. and go to Proofing.
GO into this location several times in a row, so that you can remember it better, and return to re-enable auto-correct. Uncheck the boxes needed to turn off this behavior.
Posted on Mar 19, 2014
Capitol letters to begin each word
Try following :-
  1. Select the text that you want to change the case of.
  2. On the Home tab, in the Font group, click Change Case za010210667.gif (as shown in the diagram below), and then click the capitalization option that you want.
    • To capitalize the first letter of a sentence and leave all other letters as lowercase, click Sentence case.
    • To exclude capital letters from your text, click lowercase.
    • To capitalize all of the letters, click UPPERCASE.
    • To capitalize the first letter of each word and leave the other letters lowercase, click Capitalize Each Word.
    • To shift between two case views (for example, to shift between Capitalize Each Word and the opposite, cAPITALIZEeACHwORD), click tOGGLE cASE.
    • To apply the small capital (Small Caps) letter formatting to your text, see the note and diagram below.
Jul 07, 2013 | Computers & Internet
I have a Samsung Convoy. The camera zoom stopped working. The phone is 7 months old and has had no abuse. Also, when I want to text and I'm on the window to enter the phone number of the intended...
menu-messaging-left soft key for settings-entry mode. This will make your text be in letters rather than numbers and then all you need to do is change the letters to numbers in the address of one text and it will continue to be numbers.
Nov 11, 2010 | Samsung Convoy Cell Phone
I have a motorola v545 and want to turn off the predictive text help!
Go to messages, new message, go to the menu(middle button) select entry options/method/settings, go to primary and select TAP English, go to Secondary and select None.
Text-Entry Methods:
iTAP - Lets you enter words using one key press per letter. The iTAP® method combines your key presses into common words and predicts each word as you enter it.
TAP - Lets you enter letters and numbers by pressing a key repeatedly to cycle through the letters and number on that particular key.
TAP Extended - Same as TAP, but cycles through additional special characters and symbols as you repeatedly press a key.
Text-Entry Modes:
Primary - You can set your Primary entry mode to any iTAP or TAP entry method.
Secondary – You can set your Secondary entry mode to any iTAP or Tap entry method, or you can set it to None if you do not want a Secondary entry mode.
Numeric - Enter numbers by pressing the number keys.
Symbol - Enter symbols by pressing a key; its symbols are displayed at the bottom of the screen. Scroll to the desired symbol and then press Select.
To set the text-entry mode or method:
  • From a text-entry screen, press Options.
  • Scroll to and select Entry Setup or Text Setup.
  • Select the desired text-entry mode or method.
Tip: From any text entry-screen, you can quickly change your text-entry mode without leaving that screen. Press the # key repeatedly to cycle through the text-entry modes: Primary, Secondary, Numeric, and Symbol. With each press of the # key, the mode indicator in the upper left of the text-entry screen changes.
Nov 15, 2009 | Motorola Mobility RAZR V3
My blitz doesnt text
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
Aug 05, 2009 | UTStarcom Blitz Cell Phone
How do you change the text message settings to TAP instead of Abc
How to set up Text Entry Mode?
1. From any text entry screen (ie. when you are writing a text message), press the top center button, the one above the directional wheel.
2. Press on "Entry SetUp"
3. Select the "Primary Set Up" or "Secondary Setup" by choosing your preferred input mode among the ones below. Us the wheel by pressing on the right arrow to change mode:
  • ITAP: it's a built-in software which predicts the word you are typing.
  • TAP: enter individual letters and numbers by pressing the keys multiple times. Ie. for the letter "F" press the number 3 button three times.
  • Tap Extended: enter individual letters, numbers and symbols by pressing the keys multiple times
  • Jun 11, 2009 | Motorola Mobility RAZR V3
    Changing to capital letters in texts.
    i might be wrong on this one, but all motorola's are mostly the same on texting. Soto get a capital letter in text just press the 0 before the letter
    Mar 11, 2009 | Motorola Mobility L71 Cellular Phone
    Predictive text problems with my samsung u900
    when on predictive text if you want to change a word just click the "0" button (one with the Cross sign) this will cycle though the different words for you
    rate me please thanks
    Oct 04, 2008 | Samsung U900 Soul Cellular Phone
    Motokrzr K1
    your phone's text entry mode is currently set to 'predictive text' which means the phone is trying to 'guess' the word that you want. Teenagers find this easy to use and fast, but I, like you, absolutely hate it.
    This mode is easily changed. When you start to write a text message, before entering any text press the 'hash' key (bottom right) sequentially until the top left of your display title bar shows 'Abc2' this means your phone is now in ordinary text entry mode.
    You can also change the case (capitals etc) by sequentially pressing the 0 button (bottom centre).
    Hope this helps
    Aug 12, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
    How to delete a letter while writing a text message, also how to get rid of predictive text
    it depends on your model number.
    Usually you can delete a letter by hitting the clear key.
    Usually you can change predictive text to standard by pressing and holding the 1 key, the * key or the # key.
    Jun 25, 2008 | Samsung Cell Phones
    Highlighting
    you may have turned on click-lock. You can disable this feature in Control Panel, under Accessibility Options. Click Lock helps people who have a hard time holding the mouse button while dragging the mouse across the screen by holding the mouse button for them
    Oct 02, 2007 | GE Wireless Optical Mouse
    Microsoft Windows Vista Ultimate Edition Logo
    62 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
