Question about Philips 34PW9846 34" TV
Too much overscan
The picture does not fit the screen
    Top Expert:
  • Philips Master
  • 75,571 Answers
If EHT is lesser than normal, this type of fault can occur. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Mar 20, 2014
Repaired the convergence and now the image quality is good but the TV seems to be over projecting the screen. The top, bottom and sides of the image are cut off slightly. is there a way to adjust?
Hey! its me again. I think what your experiencing is called overscan. This website might help but if not just google how to fix overscan on a projection tv.
http://www.cnet.com/news/overscan-youre-not-seeing-the-whole-picture-on-your-tv/
May 24, 2016 | Televison & Video
How to change the screen size on a Westington TV
Hey,
In order for you to change the screen size on your Westington TV you have to press on Format on your remote (it is the button between the volume and the channel, right under the input button). As you press on it, it will change the display. From
  • Standard: Picture is displayed in its original size.
  • Fill: Picture is displayed to cover the entire screen.
  • Overscan: Picture is scaled down to fit the display area.
  • 1:1 Mode: Matches the incoming resolution exactly to the pixels without any scaling.
And now everything should be good!
Enjoy!
May 13, 2014 | Westinghouse 55" Class 54-5/8" Diag. - LCD...
Pc resolution doesnt fit on screen
There is probably an overscan option in the TV menu. Make sure that is off. Otherwise, adjust the resolution on the computer to fit correctly.
Mar 28, 2014 | Hitachi P42H401 42 in. Plasma HDTV
White stripe on screen
Unfortunately it seems that each time I turn the tv on and off it resets the screen position and I have to adjust it each time.
I would assume that my set would remember the settings.
Use Picture Size, not Picture fit. Set it to 16:9, instead of Fit To Screen. There's a handy button the the remote for this: P-Size. And the setting sticks between shut-offs.
What you are seeing is called "overscan", extra information that most broadcast stations send, because most old TV's were set to zoom-in/crop the signal they received. So.. with new TVs, like your Samsung, you get the choice between size "Fit to Screen" which is 1-to-1, for pixel-accurate inputs like Blu-Ray and DVD, and size "16:9" which is really "support for overscan", for old, less precise signals like broadcast.
Mustang Parts.
May 28, 2012 | Samsung Televison & Video
Xfx disc wont load and i cant register my new card .i need to do this as ihave no catalyst control so i cant overscan the picture size to fit screen.i also need to know my cards status.
You don't need to install the drivers from the CD. Go online
and use your Personal Activation Code to create an account
and register your new card. You are then allowed to download
the drivers and Catalyst softwares.
Jul 19, 2011 | Computers & Internet
Panasonic viera doesn't display computer correctly
I have had what is fundamentally the same problem. I have a desktop PC that I am plugging in to my Panasonic Viera TX-32LZD80. I am using DVI connection plugged in to HDMI port.
The solution is fairly simple; use the Menu button on the TV remote to get to the Main Menu for the TV and then select Setup which should be the fourth of four options. This will get you to the Setup Menu for the TV for the current channel. Look for the Picture Overscan option, it will very probably be set to On if you have the problem of %5 or so of display being missing on all sides.
Switch Picture Overscan to Off.
This immediately should solve your problem. A note of warning on this is that I suspected this was the problem but when I first looked at the Setup Menu I could not find the Picture Overscan option.
If you are unable to find the Picture Overscan option then trying fiddling with the Aspect settings. You will probably find it set to Auto. Switch it to 16:9 and you should find the Picture Overscan option will be available from the Setup Menu.
Hope it works for you.
Mar 03, 2009 | Televison & Video
Overscan
do you mean the top of the picture is cutt off? if so then go into tv menu and set screen size to 16:9 not auto. if that doesnt work then try settings on ps3 hopefully that works
Jul 23, 2008 | Toshiba 55H70 55" Rear Projection...
My LG HDTV is in overscan, can't resolve
Have you tried to reduce the ratio on the remote..when zoom comes on lower the zoom ratio.
Dec 23, 2007 | LG 37LC2D Television
Connection to MAC Mini
No changes can be made to the picture size on the panel. Most PCs have a facility to reduce the size by software means to correct this sort of problem (for example in 'Display properties'). As for the Mac; since it's not my area of expertise I can't say for sure but I'd be suprised if it didn't have this feature.
Nov 08, 2007 | Pioneer PDP-5060HD 50 in. Plasma...
My Picture is wider than the screen
How much wider are we talking about? It is normal for all TV's to be a bit overscanned anyway.
Apr 18, 2007 | Apex Digital GT3215 32" TV
Philips 34PW9846 34" TV Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
