Question about Fuji FinePix S5000 Digital Camera
How do you manual zoom on this camera?
Do you need a new lens attachment that doesn't come with the basic package?
  • 423 Answers
You can't, it's power zoom only, even with a lens attachment.
Posted on Jan 28, 2008
Need information and Instruction Manual for a Vintage Bushnell 300mm camera lens
This is not a zoom lens, it is a fixed focal length of 300mm telephoto, so the focus ring will not slide back and forth, merely rotate. It is also manual focus. If you google it, you may find a manual, but doubtful - best bet is to get a book on basic photography and read up on telephoto lenses there.
Update - allegedly made by Tokina, so should be a reasonable lens.
Apr 01, 2017 | Bushnell Cameras
This lens makes a whirring noise when attached to the camera body. It will not focus in either manual or automatic. The camera works well with the other lens.
Sounds like the focus mechanism is broken on that lens. There's a small screw on the back of it where it meets the camera body, the motor in the camera body turns that screw to autofocus. To me it sounds like the screw is turning, but the lens isn't focusing. You said it also doesn't focus in manual mode, so there is probably something inside the lens that needs repair or replacement. Your best option is to take it to a camera repair shop and ask them for an estimate, camera lenses are not the kind of thing you can take apart and fix on your own. Hope that helps.
May 03, 2011 | Nikon 35-70mm f/2.8D AF Zoom-Nikkor Lens
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
Lens keeps getting stuck/needs a good tug to zoom past 25 HELP!
Hi Rachael_amor, If the lens will not zoom on the camera will it off the camera? If not then it has some grit, dirt, and the like in the lens. You could attempt to vacuum around the zoom however, I suspect it will need to go in to Nikon. That lens is not well weather sealed, it is a inexpensive consumer lens.
Jun 02, 2009 | Nikon D80 Digital Camera with 18-55mm Lens
How to digital zoom
The camera has a 15x optical zoom. Once you've reached the threshold of the lens (optical zoom), the digital zoom kicks in (if you have the option turned on - see manual for details pg.104).
According to the manufacturer, the digital zoom is "Approx 5.7x." (see Specs, below)
Do keep in mind that digital zoom only enlarges an area of the true picture; you actually lose pixels (resolution). Here's more info from Wikipedia about the digital zoom option:
-You'll need Adobe Acrobat for this file. They are a well-trusted and secure name. You can download the viewer for free from their site:
Manufacturer Specs
I hope this is useful to you. Happy shooting!
Mar 20, 2009 | Fuji FinePix S2000hd Digital Camera
AV flashing in LCD of camera whn zoom attached
I found on some lenses you need to go into the menu , select settings and change av appurature setting to 2 instead of 1 .
Feb 20, 2009 | Pentax *ist DL Digital Camera
AV error whn pentax ist DL & Quantaray zoom lens attached
I've got the same problem. The problem is that the lense is loosely attached to the body. What you need to do is that when you see the Av flashing, press the lense of the camera to the body and twist the lense to the left a bit. This tightens the connection. You can then take the photo.
Instuctions for opteka 650-1300 lens for use on konica minolta
Try turning off the shutter lock.. In my Dynax 7D manual it tells you to turn off shutter lock when attaching to a telescope or microscope this is what this lens basicly is .The shutter lock is turned on and off in section three of the custon menu on my Dynax ,check your manual for your camera to find out where to turn on and off shutter lock, hope this helps
Jan 18, 2009 | Canon Opteka 650-1300mm F8/16 Super...
Conversion lens
A conversion lens should be attached using the conversion adapter CLA-1 (41mm-43mm, optional) and the step-up ring. However, the fish-eye conversion lens FCON-02 cannot be used
Sep 01, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Conversion lens
A conversion lens should be attached using the conversion adapter CLA-1 (41mm-43mm, optional) and the step-up ring. However, the fish-eye conversion lens FCON-02 cannot be used.
Sep 01, 2005 | Olympus C-3000 Zoom Digital Camera
Fuji FinePix S5000 Digital Camera Logo
23 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
