Question about Samsung HT-F6500W/ZA New 5.1 Channel Home Theater System [ht-f6500w] -
SAMSUNG HT-F6500W/ZA RENDOMLY THE POWER CYCLES ON & OFF
THE POWER KEEPS CYCLING ON AND OFF.
3 Suggested Answers
roety
  • 585 Answers
SOURCE: My Samsung TV power indicator light cycles on and off.
Hi my name is Eric,
I hope I can help you with your issue ,
Your power supply is the problem, a repairman will charge between $250-$450
depending on if they repair or replace the power supply
Seems you know about this already, they are either 1000uf at 16volts radial caps or 2200uf
open the set and look for bulging caps
here is where you buy new ones
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Eric
Posted on Sep 26, 2009
  • 14 Answers
SOURCE: Samsung Hl-t6176S Flat Panel. Keeps cycling, no
see thi s site - I just fixed my tv using this site...lots of geeks.
http://www.badcaps.net/forum/forumdisplay.php?f=31
Posted on Jan 24, 2010
MAKING A SAMSUNG HT-F6500W REGION-FREE
1) Switch Player off then On (this is to clean-boot firmware).
2) Wait until main menu appears
3) Open Disc Tray and Close Disc Tray (May not be necessary)
4) As soon as "No Disc" is displayed quickly press REPEAT on
remote quickly use the following code for your current
region:
Region 1: Press - 2,9,3,3,4
Region 2: Press - 5,7,5,3,8
Region 3: Press - 5,6,7,3,2
Region 4: Press - 7,6,8,8,4
Region 5: Press - 5,3,8,1,4
Region 6: Press - 2,4,4,6,2
5) Your current Region will appear in the top-right corner
6) Quickly Press "9" before it disappears (It should replace
the code with a "9" in the corner)
7) Switch Player Off and then On again.
Note that REPEAT is part of the code so one smooth press of
6 keys is required.
There isn`t currently a region hack for Blue-Ray Disks
Dec 27, 2013 | Samsung HT-F6500W/ZA Home Theater System -...
How to make aSAMSUNG HT-F6500W region free (hack-code) as I am an expat
region:
the code with a "9" in the cThere isn`t currently a region hack for Blue-Ray Disksorner)
6 keys is required.
Dec 24, 2013 | Samsung HT-F6500W/ZA Home Theater System -...
My Samsung HT-x250 keeps shutting down. First of all after about an hour and then ever 5 - 10 mins after that?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Sep 04, 2011 | Samsung HT-X250 Theater System
My HT-X20 keeps on going into protection mode after 1 hour then every 5 minutes. What should i do?
Suspect heat.
Sep 01, 2011 | Samsung HT-X20 Home Cinema 600W Theater...
Why does protection come up on the display of my samsung ht-x200
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 27, 2011 | Samsung HT-X200 Theater System
My samsung ht-p10 theater system displays protection then shut down
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 06, 2011 | Samsung HT-P10 Theater System
I have a Samsung HT X 30 home cinema after about 15 to 20 minutes turns off saying protected??
Feb 06, 2011 | Samsung HT-X20 Home Cinema 600W Theater...
My samsung HT-Q40 turns on then says protection, then instantly turns off is there a way to fix this or is it garbage now?
Generally speaking, an amp protects itself from heat, shorts and overloads.
Jan 30, 2011 | Samsung HT-Q40 System
Turning off and writing prot
It's not clear where you're seeing "protect" nor how you're connected to your TV so I have to make some assumptions.
The manual for the HT-BD2R wasn't available but the HT-BD2/HT-BD2S was...
http://www.retrevo.com/support/Samsung-HT-BD2-Home-Theater-Systems-manual/id/22986bh646/t/2/
Read the section of page 24 regarding HDCP and page 70 regarding Copy Protection.
If the unit is powering itself off...
Jan 15, 2011 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Hi my name is Eric,
I will reply asap
Thanks
Eric
Sep 26, 2009 | Samsung LN-T5271F 52 in. LCD Television
Samsung HT-F6500W/ZA New 5.1 Channel Home Theater System [ht-f6500w] - Logo
95 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
