Question about Pool & Spa
Rheem pool heater does not light.
Display shows SPK and I hear a clicking sound. Pool technician says I need a new circuit board and igniter for $500+ which I am skeptical about. What else could it be and what can I do to troubleshoot?
  • 372 Answers
It would be unusual for both the board and the igniter to go out at the same time. You should have a CFH code before SPK . That is Call For Heat and SParK. The clicking is the heater trying to fire up. It sounds like the igniter is doing its job. For some reason there is no gas getting to the pilot. That could be the board not telling the gas valve to open. It could also be the gas valve malfunctioning. You may want to have another tech take a look at it. It could just be dust or dirt in the pilot assembly.
Posted on Mar 20, 2014
5 Suggested Answers
  • 83 Answers
SOURCE: When Heater is turned on display shows 125, doesn't ignite/fire.
I am not sure if you have solved this issue, or not, but here is one idea. When you turn on the heater, it is reading the temp at 125/126 correct? IF this is what the heater is reading, then the problem is the Thermistor,or temp sensor, and is very easy to replace.
If you have an Owner's Manual, there are part numbers and instructions on how to replace the Thermistor. If you do not have one, follow the link below and it will take you to one online:
http://www.pentairpool.com/pdfs/MaxEThermOM.pdf
Posted on Jul 01, 2009
  • 11 Answers
SOURCE: Pool heater sparks but does not light up
coud be several things, Do you have Gas and is gas toruned on. Is valve on. The Pilot could be dirty and need cleaned. $350+ sounds reallly pricy for a pilot assembly. Call your Gas Company and get an Estimate and a Qualifed Service tech. You may try turning Off the Power to the Heater Unit and turning it back on , and then trying to turn on heater again, So times after several atemps the valve will lock out and the power needs reset on Propane units.
Posted on Jun 29, 2010
  • 760 Answers
SOURCE: rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Posted on Jul 05, 2010
  • 3 Answers
SOURCE: Our pool heater display shows
burner will not turn on
Posted on Nov 01, 2010
Why does pool heater read SPK and won't light?
Sounds like your ignitor is shot. You may have to replace it.
Jul 24, 2014 | Rheem Water Heaters
Rheem SPK display
if clicks then check gas line to ignitor if no click replace sparker
Jul 19, 2014 | Rheem Pool & Spa
What part do i need when plt code comes display ?
spk I think means spark for ignition and plt means pilot so i assume the heater tried to light but the pilot light is not staying on. could be dirtly contact on the ignition spark plug or dirty pilot flame need to be cleaned and the unit serviced.
i hope this was useful.
May 28, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
Heater takes a long time to fire up.
There is a flow switch if that's not working. same problem needs to be tested Gas valve solinoid could cause this Igniter could cause this problem Gas pressure regulator wrong pressure should be about 2.7KPA LPG Gas valve should be set to about 2.6 KPA LPG
Mar 28, 2013 | Rheem M206A 206K BTU Pool and Spa Propane...
Raypack pool/spa heater works intermittently
You can try pulling your pilot assembly out and clean it. Sometimes it will get sooted up and cause the sensor to short so the heater get's a falce reading and shuts the heater down. Then sometimes the heater will start and sometimes it won't. If this dosen't help check the ignition wire for any cracks or anyplace it may be shorting. Good luck.
Feb 17, 2010 | Raypak Versa 130,000 Btu Above Ground...
Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
RayPak 2100 pilot won't light heater. I'm getting PLT message.
Well your right it is your ignighter the spk is spark the plt piolet light this pc is about 200 .
THANK YOU FOR USEING FIXYA
RATE ME
Mar 29, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Pool Heater
check to see if ignitor is lighting if so check gas line to ignitor if no ignitor replace and check safety circuit
Nov 05, 2008 | Raypak DOOR ASSEMBLY
Pool & Spa Logo
131 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
