Can't stop beeping
Xerox 5855
  • 33 Answers
Machine needs something, press machine status button, the one with a question marks. Check "Consumables" for low toner, drum end of life or fuser end of life. Or cleaner or waste bottle.
Posted on Jun 25, 2014
XEROX WORKCENTRE 5222 IT KEEPS ON BEEPING 4 TIMES WHEN TRYING TO PRINT IM USING HP LAPTOP
JAPh.
post for one PC at a time never 2, and never Lenovo to HP forums.
what pc, you failed to say 2 things
what PC, HP full name and model numbers laptps
what beeps the PC or the alien Xerox printer.
what OS do you run on the HP puter.? XP?
my guess is you are not talking to Xerox are you.
you need to, ask them for drivers that work in all possible unstate OS operating system. HP can not help fix any Xerox of any kind.
only Xerox can !
Mar 08, 2018 | Xerox Office Equipment & Supplies
Touch screen calibration xerox 7345
Switch on the power while simultaneously holding down the numerical keys 0, 1, and 3 on the Control Panel.
The Calibration Screen 1 will display
In numeric sequence (P1 to P9), touch the intersections of the vertical and horizontal lines with the stylus.
Apply the stylus to each of the four line intersections. A black square should appear at the point of contact, and a beep should sound.
If four beeps are heard, adjustment is OK.
If you don't hear four beeps, repeat the adjustment from step 1.
Switch the power off and then on.
Feb 16, 2012 | Xerox Office Equipment & Supplies
How do i shut off the energy saver compliant on xerox c20
For majority of the models Xerox entry in service mode holding [0], include the device.
Entry in service mode
Xerox 5845, 5855
Or include the device with simultaneously pressed button [Interruption] and [2], or on included device to press and hold these buttons more than 2 sec. If device faulty - an entry is realized button [Interruption] and [5], with restriction function (consecutively appearing reports on fault are thrown double keystroke [Foots]).
Hereinafter, the device calls четырQхзначный code of the access: this or 8765 (by default), or the last four numerals counter mines in inverse order (if counter mines shows 01234567 - a code of the input 7654).
Xerox N17, 24/32/40, 3225/4025
There is 3 diagnostic modes:
1 - are checked breakers, sensors and are removed parameters фьюзера, input: (2+6), after "IOT?" press "7" 2 - haves something published the test-sheet "net" in simplex or duplex, input: (2+6), after "IOT?" press "4" 3 - are changed parameters and adjusting the printer (NVRAM), input: (2+6), after "IOT?" press (4+7), "7" immediately release, "4" keep before appearance "3" on дисплее, then release.
XD102...155, XE60...84, XC800...1255
stop auto stop auto
sometimes write as C Density select C Density select (that same)
WC PE 16(e)
we type on keyboard [menu] - [#] - [1934] - [menu], after entering inscription "TECH" will appear in service menu
Oct 12, 2009 | Xerox CopyCentre C20 Black and White...
My wife's Eureka 5855 Boss Bagless Wide Track stopped running
its probably something in the motor. you may have to replace the motor which could cost around $50.
Apr 15, 2009 | Eureka 5849A Boss Bagless Upright Cyclonic...
Copier beeps after scanning
Is this connected to a Vista computer? There might be a few extra things that need to be turned off permanently in the computers admin settings.
Nov 21, 2008 | Xerox Office Equipment & Supplies
Xerox 5665 beeping for all functions
  1. Press the [Log In / Out] button on the left side of the Control Panel. The System Administrator Login screen will be displayed.
  2. Enter the System Administrator Login ID using the numeric keypad on the Control Panel, and then select the [Confirm] button on the Touch Screen. The System Administrator Menu screen will be displayed.
    NOTE: The System Administrator Login ID and UserID is '11111' by default. If an error is made, press the [Clear (C)] button and re-enter the ID. To cancel the operation, select [Cancel]. If the administrator has a problem with changing or has forgotten the ID, a service call must be placed.
  3. Select the [System Settings] button twice. The System Settings screen will be displayed.
  4. Select the [Common Settings] button. The Common Settings screen will be displayed.
  5. Select the [Audio Tones] button.
  6. Select the required option from the list, and then select the [Change Settings] button.
  7. Select the [Save] button to save the settings.
  8. Select the [Close] button several times, and then select the [Exit] button to exit.
Jul 03, 2008 | Xerox 5665 Copier
70 people viewed this question
k24674
jasbo
jasbo
