Question about Frigidaire Washing Machines
My Frigidaire FWT645RHSO front load washer sounds like a propeller airplane when it spins...HELP!
Today I noticed my front load washer is making a propeller airplane noise when it is spinning. It sounds like it is coming from the front, underneath. What do I check?
    Novelist:
    Champion:
  • 220 Answers
Robin, it sounds like the tub bearings may be going out on your machine. With the washer empty, reach inside at the top and gently lift the inner stainless steel tub. Does it move up and feel like there is some slop or play in the tub. If the bearings are tight, the inner tub will not move much at all independently of the complete outer tub assembly.
Have you noticed any grease on any clothes recently? Usually what happens is the water seal fails and the water eventually washes the grease out of the bearings and they fail.
Depending on your skill level, there are some good online blogs about tub bearing replacement. You may not want to deal with it. You have to make the call on that. Thats my 2 cents worth. Good luck.
Posted on Mar 21, 2014
  • robin walls
    robin walls Mar 22, 2014
    There is a TON of play in the tub. I realized it was the bearings from what I have read. My NEW washer is being delivered in the morning! I'm going with the Kenmore Elite 41073. It is 5.2 cu ft!!! My old one was only 3.1 cu ft, so I am looking forward to this HUGE washer!!
  • 105 Answers
SOURCE: Frigidare Front Loading Washer model# FWT645RHSO
check out the drain pump if drain pump is blocked up water will not get away quick enough and stop machine from spinning
if that is clear
turn bowl by hand and if you get a runble noise then the main bearings are gone
that will need dismantle and replacement or new machine
Posted on Mar 16, 2008
SOURCE: frigidaire front load washer
I had the same problem. The service tech came out and replaced the pump, it has been working fine ever since. I couldn't believe the pump went out in only a couple of years.
Posted on Jul 10, 2008
aborcass
  • 2651 Answers
SOURCE: frigidaire front load washer no spin
sounds as if theres something stuck in your drain pump, youll need to remove the lower acess panel(2 screws across the bottom front of unit) you'll see teh pump in the rigth hand corner. i would remove as much water as possible before trying to remove the hose to the pump or you will get soaking wetaferer removig the hose youll be able tro see what trapped in oyu pump preventing free draining.. VERY common problem.DISCONNECT POWER THE DRAIN PUMP IS ALWAYS LIVE!!!!!!!!
Posted on Oct 19, 2008
  • 220 Answers
SOURCE: Frigidaire front loading washer makes a clinking noise
It sounds like your tub bearings are starting to go bad. Mine sounded like airplane taking off. Once the seal goes bad, water tends to migrate into the bearing cavity and flush the grease out of the bearings and then they wear quickly.
You have to completely remove the tub assembly to take it apart. Some say get a new washer, but I only paid $60 for the 2 bearings and a seal from a bearing house. They are even cheaper online.
You may as well try and fix it, worst case the junk yard doesn't care if it's in pieces when you bring it to them. I have no idea what an appliance repairman would charge to fix it.
If I remember right the seal is a 80mmx40mmx10mm metric seal. I found a rubber coated one from SKF I believe. The bearings should be 6306-2rs and 6307-2rs, but I would not buy anything till you have it apart. The bearings knock out easily.
INFO-Mine had -2z bearings installed which are only shielded bearings. The -2rs bearings hold up much better to water exposure in case the new seal leaks in the future.
If you want the exact seal part number, I can get it off my paperwork, Just write back.
I saw somewhere on an appliance blog that had step by step pictures of the procedure.
Posted on Jan 12, 2009
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Whirlpool cabrio washing machine doesn't spin
Try to turn the drum by hand, if it hard to turn, there may be something stuck underneath spin basket. If it does turn freely but makes a loud growling sound, you probably have a bad bearing. You should notice black oil and water mixture at bottom of washer, on the rotor. It will usually throw a f51 error code. This unit has service bulletin on this problem.
Apr 05, 2014 | Whirlpool WTW6400SW Cabrio Washer
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
My frigidaire LTF6700FSO will not spin
Your symptom sounds like a jammed drain pump. Was it spinning and then stopped before the spin cycle should have ended or did it not begin spinning when it should have?
Jan 17, 2013 | Frigidaire ATF6000ES Front Load Washer
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
FWT645RHSO drum is making a sound
Sounds like on of the chocks may have failed. Open the cabinet and look at the shocks to see if 1 or more have failed. Here is a link to the shocks in case you need them.
Oct 13, 2012 | Frigidaire ATF6000ES Front Load Washer
Terrible noise when spinning.
Hello, Thank You for using FixYa. I will be helping you today.Ifits a loud roaring or sounds like an airplane then the bearing failed. Check your warranty because it is very expensive to repair.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jun 30, 2011 | Frigidaire ATF6000ES Front Load Washer
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
Loud noise in the end of cycle, during spin
Hello, Thank You for using FixYa. I will be helping you today.If it sounds like an airplane it is a bad bearing in the tub.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
148 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
