Question about Primera Technology Autoprinter, Bravo Se, 100-240VAC, InkJet
Tray is sagging won't pick up disc
Tray comes out and disc is placed in the tray, then when arm comes over to pick up disc and put in the printer, it won't pick up
ERROR 024-959
Xerox 6605 paper tray empty error, the paper detect sensor arm and pick up roller get out of place. remove paper detect sensor arm and pull down on pickup roller assembly it should be springy not stiff. once it springs again, put paper detect sensor lever back on, on the right side of that lever gets tucked behind pickup roller assembly. hope this helps. The Magic Man!
May 29, 2014 | Xerox WorkCentre 6605/N Color Laser...
Unable to pick up papaer on tray 2 error 13.00
common faults for poor feeding on lj5200
1, feed rollers are worn - replace
2, sep pad is worn ( cant seperate pages correctly)- replace
3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
Dec 13, 2013 | HP LaserJet 5200 Printer
How to install a lexmark t644 250 sheet pick arm ***'y in 3rd tray
We do not advice that you remove the pick arm for the Lexmark T644. I would suggest that you contact Lexmark Technical Support or contact a local Lexmark Service Provider (please click on the link below to locate a Lexmark Service Provider nearest to you).
Link: http://bit.ly/UeQhSB
Jul 04, 2012 | Lexmark T644 Laser Printer
Slide tray won't turn and accept slide --the arm moves up and down but that is about all.
Sounds to me like one of the return springs has either stretched out or fallen off. There is no easy way to diagnose this.... takes hands on from an experienced tech. The Slide Lift Lever has to come up high enough to put the slide back into the tray, plus give enough clearance for the tray to rotate. I sure hope this helps. Jim
May 08, 2012 | Kodak Carousel 4400 Slide Projector
Printer i making a weird clicking sound. It won't print. It has error light On. Status: load tray 1 / Plain letter Toner level is 80%
check if there is a paper at tray 1. if so, may be the printer is unable to pick up paper due pick-up roller problem. try to remove the tray and look in the middle, there should be a rubber like roller. if its too glossy it cant pick the paper.
Sep 18, 2011 | Dell 1720dn Laser Printer
The pick arm on a Dell M5200 printer is not dropping to the top of the paper in the tray and does not feed the paper. Ideas?
That's odd
Usually its the other way around. ie stays down...
Remove the paper tray completely from the device and have a look inside,
is the pick arm lowered?
Check the RHS lift spring on the pick assembly, and the bell crank it attaches to. (these snap)
Hard to say from this end without a visual ...
Dec 09, 2009 | Dell M5200n Laser Printer
It does not pick papers
There's really nothing in common except the motor. When you have the covers off, the printer will default to the manual tray because the sensor arm is on the cover. If you want to check printing from the lower tray with the cover off, you have to block the MF sensor. A folded piece of paper works well. You made no mention of lights coming on and at what point. Need that info to diagnose it any further.
Aug 10, 2009 | HP LaserJet 6p Printer
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Feb 04, 2009 | Lexmark T640 Laser Printer
Paper feed
Check tray 1 there should be an arm hanging down in the center of the tray the arm goes thru a slot in the metal plate. This arm moves when you install paper in tray 1. If the arm is missing or not in the slot the machine will think paper is in tray 1 and try to feed from tray 1. You can try changing the paper size setting for tray one to something other than the size in tray 2.
For example If tray 2 is set for 8.5x11 set tray 1 for legal.
The machine should then pull the correct size based on the print job.
Hope this helps
Jan 21, 2009 | HP LaserJet 5si Printer
Dell Laser Printer model 1700
Its caused by the rubber on the feeder wheels getting worn. And the fix is easy. Just peel the flat rubber rings off the rollers, flip them inside-out, and put them back on. Now your paper will feed all the way intot he machine. ( you can order replacements the next time)
Other: Dont use alcohol on these rubber parts, it only dries them out and makes it worse, you can wash them in soapy water though.
Use higher grade heavier paper, its a bit more expesnive but wont wear out your printer with jams and dust.
Most folks (including myself) think the rollers are actuated when printing, actually the paper tray causes the rollers to pop down onto the paper stack when you close the tray all the way. you cant see it, its like trying to watch the refrigerator light go off when you close the door! :)
Sep 20, 2008 | Dell 1700n Laser Printer
Primera Technology Autoprinter, Bravo Se, 100-240VAC, InkJet Logo
Top Primera Technology Office Equipment & Supplies Experts
Josh Whitehead
Josh Whitehead
Guy Loeffler
Guy Loeffler
Level 1 Expert
Martyn01202
Martyn01202
Are you a Primera Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
