Question about Belkin Basic Wireless N150 USB Adapter
Signal strength went from Good to Low
My connection strength to the internet is low
  • Belkin Master
  • 3,320 Answers
Either move the computer closer to the router or the router closer to the computer. You could also try connecting the usb adapter to a usb hub to remove any interference from the computer.
Posted on Mar 21, 2014
2 Suggested Answers
  • 84 Answers
SOURCE: wont connect to internet
Secure is not there to re-assure you, its telling you the network is password protected & you need the password to connect. The wireless key will appear on the staus screen of your router. Connect using a wire, goto the router status screen & write down the wireless key, try to re-connect wirelessly.
Posted on Apr 04, 2010
Irulu 7" tablet keeps disconnecting from internet. It's connect for a minute or so and then just drops. Just received replacements for 2 in the mail yesterday. No connection problems with old ones.
How many 'bars' are showing on wi-fi signal strength indicator (presuming you are using wi-fi for internet access)? If the signal strength is low, you could be losing connections that way, or there might be interference on the wi-fi channel that the tablet is using. Try changing channels in your wi-fi setup and see if there is an improvement in the behavior.
Feb 07, 2015 | Tablets & eReaders
WHY DO I LOSE MY CONNECTION TO THE NET WITH MY CELL-C HUAWEI E1752 3G USB INTERNET STICK BEFORE MY ACTIVE DATA BUNDLE HAS DEPLETED?
If the device has worked for you in other locations, the most likely answer is that you have low signal strength from your network carrier to your device. To test if low signal strength is the problem, try moving your laptop to another location, closer to the cell tower you think might be servicing you to see if it starts working. If your laptop connect software has the ability to show you the signal strength, look to see how many dBm the signal strength is. The larger the negative number, the worse it it. Below -85 dBM, you will have frequent drop outs.
-75 to -80 dBm should give you usable results. -65 dBM and lower should give you very good results. If you can only find the strength in bars, 1 or 2 bars is bad, 3 bars marginal, 4 & 5 bars useful to good. You can buy repeater devices which pick up cell signals and rebroadcast them, making them stronger for you laptop to pick up the cell signal. They usually have an external antenna port which you can put outside and high to help pull in the signal. Trees, hills, and rain all block and lower the signal strength between you and the cell tower. Distance is also a big factor.
Jan 06, 2015 | T-Mobile Huawei T-Mobile Webconnect USB...
Internet keeps dropping
check your router signal strength ,if it is low then it can drop internet connection..
you can try to reboot..its a good option....:))
if everything fail then try to connect using cable and ping with proper IP address and check router signal strength .......
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Nov 29, 2012 | Linksys Wireless-G WRT54G Router
Why is my signal stength very low?
Sounds like you need a new wireless card in the one that shows low signal strength. You can buy a good usb wireless card that gets a great signal for less than $30.00
Mar 26, 2012 | HEWLETT-PACKARD Pavilion p7 Quad PC 25 GHz...
My signal strength is very low
You Can Try Changing the Wireless Channel on the Router you have 11 Different Channels Available.
> Steps to change the Channel
- Open Internet Browser on Hard wired computer & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Click on Channel & Ssid
- Leave the Password Blank Click on Submit
- Change the Wireless Channel To Number 1 or 6 or 11.
- Click on Submit
- Check the Signal Strength
- If you Still Have Low Signal Strength you Can Try Updating the Firmware or Changing the Wireless Mode to G only... :)
Mar 06, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have had a LinkSys WAP54G wireless router for 1 month The signal strength has always indicated very low. Is there anything I should /could do to improve this. Interestingly the other wireless...
HI, If its a Internet link which u are speaking about, Please connect the LAN to the System with LAN wire and check the speed. the Problem will be due to low connectivity issue. Wireless router will not increase the bandwidth, it can able to provide the same or below the bandwidth which it received from the ISP.
Mar 01, 2011 | Linksys WAP54G (WAP54G-UK) 802.11b/g...
I have the belkin router in my home and one of my laptops are not picking up the signal for the router
Probably the Router signal strength is low.
You need to open the EWS page ( Router configuration page ) and increase the signal strength to 11 ( it must be Auto or 1,2,3, etc )
EWS Page ( Router page ) can be opened using the Router IP Address which may be 192.168.1.1 or if you know it. Open Internet Explorer and enter the ip address and hit enter ( without www or .com )
Under Wireless configuration or settings you will find the Channel Strength. You need to restart your Laptop to get connected again to the network after saving the settings are you will loose the internet connection.
Regards,
Shawn
Feb 01, 2011 | Acer Computers & Internet
Most of the channels breaking up despite auto retuning
could be one of a few things,
low signal strength, aerial out of line with transmitter.
bad coax connections losing signal strength.
coax broken inside, or old and not low loss.
Get the aerial checked for direction, half a degree out of line over a few miles and you will lose a lot of signal strength, as will old coax (aerial cable) and if you are using an unshielded coax you could be losing signal strength through the cable itself. Replace the connecters and try to use a straight run of cable instead of having joins in it as these joins, even if using connecters, will cause a weak signal. If yiu are running more than one tv off your aerial, invest in a booster.
Feb 06, 2010 | LG 32LG30 32 in. LCD HDTV
Wireless Network Connection constantly reading low/vlow/no signal
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply).
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Jan 04, 2010 | Computers & Internet
Problems connecting remote net connection.
It sounds as if your signal strength is too low for the laptop to make a solid connection with the router. The further away you get from the router, the lower the signal gets. Any problems connecting to other access points? Places with free wi-fi like some fast food restaurants, books stores, etc? You may need to get a new router with a stronger signal strength.
Mar 23, 2009 | NetGear RangeMax WPN824 Router
Belkin Basic Wireless N150 USB Adapter Logo
55 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
