Question about Ovens
Will the oven work without the broiler attached
We have a Kenmore electric range. The broiler started on its own and would not turn off except at breaker. Will the oven work without the broiler element?
    Prodigy:
    An expert who has answered 500 questions.
  • Ovens Expert
  • 650 Answers
You could use the oven without the broiler. It is customary that the oven will use the broil element to even out the heat in the oven for better baking but you could use if. it just may not bake evenly. There could be two things that is causing the broil element to stay energized. the control is not shutting down or there is a short to ground in the broil element. Have the broil element tested, it could just need replacing. If it is in the control that is a bigger problem.
Posted on Mar 29, 2014
SOURCE: Heating Elements for oven and broiler do not heat
There is four crimp connectors on the inside at the element. They can go open circuit. I would check them. There is an interna thermal fuse, when the element blows that usually goes too. Good luck
Posted on Jun 16, 2007
  • 530 Answers
SOURCE: Broiler turning on-Kenmore Electric Range Model# 66595781000
i would say you have a bad board
Posted on Sep 15, 2009
  • 127 Answers
SOURCE: kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Posted on Oct 25, 2009
barkencoa
  • 3463 Answers
SOURCE: I turned on my oven on my Frigidaire Range and
To be certain the elements are o/k you need to test them with a meter. I suspect one of them has failed.
You normally cannot always tell if they are o/k simply by looking at them.
Hope this helps.
Posted on Jan 11, 2010
heatman101
  • 43501 Answers
SOURCE: Kenmore electric range oven wont turn off error
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
heatman101
Posted on Apr 26, 2010
Kenmore range 8274197
The oven will not shut off, had to turn the breaker off . The upper heating elements appear to be working.
Mar 24, 2012 | Kenmore Ovens
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
ELECTRIC OVEN THE RANGE WORKS BUT THE OVEN AND BROILER WILL NOT WORK
Without a proper model number I would say you need to replace the electronic clock/timer control. It could also be a relay power board in the back of the range if it has one. beast to call a reliable repair company such as sears.
Jan 31, 2010 | Magic Chef 9815 Electric Single Oven
Kenmore oven will not turn off
yes sounds like your bake/broiler relay is sticking closed. this could possibly be a $400.00 repair. look in your owners manuel sometimes they give extended warrenties in there. so all you would be responible for is the labor. let me know how it goes.
Jun 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Electric Range both oven and broiler stop working
Check the breaker first, then the wiring in the back from the receptacle to the oven. Check to see if the wires in the plug are secure. Then look in the back side of the oven and you will find the wires attached to a connection box. This is where you should find your problem. If not here, your board could be bad. The replacement board is not that expensive. I really think the wiring is the problem since you have neither the top nor the oven working.
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Roper drop in range broiler will not light
YOU HAVE A SHORT ON THE BROIL CIRCUIT PROBABLY ON THE ELEMENT IT IS ELECTRIC CORRECT?
Jan 07, 2009 | Ovens
My Kenmore Electric oven quit working.
PUT POOP ON THE WHATYAMACLIT AND SEE WHAT HAPPENS
Dec 28, 2008 | Ovens
Ovens Logo
136 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
