Question about 2006 to 2007 Ford Freestar Tire Pressure Monitor Sensor Assembly SE
I have a 2006 Ford Freestar SE minivan. When I try to set the dimmer switch to bright, the headlights turn off. They do however stay on as long as the dimmer switch is set to dim.
The headlights only work on dim. when you try to set the dimmer switch to bright, they turn completely off. When you pull the dimmer switch again, located on the steering column on the left side of the steering wheel, setting the lights back to dim, they come back on.
    Top Expert:
  • AM Auto Parts Master
  • 44,148 Answers
What you are referring to is the beam selector switch, i.e., low beam vs high beam. The headlight switch on the dash turns on the headlights set to low beam. Pulling the steering column lever toward you flashes the high beams; pushing the lever away from you turns on steady high beams. From your description, I believe you do not understand the function of the beam selector switch.
Posted on Mar 19, 2014
My headlights are very dim when on dim.
If you had the wrong fuse, the fuse would blow.
Chances are its a bad connection somewhere, like the dimmer switch. You could test the power and ground at each headlight to verify.
Feb 23, 2014 | 2006 Ford Freestar
My headlights wont work
I don't believe there is a fuse. There is a circuit breaker built into the headlight switch. If you are sure the headlight switch is good, it could be a bad dimmer switch. If you have a voltmeter, with the headlight switch turned on, a larger yellow wire going from the headlight switch to the dimmer switch should be a hot wire. The dimmer switch sends power on a tan wire to the low beams, and through a light green wire to the high beam bulbs.
If your high beam indicator on the dash also doesn't work, then it is likely one of those switches. A voltmeter or test light would need to be used to find which one is bad. If you can find the connector at the steering column going to the dimmer switch, pull it apart and check for power on the yellow wire coming from the headlight switch, with the headlight switch turned on. If no power, the headlight switch is bad. If there is power there, then the dimmer switch must be bad.
Jan 21, 2014 | 1993 Oldsmobile Cutlass Ciera
Ford freestar
Suddenly the fans stayed on and the weather does not work, it's hot or cold
My freestar 2006 , help me please .
thanks
josue
Sep 24, 2013 | 2004 Ford Freestar
Hello, just recently started having a problem with my 98 grand prix gt headlights... while im driving at night my headlights will shut off and start to flicker after about 10 minutes of driving... if i...
COULD BE FAULTY DRL HEAD LIGHT RELAYS OR FAULTY DIMMER SWITCH.SINCE HEADLIGHTS TURN ON AUTOMATIC.TRY USING MANUAL HEAD LIGHT SWITCH ON TURN SIGNAL SWITCH LEVER SEE IF HEADLIGHTS STAY ON IF LIGHTS STAYS ON YOU HAVE FAULTY DRL HEADLIGHT RELAY.IF LIGHTS STILL FLICKER OFF.YOU HAVE BAD DIMMER SWITCH.
Jun 09, 2011 | 2006 Pontiac Grand Prix
I have a 2005 Ford Freestar SE Minivan and cannot get high beam headlights to work. Have replaced bulbs, fuses are intact. When I switch to highbeams, the headlights go out completely. Low beams work...
AT FUSE TERMINAL #45 TO THE RIGHT OF THE HIGH BEAM RELAY AS YOU ARE LOOKING INTO THE ENGINE COMPARTMENT FROM THE FRONT OF THE VEHICLE. THERE IS A 15 AMP FUSE, PULL IT AND SEE IF IT IS BAD. IF IT IS REPLACE IT. THIS IS THE FUSE FOR THE HIGH BEAM RELAY.
Sep 14, 2010 | 2006 Ford Freestar
I have a 2001 Ford Escape , when you turn the headlights on only the Brights work . The Bright light indicated light on the dash stays on all the time . Its like the dimmer switch is stuck on high . Dave
Headlight Switch....or some call dimmer switch...you must remove steering wheel to complete job....part is around $110 at Autozone or Advance
Apr 17, 2010 | 2001 Ford Escape
2006 to 2007 Ford Freestar Tire Pressure Monitor Sensor Assembly SE Logo
81 people viewed this question
Top AM Auto Parts Vehicle Parts & Accessories Experts
geo marin
terry stevens
ray gallant
Are you an AM Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
