Question about Klipsch Gallery G-17 Air Speaker for AirPlay
Only shows red light
When i turn klipsch on only red light shows
Red light = need to recharge battery with USB PLUG; unfortunately mine has same issue: plug is damaged.... unable to repair
Posted on Aug 23, 2015
  • Klipsch Master
  • 3,320 Answers
Posted on Apr 08, 2014
Technics SU-G91... clipped out @ high volume. Disassembled, sleaned and applied new grease to heat sinks. Amp worked great for a while, clipped out and now occasionally will not light up the front dis
First off, why do you drive the amp into clipping? It's not good for amp, nor your Klipsch. We won't even mention the terrible load that Klipsch in parallel presents to your amplifier, nor the distortion. I would suggest to you, that the amp goes into thermal overload. Trying turning it down by 20-30db, and see if it stays on-line. It can be fixed, if turning it down doesn't help, it can be repaired, but not inexpensively.
Nov 27, 2014 | Technics Audio Players & Recorders
How do I program the jamo torsten sound bar to my remote control?
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
Apr 28, 2014 | Jamo Torsten Soundbar with 10" Wireless...
Asko repair melbourne
it's more likely the amp, which klipsch provides as a complete unit.
Apr 08, 2014 | Klipsch Audio Players & Recorders
Klipsch sw 350 subwoofer not working in auto on off position
The audio signal on the subwoofer output of your amplifier turns on the subwoofer after a brief delay to prevent "popping". Sometimes you have to crank up the gain to turn on the sub, then turn it down to a comfortable level. If this approach does not produce results, there may have been a component failure in the input circuit.
Jan 14, 2014 | Klipsch SW-350 Subwoofer Speaker
Klipsch Synergy Sub12 Subwoofer Speaker
If it's a new model you should send it back.
If it's not then it sounds like the thing that does all the work has gone. It will be found on a heat sink. Try replacing that.
Jan 25, 2013 | Klipsch Synergy Sub12 Subwoofer Speaker
My klipsch sw112 sub stop working and know when i turn it on it just makes a clicking sound the led light flashes on and off
The sub amplifier circuit is probably damaged and the protection circuit takes over. Have a qualified electronics technician take a look at it.
Oct 13, 2012 | Klipsch SW-112 Speaker
Klipsch cs500 will not power up
I have klipsch Cs500 has a problem it turn on the green light but screen not on it no sound come out
Aug 25, 2012 | Klipsch Audio Players & Recorders
Klipsch cs-700
my klipsch cs 700 subwoofer not work
Jul 19, 2012 | Klipsch Audio Players & Recorders
Klipsch Lightspeaker 5.2 One speaker will no longer communicate with base.
Hello Beerisfood,We are the Canadian distributor of the LightSpeaker. Sometimes very rarely the LightSpeaker may "un-pair" and "re-pairing" the unit to the base is needed. It takes under 10 sec and is very easy to do but must be performed in a specific manner. 1. Power to the LightSpeaker must be off.2. Turn on transmitter (base) 3. Press the "pairing" button on the transmitter (base)
-lights will flash on the transmitter, during that time that they flash, turn power "on" to the LightSpeaker. The light on the LightSpeaker should now be green.
Youtube has a great video as well on pairing. Type Klipsch LightSpeaker and the first video should walk you through the process. If that does not work contact www.lightspeaker.net as they are the manufacture of this product.(Klipsch was just the US distributor not the manufacture)
Hope that helps.
Jun 02, 2012 | Klipsch Lightspeaker 5.2.0 Wireless Sound...
Klipsch Gallery G-17 Air Speaker for AirPlay Logo
445 people viewed this question
Top Klipsch Audio Players & Recorders Experts
rhodesworks
Tom Chichester
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
