Question about Chevrolet Silverado 1500 14655-92 Tonneau Cover Tuff Tonno
Wont turn over
I have a 1992 silverado 1500 wwith a 350 it was running i shut it off now it wont even turn over
    Sergeant:
  • 361 Answers
#1 battery condition , wire connections , 12 volts to the ignition switch , all dash lights coming on ? if so then make sure you are getting power to the solenoid switch ck with text light , ck power 12 volts again at the battery side of the starter with test light or voltage test .I also think that power goes through the alternator to power the starter this is in older trucks but ck sounds like you are not getting power but must be more specific on the issues ,hope this help,
Posted on Mar 19, 2014
My2002 sierra with a4.8 with a good battery, all my dash lights and cd player come on but the truck doesnt turn over right away sometimes it takes 5-10 minutes 2 start of repetitively turning key over
battrey is good but truck makes no sound and wont even click
www.cargurus.com > Questions > Chevrolet > S-10
CarGurusbattrey is good but truck makes no sound and wont even click ... Asked by Jennifer May 15, 2013 at 03:21 PM about the 2002 ... quite obviously the amps aren't getting through~ how do you know the battery is "good". the date ... If it turns over your power and starter are good but the ignition circuit ... Used GMC Sierra 1500".Missing: a4
Intermittant Failure to Start : Chevrolet Silverado 1500 ...
repairpal.com > Problems > Chevrolet > Silverado 1500
first start engine turns over alot. 2000 Chevrolet Silverado 1500. Hard start. When starting my truck it often takes two or three attempts. It kicks over but does not ...Missing: a4
Chevy Silverado and GMC Sierra Starting Problems - Car Forums at ...
forums.edmunds.com > Chevrolet > Chevrolet Silverado 1500
Oct 20, 2008 - 30 posts - ‎19 authors
i got a 2001 silverado 1500 and it wont start it turns over and fires and .... Put the key in and the truck barely starts due to the battery being weak. .... If it was really 8, the lights would be dim? .... I have a 2002 GMC Sierra 4.3L 2WD. ... I bled the fuel filter looking for air, but good fuel came out the top bleede ...Missing: a4
Jan 01, 2016 | 2002 GMC Sierra 1500
Why won't blower shut off?
03 - 06 Silverado/Sierra blower stays on with key off (how to ...
? 1:32
https://www.youtube.com/watch?v=PkltkvLDhIg
Apr 7, 2014 - Uploaded by MAY03LT
The HVAC blower in this 2003 Silverado stays on speed 5 even with the key off. Here's how to turn speed 5 of the blower off(while keeping speeds 1-4) and ho. ... How to replace blowermotor resistor in Chevrolet Silverado - Duration: 5:06. ... 2004Tahoe rear brake service (replace pads, clean/lube slides, ...
Blower motor won't shut off. - Diesel Place : Chevrolet and GMC ...
www.dieselplace.com/.../76.../208669-blower-motor-wont-shut-off.html
Jan 10, 2008 - 11 posts - ‎7 authors
I have read through many posts on blower motor issues but no one had the same issue I have. ... If I shut the truck off, it still won't shut off and runs until the battery is dead.... 2002 GMC Sierra RCLB 1500 4X4 SLE, 7 1/2' Fisher plow.
Question - Blower Motor Won't shut off ' Chevy Truck Forum ' GMC ...
www.gmfullsize.com > General > Maintenance
Dec 11, 2015 | 2004 Chevrolet Silverado 3500
2001 chevy silverado 1500 headlights wont shut off
You will have to have the dealer reset the security light to restart vehicle.Check all engine and chassie grounds because this is where the lighting would exit the vehicle.It sounds like a ground burnt through.
Jul 19, 2009 | 2001 Chevrolet Silverado 1500
92 350 chevy silverado 1500
Check the throthle positioner sensor, ignition timing, sparkplugs.
Jul 18, 2009 | 1992 Chevrolet K1500
1997 chevy silverado 1500 350 vortech, new fule pump not working
before you drop tank again, check fuses & relay.then disconnect fuel line @ filter turn key to on position should hear fuel pump run and get gas stream out of line. if no flow from line new pump faulty be sure & remove negative battery cable first good luck.
Jun 04, 2009 | 1999 Chevrolet Silverado 1500
Hi I have a 1992 silverado with a 350,hard to start.
When it runs really rough is there alot of black smoke? Could be the fuel pressure regulator diaphram, real easy to change on that TBI...
Mar 22, 2009 | 1992 Chevrolet K1500
Chevrolet Silverado 1500 14655-92 Tonneau Cover Tuff Tonno Logo
42 people viewed this question
Top Extang Vehicle Parts & Accessories Experts
Frank Magliocca
Are you an Extang Vehicle Part and Accessory Expert? Answer questions, earn points and help others
