Question about Sony "KLV-40BX400 40"" 1080p Multi-System BRAVIA HD LCD TV"
Hello,my Sony Bravia HD TV (LED & LCD) we suspect that it was struck by lightning,but my other appliances connected on the same power cord as my tv are working fine,so i'm confused..
Red power led of the tv doesn't switch on when i plug it in the power cord
    Genius:
  • Sony Master
  • 1,039 Answers
The power surge from lightening can come in thru the antenna or cable box. Also just the proximity of lightening can damage one item and not another. An ic chip can be destroyed from the charge in the air.Likely took out power and main brd both.
Posted on Mar 19, 2014
mistersony
  • 320 Answers
SOURCE: SONY 62 LCD GRAND VEGA HD TV
A three flash means you have not seated the lamp cover correctly. Try recolsing and relatching the lamp cover
Posted on Dec 21, 2008
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
  • 1779 Answers
SOURCE: My LCD Sony HD tv turns off after few seconds.
You need the Inverter Board.
Posted on Sep 14, 2009
eagle338
  • 4889 Answers
SOURCE: sony bravia l42" LCD TV. No power. Green light on
7 blinks in the this series(KLV) means there is a short in the power supply board. The easiest way to fix this would be to swap out the board. I can find you a replacement if you want to try fixing this yourself.
Sai.
Posted on Dec 24, 2010
Kensolutions
  • 455 Answers
SOURCE: Sony Bravia KDL-42V4100 42 in.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Posted on Jul 17, 2011
Sony bravia klv40v300a lcd tv 6 time led bilink.what is the problem
It sound like it took a power surge. suggest you either have it serviced or replaced the tv itself. Frankly if it is not under warrenty then it is time to purchase a brand new tv.
Feb 20, 2015 | Sony KLV-40V300A Multi-System BRAVIA LCD...
Bought sony bravia 6 37" lcd hd tv 2 yrs ago +$1,500 when picture went dark, then out; srvc repair diagntc $75+tx. Now, we hv audio but only one channel wh cannot be seen & remot doesn't work. Were...
1,If you still have the old tv, reconnect.
2 turn on power after connecting cables making sure audio goes into ado and video into video.- very important.
3. do you get the pic, and sound?
4 if you do, do the settings to your choice.
will talk about new if the old does not work, good luck lindamilo.
Dec 25, 2013 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Lightning struck my Bravia
your tv is shot ,im sorry to say that but its burnt
Jul 29, 2012 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Sony "KLV-40BX400 40"" 1080p Multi-System BRAVIA HD LCD TV" Logo
135 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
