Question about Garden
Why would my 2007 troybilt mustang rzt 50 in leaving grass behind? I replaced belts and blades
  • Garden Master
  • 2,478 Answers
Happen to me. Belt slipping.
Posted on Mar 20, 2014
  • 109 Answers
SOURCE: blades are engaged,but won't cut the grass
Check the blades to make sure that they are not upside down
Posted on Apr 24, 2009
  • 86 Answers
SOURCE: Blades do not spin fast enough to cut grass
If you got the right oem belt,ta\han you can look at the end where the cable attachs to spring and you should see a double nut adjustment loosen nuts and adjust to put more tension on the belt when you put lever into gear for blades to turn then retighten them .
Posted on May 11, 2009
  • 125 Answers
SOURCE: A row of uncut grass left between blaces when mowing
Mowing too fast for the blade speed. Use higher engine speed or lower gear.
One or both blades too short?
Posted on Jun 16, 2009
SOURCE: Airens Zoom 1944 ZTR Blades Slow Down In Bahaia Grass
You mention many PM issues but do not mention a blade sharpening. I don't get on my ZTR without a freshly honed blade installed. "That's" what cuts bahia grass...the blade. You can put all the horsepower you want behind the lade but if you're trying to cut grass with a 2X4 it rips more than cuts grass.
Posted on Oct 21, 2009
  • 10865 Answers
SOURCE: cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
Posted on May 28, 2010
I replaced drive belt on troybilt mustang rzt shortly after electric pto clutch stopped engaging
Moist likely you failed to reinstall PTO clutch correctly as it sound the anti-rotation device wasn't installed. When you started the engine it would spun pulling the wiring apart. Hopefully just connector came part; otherwise, you might need to purchase a new PTO clutch assembly.
May 12, 2015 | Mustang Garden
Why when riding along mowing and the blades just quit turning, belt is not off?
If you hit a bump too hard, I believe it's equipped with a shock sensor that shuts down the blades or if you slightly lift off the seat the blades will shut off. If this is the case simply stop and restart the blade switch. Hope this helps
Jun 08, 2014 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cable that operates the auger broke troybilt storm 8520 snon blower
Any authorized MTD, Troy-Bilt or Cub Cadet dealer can get you the new cable.
Nov 14, 2013 | Mustang Rzt 50" Zero Turn Riding Lawn...
Zero turn cub cadet mower, deck keeps clogging with grass
do you have the right blades for bagging ?is the deck belt slipping?
Apr 22, 2012 | Briggs & Stratton Garden
The mower is mowing uneven in the front. what can i do? it seems that it is scalping the grass but both sides are level
Look under the mower deck. If you can't see well and work on it, you may have to remove the mower deck and flip it over on the ground. Grass and mud buildup in the decj could cause a blade to pinch grass, 'scalping' the lawn. Clean it all out. Dull blades cause cut grass to look torn and brown. Remove and sharpen. Bent blade will cause uneven cut. Replace it. Good luck! Please rate if you found this helpful, thanks!
Jun 05, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cub cadet rzt 50, hit stump, blades wont engage but not bent
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
I HAVE A RZT TROYBILT 50'' ZERO TURN ONLY 13HRS..THE RIGHT REAR WONT MOVE..
Your machine has a warranty on it and in many cases if you attempt any unauthorized repairs, it will void your warranty.
My best advice it to first contact your dealer or an authorized service center regarding the problem and what you can do yourself without voiding the warranty
Oct 31, 2009 | Mustang Rzt 50" Zero Turn Riding Lawn...
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
