Question about Acer Aspire 5250 5252 5253 5333 5336 5552 5552g Left Speaker
Add audio input device on Acer aspire 5263 series
Add audio input recording device
  • Acer Master
  • 3,320 Answers
Acording to the data sheet there are a mic and line in ports on the laptop.
Posted on Apr 08, 2014
When i install application or games on my sony ericsson aino it display operation failed, how can i fix this?
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 4410
Jul 10, 2013 | Audio Players & Recorders
I have a Sony ICD-BX800 IC Recorder. I have purchased and hooked up the Audio Cable to transfer the recordings to my computer (I need to email them to someone.) However, I did a test recording, and the...
What you need:
Howto step by step:
- Audio Host: MME
- Sampling (Hz) set 44100
Dec 26, 2010 | Audio Players & Recorders
Ive been able to record and now i cant record bcuz the screen says "no inputs..." but i can hear music thru the inputs and the lexicon alpha is selected as the input and output sourc. whats wrong????
It sounds like you have NOT connected via the recording software.
It is like the normal Windows software audio has hijacked the audio system even though it is external.
Go into your recording software and look for an option to select the Lexicon device. You did not tell us what recording software you are using.
This is not an uncommon problem with these external audio recording devices.
Apr 14, 2010 | Lexicon Alpha Personal Recording Studio
I have a Realtek HD audio driver on my Windows XP Media Center Edition version 2002 with SP3. I can listen to anything online and offline but I can't record anything using my Wave Pad sound editor or...
Open your control panel.
Click on Sounds and Audio Devices with the control panel in classic mode.
Click on the Audio tab.
Is Realtek HD Audio Input Device listed as the default device under Sound recording?
If not, select that from the drop down list and click Apply/OK.
Mar 18, 2010 | Gateway Computers & Internet
How i can add an old turn table
you'll will need a peamp device to boost the audio level of the record changer. preamps are still available try radio shack, they use to have one for about 40dls, but connect the turntable to an available input, something you are not using(aux) run a test with a record, you should be able to listen to the record but with a very low audio level, if you don;t then forget about the preamp and you'll need a a/d conversion device.
Jan 12, 2010 | Televison & Video
Direct sound is not supported....
Follow these steps (Windows Vista):
Control Panel - Hardware and Sound - Sound - Manage Audio Devices - Record - Right click to show all the devices (including the deactivated ones) - Activate all the devices you can.
In Adobe Audition:
Edit - Audio Hardware Setup - Edit View - Control Panel button - Direct Sound Input Ports - Enable one device (default input will now show the device). Now you will be able to record sound.
Jul 24, 2008 | Adobe Audition 3 for PC (22011292)
Sound in one ear only
The Fastrack only has one audio input signal to the PC. You'll need to set your recording software to mono, then you can add stereo fx in your audio software.
Jun 06, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
Usb mic in cubase sx3
you have a pci audio card so maybe you can add an extra input device by going to devices panel or press F4 shortcut.
and choose your usb mic.
also you can check your wavelab audio inputs. they must have the same config so if you can record woth your usb mic and your poci card in wave lave you must be able to do so in cubase sx
hope it works
Apr 01, 2008 | Steinberg Cubase SX3 (502010600) for PC,...
Sound recording with external microphone
An instruction manual is available for download at www.canon.com
Your camera, according to the manual, has a single input for microphones, and in the internal menu, AUDIO DUB has to be set to MIC. IN. when using an add-on microphone. An MA-300 hot-shoe microphone accessory can be used, and then the input controls would be on this device, not the camera. Your camera can also record in two different audio qualities: 16-bit two channel or 12-bit four channel. If you are using an accessory you may need to select 12-bit in the internal setup menu in order to have enough channels to add on the additional microphone(s).
Finally, and hopefully not, the camera may have an internal hardware problem, and so would need to be serviced.
Nov 05, 2007 | Canon GL2 Mini DV Digital Camcorder
Acer Aspire 5250 5252 5253 5333 5336 5552 5552g Left Speaker Logo
48 people viewed this question
Top Acer Audio Players & Recorders Experts
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
