Question about Linksys Wireless-G WRT54G Router
Ip address My router wont accept the new ip address can you help me configure it?
    Sergeant:
    Novelist:
  • 143 Answers
Don't rate me PERIOD for saying this (Unless it helps... Let's work through this FIRST before any rating.)
...but...
Which IP is it that you're trying to configure? Is it the WAN IP or are you trying to change your LAN IP?
If it is the WAN IP, I would certainly recommend leaving that on automatic settings as most ISP's assign IP's dynamically and can change from time to time.
If it is the LAN IP... Are you also making sure that your network adapter on the system you're connected by is in the same IP range and Subnet Mask? (If the IP range of the network adapter is different than the IP range of the router's LAN IP, you won't get any throughput.)
Also... When you say "won't accept the new IP address", are you saying that the router is still responding...but is somehow REJECTING the IP that you're giving it?
You have got to give us more details here. Give us a breakdown of what you did that landed you in the current situation. We honestly can't help you much if you don't.
I'll be watching this thread for your reply. If you give more detail, I will continue to assist you.
Again... Do NOT rate me badly OR good until we resolve your issue.
Cyryl
Posted on Nov 04, 2007
    Scholar:
  • 193 Answers
The ip for the linksys is 192.168.1.1 user name - lower case admin
password lower case admin
rate me solved if its help full
Posted on Oct 30, 2007
How do I set up the ecb350 as a repeater. I have an xfinity wifi that doesn't reach the whole house but I can connect with an Ethernet cable to the back of the ECB350 out in the area I need wifi acce
What are you using for your main router (xfinity wifi)? The best way is to set the ecb350 in AP Router Mode not a repeater since you have a rj45 cable long enough to go from one of the ports on the xfinity wifi router and hook it into the ecb350. You will need to know what your ip address range is for example if the xfinity is 192.168.1.1 then you want to assign a static address for the ecb350 to be 192.168.1.100 (assigned IP Address) You will also need the Subnet mask, Default Gateway IP Address, and Primary DNS and Secondary DNS of the xfinity wifi router. Then on the ecb350 you will need to configure the following with the info you go off the xfinity router:
Static IP Internet Connection Type Select Static IP to begin configuration of the Static IP connection. Account Name Leave Blank Domain Name Leave Blank MTU Auto IP Address ie: 192.168.1.100 (assigned IP Address) IP Subnet Mask Specify the subnet mask of your Xfinity Router Gateway IP Address Specify the gateway of your Xfinity Router Primary DNS Specify the primary DNS server's IP address of your Xfinity Router Secondary DNS Specify the secondary DNS server's IP address of your Xfinity Router Discard Ping on WAN Check to Enable to recognize pings on the ECB350 WAN interface or Disable to block pings on the ECB350 WAN interface. Note: Pinging IP addresses is a common method used by hackers to test whether the IP address is valid. Blocking pings provides some extra security from hackers. Accept / Cancel Click Accept to confirm the changes or Cancel to cancel and return previous settings. Note: Clicking Accept does not apply the changes. To apply them, use Status > Save/Load Hope that this help you.
Sep 10, 2014 | EnGenius ECB350 Wireless-N Indoor...
How do i configure a wireless modem from static to dynamic IP addresses acceptance.
You Have not Mention What Wireless Router are you using, To set Dynamic IP you need to Enter inside the router Configuration Page. Your Router most have one Default IP address, user name and the password, by using any web browser and typing the default IP of the router on Address bar of web browser you can enter to its configuration page.
One You get in to Configuration Page you'll find Wireless setting, there you can Change it to Dynamic IP.
Aug 11, 2012 | Computers & Internet
I have loaded the install. disc on a pc with the new router connected I have given it a new name and password. My lap top will not accept the same IP address as the PC . Can you asist me?
There is no way for two computers to have the same ip addresses. Try to check that laptop's ip address by clicking on START then type CMD on the search bar which will pull up command prompt then type "ipconfig" press ENTER it will give you lists of addresses like ip address, default gateway, etc...
Now, if the ip address shows 169.254.X.X it means that it is not getting any signal OR worse case scenario is, the network card is defective BUT!! if your computer is getting an ip address other than 169.254.X.X then it means that it just needs a little configuration...
>hope it helps... ?
Sep 15, 2010 | Computers & Internet
Internet explorer connection
This problem could be due to your DNS settings or your IP Address. First of all you will have to configure your router to accept the new computer. To do this you will need to go in to the router in your browser window and add your new device.
Then you will need to configure your router to either automatically assign an IP Address or use an allocated IP Address and use the same setting on your new computer. Also, you will need to configure your router to either assign a DNS Server automatically or to use an allocated DNS Server and once again you will need to use the same settings on your new computer.
Your IP Address is crucial in order for your new computer to connect properly to your network. Your DNS Server is crucial in order for your new computer to access the internet through your network.
If you still have problems, please do not hesitate to contact me directly on Skype (Skype Username: fixya-support)
Thank you for using FixYa! Have a great New Year and please remember to rate this solution.
Warm regards,
BearWeb
Jan 09, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
I have dowloaded all the drivers ann i still can't connect to the internet
Warm regards,
BearWeb
Jan 01, 2010 | HP Pavilion dv9000z Notebook
I can't connect to the internet with my new computer. I bought a new computer. I can connect with my old computer but my new says limited connectivity. it is password protected and i entered the password...
Make sure your new computer is set to automaticly obtain ip settings.
If thats not the problem, I would turn off the wireless security for a moment and see if you can succesfully connect then.
Jan 01, 2010 | Blitzz Technology BWA711 (B3WL000900)...
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Trying to switch routers, can't get into new Netgear to configure
To configure it you can simply contect a pc to one of its rj45 port. it will give the pc an ip address in a default range. but the must have its network connection configured to receive ip automatically.
See the status of the pc LAN connection and note the gateway ip address. then type this ip in your explore address bar to access the configuration page / program of the router.
Hope that help.
Mar 16, 2009 | NetGear RangeMax WPN824 Wireless Router...
Configuring nbg334w router
To configure the wireless router it is recommended the it is connected directly to router.
Please follow these steps to fix your issue
1. Reset the router using reset button on the back of the NBG334W router
2. Configure or change the laptop ehternet adaptor setting to "Obtain IP address automatically.
3 connect laptop and router using ethernet cable. check the ip address using ipconfig command in DOS prompt. If IP address is 0.0.0.0 or 169.X..X..X run command
ipconfig /release
ipconfig/ renew
best way restart the computer
4. if you still have issue in getting ip address double check ethernet cable and try reseting the router again.
5. Still problem persist install new firmware on the router. you can download router firmware from
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420070320142921
Please vote if this information is helpful in resolving your issue
Dec 27, 2008 | Zyxel Prestige 334 Router
How do I set a new address in the 850 motorola router
First, you ned to login into your router (check the manuals for this, Netgear has this printed behind the router near Serial no. etc).
Enable DHCP settings, allocate IP-address range say 192.168.0.1 to 192.168.0.5 (enough for 5 computers connecting via this router). Next, configure each computer to accept new IP-address from router by enabling DHCP.
The settings on a Windows XP Professional Desktop:
Need administrator access to your desktop, right-click on Network icon, Internet Protocol TCP/IP Properties, click on Properties button, then select Advanced properties, you can set DHCP from here.
Dec 17, 2008 | Arris Wireless G Broadband Router (wr850g)
Linksys Wireless-G WRT54G Router Logo
50 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
