Question about Sony Ericsson Walkman® W995 Cell Phone
W995 replaced screen,keypad,flex then keys malfunctioning
So i replaced flex and screen and that solved my black screen problem but 5 and 8 werent working either so i changed keypad as well.Now the key bindings are messed up.Asterisk not working at all,OK big middle button sometimes works in some menus and sometimes it opens up the camera.Up is 7 and left 4,some keys are not registered at all and others are registered as others.You think its low-quality keypad or something i assembled wrong?
otacon
  • 1944 Answers
SOURCE: keypad wont work
Try reflashing/updating your phone's firmware/software.
http://www.sonyericsson.com/cws/support/products/updateservice/k850i?cc=gb&lc=en
Posted on May 05, 2008
  • 5 Answers
SOURCE: keypad not woking
u better remove ur panel & beside the keypad u ll get 1 white col key pad type plastic paper... u hav to replace tht.....
Posted on Mar 26, 2009
  • 11 Answers
SOURCE: Keypad on W960i not working:- The number 7 key broken
I fitted a new keypad on my 960i some time ago (funnily enough for the same reason - no.7 not working!) and I'm pretty sure you will find that when your new membrane arrives, it is a complete unit with buttons and contacts all enclosed together, connected to the phones' circuit by a ribbon with a tiny plug on the end.. hope this helps....
Posted on Nov 19, 2009
SOURCE: i have a sony w995 the keypad does not work correctly
I have exactly same problem. Did your issue solved?
Thanks and Regards,
Jay
Posted on Apr 26, 2010
SOURCE: Sony Ericsson w995. Some of the keys have stopped working, how
my sony ecrisson w995 fone keypad buttons have stopped working what can i does shall i get another fone var viewReq = new Array();function vu(u) {var i=new Image();i.src=u.replace("&","&");viewReq.push(i);} vu("http://googleads.g.doubleclick.net/pagead/adview?ai\x3dBa0txEq1BTbe8MoSa-Aa96OTDCM-1tesBl4qClxel7-_HBAAQARgBIAA4AVCAx-HEBGC7vqKD0AqCARdjYS1wdWItMzM4NDk0NjI4NTM1MTk1NqABx5L46gOyAQ13d3cuZml4eWEuY29tugEKMzAweDI1MF9hc8gBCdoBSmh0dHA6Ly93d3cuZml4eWEuY29tL3N1cHBvcnQvdDMxNTU4MzItc29ueV9lcmljc3Nvbl93OTk1X3NvbWVfa2V5c19zdG9wcGVkmAKWBqkCG-ZZ_-bCuj7AAgHIArG7vg3gAgDqAiA2MTUzL2ZpeC5lbGVjdHJvbmljcy9jZWxsX3Bob25lc6gDAegDhgPoA_4C6AMS9QMEAAAE4AQB\x26sigh\x3d7qaDCui8B2E") body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; }
Posted on Jan 27, 2011
White screen only with trying to open it..but there is a sound when your pressing the keypads.
Hi,when a cell phone has a white screen display, it's occurs when the screen of the cell phone damaged..
Symptoms are that the cell phone screen will be white and you will able to recieve incoming calls, do some operations on your phone, but you will unable to view anything your doing on your cell phone.
You will need to replace the screen of the cell phone...
Also there are two models of 6600..
The 6600 slide and
the 6600 fold.
If it's the slide of the 6600 cell phone, that means you will need to replace the flex of the cell phone..
There is a common fault for all Nokia slide cell phones.There is a thread like object inside the phone called a flex that controls the functions on the keys on a cell phone when it's gets damaged, it makes the keys to malfunction. You will need to replace the thread like object which is the flex inside the phone for the keys to function again.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
You can use the below links for disassembling cell phone..
http://www.formymobile.co.uk/6600slidedisassembly.php
and
http://www.formymobile.co.uk/6600folddisassembly.php
Hope it helps.
Thanks for using fixya...
May 30, 2011 | Nokia 6600
Tip
How to repair keypad problem in China Mobile
First we need to know china phone keypad connected with PCB how way
(A) Direct on PCB
(B) Flex System (flex cable direct soldering pcb to keypad panel)
© Flex and socket system include (flex one side soldering with key panel other side connect to pcb with socket)
(D) only Socket System (here have 2 socket, 1 with key panel others with pcb)
Keypad problem have various type
1. All key not work.
2. some key work and some other not work.
3. sometimes work and sometimes not work.
1. All key not work
china phone all key not work for this type of problem
(A) though its touch screen phone, first try to disconnect touch panel line from phone pcb or display flex (4 line)
(B) though not solve and keypad direct on pcb first you try to good clean full pcb with cleaner.
© though not solve now you try to format/flash your phone because some time key problem come from software problem.
(D) though still not solve now you check must be CPU. 95% china phone keypad directly going in cpu. and other 5% first going to resistor or capacitor near the cpu or keypad than going to cpu. so now first check them than you can try to re-hot, re-soldering or changing cpu.
(E) though its flex or socket system, first check GND connection continuslay pcb to key panel. next check full flex or socket all line going continuously pcb to key panel or not. also sometimes flex or socket shorted with other line or gnd so check also them.
(F) Also you can check all key anyone is short 2 line.
(G) sometimes keypad line broken from cpu pin on pcb to key panel, so check them.
2. Some key work and some other not work
Some key work and some other is not work for this type of problem
(A) maximum time this problem we face for flex or socket system keypad. so check flex cable and socket all line any line is broken or not and though need change them. and check all key connection on key panel.
(B) though its direact on pcb, some of key line broken internaly. and maximum china phone have alternative test point near every key or with other key on keypad. so check them with multimeter and though need connect to not work key with near testpoint or other working key.
© common problem is keypad metal ball (which is short 2 line on key when we press) sometimes its damage for phone water damage or over key voltage, so clean them or change.
(D) also try to check line continuously from cpu to not working key.
this problem come from this defect
(A) flex or socket system keypad any line is bad soldering or do lose contact. check them and
re-soldering or keep there line join with extra ware.
(B) for cpu bad soldering or cpu pin is broken. so re-hot or re-ball cpu.
on Jan 06, 2010 | Cell Phones
My phone display blink
Hi, samsung phones with blinking display is usually caused by the flex of the cell phone,.
It can be fixed.There is a common fault for all Samsung cell phones. there is a thread like object inside the phone called a flex that controls the functions on the keys on a cell phone when it's gets damaged, it makes the keys to malfunction. You will need to replace the thread like object which is the flex inside the phone for the keys to function again.
Hope it helps.
May 25, 2011 | Samsung Star GT-S5233 Cell Phone
My droid 2 screen goes black when some calls i cant answer it at all i have to take battery of the back to stop it from ringing
Hi, It can be fixed.There is a common fault for all Motorola cell phones. there is a thread like object inside the phone called a flex that controls the functions on the keys on a cell phone when it's gets damaged, it makes the keys to malfunction. You will need to replace the thread like object which is the flex inside the phone for the keys to function again.
Hope it helps.
May 24, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
MOTOROLA DROID SCREEN IS BLACK BUT IT IS ON
Hi, no need to get a new phone, It can be fixed.
There is a common fault for all MOTOROLA DROID cell phones. there is a thread like object inside the phone called a flex that controls the functions on the keys on a cell phone when it's gets damaged, it makes the keys to malfunction .That's what makes the screen to go black.
Hope it helps.
Mar 12, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
My phone turns on but nothing comes up on the screen at all, its just black, i can still do things like get into the music so the phone is still working, but the sreen (display) is just black, i think i...
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Aug 04, 2010 | Sony Ericsson Walkman® W995 Cell Phone
Keypad problem
the most common problem in nokia 2600c and 2630 is keypad { navigator keys not working } while u alredy replaced key pad ic,here is final solution ,just chk tracks as given pic ,if not solve just reball cpu ,100% ,solution for navigator keys{ menu keys}
i have already solve this problems
here is new link for image
http://rapidshare.com/files/143053547/2630keypadwayno9.rar
Mar 03, 2010 | Sony Ericsson Walkman® W995 Cell Phone
Samsung x300 key pad problem
if key pads malfunctioning .....first try to clean the ksypads.. if no work, replaced the key pad flex of the unit.....
Feb 25, 2008 | Samsung SGH-X300 Cellular Phone
Sony Ericsson Walkman® W995 Cell Phone Logo
60 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
