Question about Chaney Clock 50314 Balmoral Antique Copper Atomix Atomic Wall Clock
How do you set an Atomix analog clock?
My Atomix analog clock does not seem to be responding to WWVB. It has a blue button on the back. What does it do?
Cannot set time
WWVB Radio Controlled Clocks
www.nist.gov/.../radioclo...
National Institute of Standards and TechnologyFeb 11, 2010 - To find out more about WWVB radio controlled clocks, please ... Before it does so, it applies a time zone correction, based on the time zone setting that you ...your radio controlled clock, but we cannot provide technical support ...
[PDF]FM/AM Clock Radio - Sony
https://docs.sony.com/release/ICFC218_US.pdf Sony CorporationAutomatic time set - When you plug the clock in ... The radio or buzzer alarm does not sound at the ..... The alarm time setting cannot be changed if ALARM.
[PDF]Atomic Analog Wall Clock - La Crosse Technology
https://www.lacrossetechnology.com/.../Generic_Headway_Manual_050...
clock is synchronizing to the WWVB signal and once the radio signal is decoded, the hands will ... trouble free. If the clock receives a clear time signal, it will set itself perfectly. ... A: No, the clock cannot work with a booster antenna. Opening the ...
ICF-218 Sony Alarm Clock - YouTube
? 1:50
https://www.youtube.com/watch?v=XTQ8zEMMNq8
Aug 4, 2012 - Uploaded by sohvintage
Jan 10, 2016 | Audio Players & Recorders
Have lost instructions for lidl radio controlled clock and it has not reset hour back
Hello
You haven't given any details about your clock, ie, its Model number, brand name etc. Yet I posts this solution, as these are the genteral proceedings to reset a radio clontrolled clock.
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time. OK.
Oct 31, 2011 | Audio Players & Recorders
Hot to set tide clock
Hello
Oct 29, 2011 | Seth Thomas Radio-Controlled Howard Wall...
After replacing the batteries in both the clock and the outside unit, everything is perfect except I cannot get the clock to allow me to change to Central Standard Time. Have followed instructions...
Hello
After replacing the batteries do the following to set the time.
OK.
Aug 25, 2011 | La Crosse Radio Controlled Atomic Clock
I am having trouble setting the alarm on my clock, it has options mode, max/min, up down and snooze. i am not sure how to set i , can you help?
Hello
OK.
Aug 10, 2011 | La Crosse Radio Controlled Atomic Clock
Clock will not stop rotating for outside temperature
Hello
Just set your clock once more and see whether it helps you. To set it, do the following:-
OK.
Aug 07, 2011 | La Crosse Radio Controlled Atomic Clock
My La Crosse Radio controled atomic clock is spinning for the last two days, How can this be corrected? I have a secound Clock same modle it is working fine. Modle# wt-3102
Hello
Ok.
Jul 31, 2011 | La Crosse Radio Controlled Atomic Clock
The clock stopped, I replaced the battery but it does nor reset itself it keeps going
Hello
This is the setting proceedings for you Atomic clock. Follow this.
OK.
Jul 09, 2011 | La Crosse Radio Controlled Atomic Clock
We have had no problems in the 3-4 years we owned the clock, however recently it stopped, I replaced the battery now it continues to revolve and does not reset itself. I have pushed the reset button and ET...
Hello
After replacing the bettery you have to setup your clock. I'll give details how to stup it.
OK.
Jul 03, 2011 | La Crosse Radio Controlled Atomic Clock
We have lost the instructions on how to check for the radio signal (WWVB) on our ACRU RITE wall clock. product description is AcuRite Atomix Clock & Thermometer, Antique Copper, 17.75''
You may need to move the clock to a different location in order to receive the signal, and you may even need to place it outside overnight to find the signal. This link will take you to the instructions for a similar model:
http://www.lacrossetechnology.com/8117cit/manual.pdf
Bill B
Apr 02, 2010 | SkyScan 86742 Digital Atomic Wall Clock
Chaney Clock 50314 Balmoral Antique Copper Atomix Atomic Wall Clock Logo
141 people viewed this question
Top Chaney Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Chaney Measuring Tool and Sensor Expert? Answer questions, earn points and help others
