Question about LG LHD45EL Dehumidifier
How does it work what do I do to operate it
How do I opate this
  • LG Master
  • 3,368 Answers
Read the instruction manual and then after you understand that turn it on and set it accordingly. 35% for the humiodity might be a good starting pint.
It has a refrigeration system that blows room air across the evaporator coil then across the condenser coil. The evaporate coil gets cold causing moisture to condense and eventually drip into a collection device.
Posted on May 01, 2014
Goldair dehumidifier GD-2020 has stopped working? 'CONT' light on front panel flashing and now cannot get to operate?
cont button just means continuous run mode . the power light is lit , the full light is out . try reseating the water catch bucket a few times , most machines have a safety that wont allow the thing to operate if bucket isn't just perfect in its slot (you don't want water on your floor )
May 23, 2015 | Dehumidifiers
There is no water going in the container can you Tell me why this is
some reasons i can think of are
(1) operator not famliar with operation of dehumidifier , Ie controls not set properly or interlocks not made on bucket full switch , just because you hear a fan running doesnt mean it's working
(2) unit defective , or etrreemly dirty inside filters never cleaned in its lifetime
(3) operator askin machine to remove too much moisture from air than it can so now room has no excess moisture to "give up" settings less than 53% rh could cause this problem , this of course is precusor to unit works very well at first then sort of tails off days later
Feb 11, 2015 | Dehumidifiers
Why did my dehumidifier suddenly stop dehumidifying, fan works fine
check that the tank isn't full or the outlet hose is not blocked. Remove the filters and clean if required.
Jul 27, 2014 | Fedders A7DH45B2A Dehumidifier
Why wont this unit operate I just purchased this unit and it will not turn on. I tried and seated the bucket and air filter and the outlet operates and older unit and other appliances. Is there anything...
If it were mine, I'd take it back where you bought it and complain. They SHOULD give you a replacement that works, and they should PROBABLY demonstrate that the replacement DOES work, right there in the store.
Jul 26, 2014 | Dehumidifiers
DeLonghi Dem 10 dehumidifier stopped working - the 'operational light' turns on but the fan does not start up.
You may need a new fan motor. If you can get to this
motor, with the power disconnected, see if the blade
is free to move. Do you hear any sound coming from
this unit?
Nov 08, 2013 | LG DH30 GoldStar Dehumidifier
AHH40LHG1: compressor operates, but no fan operation; no power to fan or signal to start
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Mar 30, 2011 | GE AHG40LJ Dehumidifier
Humidifier is icing up during operation
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
vbn
May 20, 2010 | LG LHD45EL Dehumidifier
Coil Icing at times need operators manual
When mine iced over, i took it apart and sprayed all the inside with a hose. Then I put a fan on it for a few day.( make sure the electrical is dry). Got all the dust and dirt out. Re- assembled and works great now
Oct 28, 2009 | Dehumidifiers
DeLonghi DH250R dehumidifyer - operating instructions?
http://www.delonghi.com.au/support/instruction_manuals/DH250R.pdf
Apr 05, 2009 | DeLonghi Dehumidifiers
It works when it wants to
Just found this forum noticed your post, it is old I know, hopefully you got your unit working already.
Sgt 48
The unit is designed to be operated at temperatures above 65°F(18°C) in normal conditions. If the dehumidifier
is operated in low temperature conditions frost can form in the evaporator coil and the unit will cycle ON/OFF
repeatedly. In this case, please check your room temperature conditions and stop the unit.
Oct 05, 2007 | LG DH30 GoldStar Dehumidifier
LG LHD45EL Dehumidifier Logo
59 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
