Question about VeriFone Vx 570 Payment Terminal
Paper sensor inop vx570
The paper sensor is bad and will not feed the paper, can the sensor be replaced and how much should it cost?
I have a Verifone vx570 and it will not print it makes a click then the green light flashes. can this be fixed
if the terminal is not printing at all and you can hear the printing mechanism moving there might be a way to get it to print. it will require you to check to see if you are using correct paper. thermal paper is required and it has to be credit card machine paper not calculator paper etc. scratch the paper and if a faint black line appears you have thermal paper. check the door to the terminal. is there anything in the little hole where you can see the cog/sprocket mechanisms? is the roller on the door in tact? there should be only one sprocket on the roller. then there should be a little nut on the end of each of the ends of the roller.
you can take canned air and clean the roller and in the hole to make sure nothing is in it causing it not to move the paper. make sure when you load the paper you are not trying to feed the paper through the roller in any way. simply place the paper with the tail side down in the terminal and pull the tail of paper allowing you to close the door on the paper. the paper should be feeding from the bottom of the roll and not pulling from the top.
if these do not work for you call your merchant services provider for assistance incase you have transactions in your terminal you don't want to risk losing those.
Feb 13, 2015 | VeriFone VX570 Credit Card Terminal (Dual...
Tamper in verifone vx570's
Bad RTC and Tamper can be repaired. the machine is equipped with multiple sensors inside. if one of them goes bad, or the Battery is dead tampering or bad RTC will show this can be fix by replacing the sensor and or the battery if you need this to be done call me @ (775) 358-2922 hope this help : - )
Oct 26, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
MY Vx570 only prints on the left side of paper.
I think your Paper Feed Roller is bad. . If still needs help, casll (775)358-2922 ask for Randy. Thank You
Apr 17, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
VX570 Credit Card Terminal (Dual Comm DCSC)... problem
You need tamper removal software for your Vx pos.
psoftware109@gmail.com
Feb 29, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
How can I reset my Verifone vx570 that shows 'Tamper' message.
bad RTC can be repaired. the machine is equipped with multiple sensors inside. if one of them goes bad, tamperring or bad rtc will come up. call Us (775)358-2922 we can help you. thanks
Jul 16, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
WON'T FEED PAPER FROM TRAY
I have found in the past that these printers can have two things that cause them not to feed paper.
1. There is possibly small pieces of paper stuck in the paper feed mechanism. I would check inside the paper try and the rollers to make sure there is no paper stuck in there.
2. A lot of printers have problems with the rollers that feed paper going bad. Many times you can contact HP and they can replace them. Depending on the age of the printer it may cost something.
Mar 01, 2011 | HP Photosmart 3310 Printer
Paper didn't feed or feeder can't feed paper
Replace Feeder sensor its a plastic piect the is a sensor that detects there is apaper in the feeder paper path, when these go bad the thing does not feed, or says your out of paper.
T will probably cost you more to have it repaired then getting a new canon or whatever all in one youe decide to buy.
thanks i hope this information finds your helpful ratings and feedback, have a good day.
May 03, 2010 | Canon PIXMA MP130 All-In-One InkJet...
I have a Samsung CLP-600N. When I try to print I get a Paper Jam Tray 1. There is no paper jam. The paper is not feeding. I tried to hold up the Sensor arm and tried to print again. The feed does not...
hmcoul,
In my experience, very rearly is the sensor bad, the sensor is a simple optical sensor activated by a flag. All this sensor does is indicate if there is paper in the tray or not. The most likely problem is that your paper feed roller,(the rubber roller at the back of the printer in the paper tray area) is embedded with paper dust as is very comon on these units. try getting some water or even better still some eucalyptus oil and clean the roller. try to print again and see waht happens.
Gremlin11
Dec 11, 2008 | Samsung CLP-600N Laser Printer
Fellowes paper shredder
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Jan 08, 2008 | Winsource Tech Solutions TS-4500 Cross-Cut...
Help my paper shredder is not working.
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc board, contact manufacturer for more info.
Jan 02, 2008 | Shredder SH2006PB
VeriFone Vx 570 Payment Terminal Logo
57 people viewed this question
Top VeriFone Computers & Internet Experts
ray gallant
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
