Question about Panasonic HC-V100M Digital Camcorder - 2.7" LCD - MOS - Full HD - Bla
Flashing up lens error
Changing from play to record then flashes lens error
Aei music prodisc/ds play and remix lights flash but no sound
DMX Music prodisc systems. I own one. I have had multiple errors, what sequence do the diodes flash in, is it green-orange-green-orange, or do they both flash at the same time? One at a time means a stuck cd drawer, and two together is "Generic Error 000x80x87. Try a DMX lens cleaner through the system. If you do not have one of those spare, look at the back of the player, you will see DIP Switches, flip the 1st one up and you may play normal cds, try a generic lens cleaner though it, if it doesnt work, try contacting Mood Media (The new name for DMX Music)
Oct 30, 2011 | Nintendo DS Lite Console
My MD-MS702 gave me very good service. Unfortunately it was not used for five to six years and now when i switch it on after full battery charging I get TOC error on all of my recorded discs. SOS, as I am...
According to you You don't have use your disk play for a huge time, so that it may damaged or lens became dirty.
You can clear the lens with lens cleaner (clear the optical head).
check the battery was properly charged or working.
Check the disk moved properly.
To prevent the disk erase or damage slide the accidental erase prevention tab.
You can show it to the Technician.
Jan 06, 2011 | Audio Players & Recorders
E6100 flashing on lcd screen
The E61 is an internal error code shown when the motor is not moving. I will look up the specific details when I get to the shop and update this with the required fix.
Dan
Oct 15, 2009 | Sony DCR-HC18E Mini DV Digital Camcorder
My DXZ585USB unit will not play my recorded Flash Drive. It gives me an error 2?? The Flash Drive plays in my computer but not in my receiver. Have I recorded my flash drive correctly? It is a SanDisk 4GB...
I had the same problem, same unit. I was using a keychain drive that I had formatted with NTFS file system. I tried reformatting the drive with FAT32 file system, and it worked, no more error.
Mar 08, 2009 | Clarion DXZ585USB Car CD/ MP3 Player
My Sony DCR DVD 108 has no image at all with or with out disc says lens cap may be closed but it isnt flashing E:61:11 top right hand side of touch screen plays previously recorded dvd fine but thats it.
You may have lost your image sensor.
  1. Take lens cap off.
  2. Look in lens make sure there is nothing on or blocking lens.
  3. Find bright room & see if image comes up.
  4. Make sure your in video record mode.
  5. If you have eyepiece lens look to make sure it is off. {Most cams will not let you use both at same time.}
  6. Still no image try recording on blank disk then play back see if image is recording.
If that does not work MSG back.
Mar 07, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Cant record - error on display E:40:00
it is a typically seems like LENS problem lens got weak and unable to record have u changed recording media tried several dvd -rw or dvd-r what are the results , can u see the lens with ur eyes if yes u can clean it with very soft cloth used to clean lcd's see if it works , other wise buy a mini dvd cleaner with brush on it may be it helps in this situtation other wise the whole lens will be replaced but this is too much for that 170 , pls try the solutions and let me know ,, do try the lens cleaning thing it works in some cases
Feb 25, 2009 | Sony Handycam DCR-DVD205 DVD Camcorder
Disc indicator flashes
lens problem
clean the lens using a lens cleaning disc
Oct 21, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
JVC Digital Video Camera GR-DVL107E
Assuming you don't see any video through the viewfinder, it could be that the CCD has died on that camcorder. It happens, though not frequently.
If the video though the viewfinder is clear, there might be some sensor on the lens ring to indicate a lens cap, or an automatic lens cap not properly disengaging when put in record mode.
Jan 20, 2008 | Video Cameras
Panasonic HC-V100M Digital Camcorder - 2.7" LCD - MOS - Full HD - Bla Logo
41 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
