Question about Splendide Washer Dryer Combo - Ventless
WD802CO anyone know the part number for the drying element?
Dishes not drying, greasy items not clean
You are alomost there. Yes these are some common issues and get resolved only by replacing the heating element.
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 28, 2010 | LG LDF6810ST Stainless Steel Built-in...
CLOTHES DRYER HEATING ELEMENT
The heating element is SUPPOSED to cycle on and off. That is normal. There is an Internal Bias Thermostat and a Hi-Limit Thermostat that help regulate the internal operating temperature of the dryer. However, if you are experiencing longer dry times, or poor drying efficiency, the following link can give you some things to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will actually take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter than usual in many cases and the heating element will appear to glow brighter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat beginning to fail.
Mar 15, 2010 | Kenmore 64742 Electric Dryer
Runs and heats but will not dry
Fist need to know if it is gas or electric dryer, it makes a difference.
If an electric dryer, It is possible that one of the heating elements has failed (burned out), which would still allow the other one to get hot, but not enough to completely dry the clothes during the normal timed or automatic drying cycles.
You can check this with an ohm/amp meter if you are comfortable with working around 220V-AC voltage, etc. You'll need to remove either the rear cover, (if your unit has rear access) or the top of the dryer and then the drum, to gain access to the electric drying elements. This depends on which model you have and how old a dryer it is, etc.
Once you've done that, you can sometimes see a broken drying element, if not, you can check for continuity with the ohm meter (make sure the power cord is unplugged!).
If you are unable to determine with this method, you can restore power and briefly put the dryer into a timed dry cycle (drum and drive belt removed, while you visually check for heating elements turning red/orange as they heat up. Only do that long enough to confirm which element is good, be very careful, as they get extremenly hot. Once you know which one is bad you can order your replacement by model number , etc. Hope that helps.
Jul 13, 2009 | Maytag Dryers
DU1055XPTQ0 DISHWASHER STUCK ON "CLEAN" BLINKS 7 TIMES, REPLACED HEATING ELEMENT ANYONE KNOW CODE TO RESET?
I believe its pressing heated dry, normal, heated dry, normal keys withing 6 seconds. There should be a tech sheet attached to the toe panel at the bottom front of the machine.
Feb 17, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
6233 keypad (numbers only) not working
my 6233 was dropped in a puddle, was dried out but now the numbers, *, and # keys dont work. does anyone know where i can get a new keypad internal part?
Jan 18, 2009 | Nokia 6233 Cellular Phone
Tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Kenmore dishwasher limited edition model 665
Anyone know anything about heating elements, mine won't dry the dishes, thanks
Mar 30, 2008 | Kenmore 24 in. 15173 Stainless Steel...
My 7 year old Malber WD 1000 won't dry - Where to order heating element?
pete5runner back again: The check you should make is to disconnect the two wires to the heating element carefully (with unit unplugged). Then connect a 110 voltmeter to the two wires. The plug in the machine and start a dry cycle. If you see 110 volts on the voltmeter, then you know that power is getting to the heating element, and you have isolated the heating element as defective. If you need a heating element, I got one in NY by calling 718-767-7396. New element was $29, shipping included. I don't know if he will ship to where you are located. Good luck, and let me know what happens.
Mar 10, 2008 | Malber WD1000 Front Load Washer/Dryer
Splendide Washer Dryer Combo - Ventless Logo
32 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
isaac johny
isaac johny
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
