Question about Sherwood RD-7503 5.1 Channels Receiver
Sherwood RD-7503 5.1 Channels Receiver blocked audio and video output
Sherwood RD-7503 5.1 Channels Receiver worked without problems 2 godol messy pressing buttons on the front panel blocked audio and video output with recoverability receiver shows what all poradmesi try learning receiver via the microphone on the display shows COD DOWNLOAD As to unlock the receiver? What code you need Western thank you for your help.
  • valera yarohno
    valera yarohno Mar 21, 2014
    A receiver left off to give out a sound and video through all digital and analog outputs. There is video output (AV) on a screen for viewing and management a menu. A method obnulit' tuning(to enter the code of deblocking) or reprogram a receiver is needed. During connecting of microphone and test of samonastroyki of receiver(through a microphone) on a board shines inscription " code download "
SOURCE: Need the remote control code/s
I google'd remote codes for this device. code 1007 seems to work as far as volume controls and the off/on switch goes.
Posted on Nov 18, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: How do I connect my TV to my audio/video receiver?
The TV has a coaxial digital (SPDIF) output, and the receiver has two coaxial digital inputs available. Simply connect the TV's output to the receiver with the appropriate cable (shielded cable with RCA plugs) and select the input on the receiver. The TV manual says you only get digital output when watching a digital channel. The manuals for both your TV and receiver can be downloaded from the manufacturers' websites if you need copies.
Please take a moment to give this solution a fixya rating if it's been what you needed, and thanks for asking here!
Posted on Mar 12, 2009
SOURCE: Sherwood RD-7502 Hdmi Audio Problem
if you have a tv with outputs you can connect audio wires from your tv output to your audio receiver input and you will have surround sound for everything connected to your tv
Posted on Aug 28, 2009
Testimonial: "That's a good idea. I hope that my TV will output the hdmi audio through the optical output on it. Thanks"
dunnbiker
  • 8546 Answers
SOURCE: Sherwood RV-4050R compatible with new gear?
The TV is irrelevant.
BD would need HDMI, digital audio or 5.1 analog inputs on the contol receiver. You have none of these.
Posted on Jun 21, 2010
SOURCE: Universal Remote Codes for Sherwood Receiver
AUDIO CODES
272 282 487 587 706 806 858 859
Posted on Feb 23, 2011
Factory reset Sherwood RD-7503
not sure if this link will help you out but have a look its all i could find at the moment .
how to Factory reset Sherwood RD 7503 Google Search
Oct 31, 2017 | Sherwood Audio Players & Recorders
I cannot seem to get the tv audio going through the amp, i have connected the red and white audio leads from the tv to monitor out, I've also tried connecting it through cd but to no avail. the audio...
You can't get ANY audio to work on receiver's Monitor Out (which is a component video OUTPUT intended for your TV, not an audio input from it).
Read the manual and get a handle on what those 3 jacks are for (page 6).
http://www.retrevo.com/support/Sherwood-RD-7502-Receivers-manual/id/2536ag207/t/2/
Then, if you really need audio from the TV (instead of or in addtion to the probable Cable/SAT Box that originates TV-related programming), just run the audio out from the TV to any available Line Level audio input. The Cable/SAT box is the BEST place for the BEST TV-related audio and it will be available digitally.
The TV's audio control plays a part in this, too. Find its menu and select a FIXED (or equivalent) setting so you can turn the cruddy TV speakers down without killing the audio output.
Sep 07, 2011 | Sherwood RD-7502
I have a RD-6108 5.1 Channels receiver that want to connect to my flat tv. Can you help me?
If you consider that a TV is just a lightshow, it's not that complicated...
Composite Video Out to composite video IN on the TV would be the minimalist absolute necessary connection for managing the receiver through On Screen Displays.
Unless you intend to dub video to a VCR or something, there is no reason to bring TV video into the receiver.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sherwood-RD-6108-Receivers-manual/id/516ci958/t/2/
My preference is to send the BEST version of any medium (audio or video) directly from it's original source to the BEST ELECTRONICS that uses it; then send minimalist versions across for convenience and lo-fi watching/listening.
Any self-respecting modern TV has multiple hi-def video inputs, so run the Bluray, DVD, cable box video straight in and run the audio from those devices to the Sherwood.
Fewer expensive cables, no excessive connections to go bad, no unnecessary handling of the material.
I'm pleased to see the manual for this one (and the product's limited video capabilities) don't tempt the user to route everything through it on the way to the TV.
Feb 23, 2011 | Sherwood RD-6108 Receiver
How do I reset the defaults on my Sherwood RD-8108 AV receiver?
I just got a tip from Sherwood tech support on resetting my Sherwood receiver, and it solved my problem perfectly. It's not the same model number but here's what I did: Put the receiver on Standby. Press and hold the Setup button for 3 seconds. When you see the model # on the display, press Enter. The word "Cleared" should show on the display. Hope it works for you also.
Feb 03, 2011 | Sherwood RD-8108 6.1 Channels Receiver
I have a Sherwood Audio/Video Receiver Model RD-6105 that keeps cutting off after 30 sec in use i had it for about 2 years can you tell me what's wrong or how to fix this ?
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 22, 2011 | Sherwood RD-6105 Receiver
I'm looking for a copy of a manual for a sherwood rd-7100 receiver
Good day. The only manual I could find was the RD 7103. but it should be from the same series. Please go to http://www.sherwoodamerica.com/site/service/old_manual/RD-7103.pdf
Hope this helps
Jun 11, 2010 | Sherwood RD-7100 5.1 Channels Receiver
Aug 28, 2009 | Sherwood RD-7502
Mar 12, 2009 | Sherwood Audio Players & Recorders
CANT GET SUB WOOFER TO WORK WITH MY RECIEVER!!!!!
See step 9 for turning the subwoofer output ON
HERE
Part of the original link i gave you to your online manual.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Sherwood RD-6108 Receiver
Sherwood RD-7503 5.1 Channels Receiver Logo
32 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
