Question about Frigidaire Electric Dryer
No power lights on front of machine not working machine will not start nothing happens machine beeps when unplugged
  • Official Brand Answer
  • 4,342 Answers
Hi Lawrence, this is AP! Thank you for your post.
I understand you are having trouble with your Frigidaire electric dryer. Without knowing the specific model number there are still some troubleshooting tips I can recommend. Make sure the dryer is plugged into the outlet, and plugged in correctly. Check to see if the house fuse is blown or circuit breaker tripped. If so, replace fuse or re-set circuit breaker. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the dryer may turn but will not heat. Check and replace fuse in fuse box if necessary. If the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer. Circuit requirements are individual 30 amp. branch circuit fused with 30 amp. time delay fuses or circuit breakers. Your dryer requires a power supply of 240 volts to operate. Make sure that the electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. If needed have a Licensed Electrician check to make sure it is on a circuit by itself.
Lastly, the thermal limiter could have tripped or there is an internal problem with the dryer. A thermal limiter automatically turns off the motor (electric dryers only) in the unlikely event of an overheated situation. If this is the case I would recommend contacting an authorized service for repair as this is not a typical DIY project. Contacting an authorized technician can ensure no troubleshooting step has been missed. Parts are often costly and if the problem is precisely diagnosed, it can save you a lot of time and funds.
You can use the link below if you need assistance in locating an authorized technician in your area. I hope this information proves helpful for you.
http://www.frigidaire.com/Owner-Center/Locate-Service--Parts/
Posted on Mar 20, 2014
Why are frigdaire front loader all leg ligts on right side blinks and beeps all the time
Thanks for your inquiry, Barbara Williams!
I understand that the lights on your Frigidaire washer are blinking and beeping. It sounds like your washer is providing a set of error codes. Your control panel may need to be replaced. I would recommend contacting a professional technician for proper diagnosis to be completed to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Nov 29, 2014 | Frigidaire FRFW3700LW Laundry : Front Load...
Error Message "LOC" Three beeps, won't door lock or start
You may have to remove the lower front panel to get to the tech manual. If the door latch isn't latching though nothing is going to happen.
Jun 15, 2009 | Frigidaire GLTR1670A Front Load Washer
Washer won't start
Have had that before and had to replace board
Jun 10, 2009 | Whirlpool GHW9200L Front Load Washer
I have a mah5500b. prob is washer will not start or do anything. it just beeps. tried the diagnostic test. by pressing delicates and heavy soil. led shows 00. when i push other buttons to check functions....
I had a similar problem on my Neptune. All the machine would do is beep. I believed it was a stuck button so I got a new touch pad and that solved the problem. I also substituted a control board prior to buying the touch pad but the problem was the same.
May 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
WCVH6260HWW GE front load washer won't start - press the On button, then press Start/Pasue button and it goes beep beep, and keeps blinking, and washer does not start; the washer pump strainer has been...
no power to control panel checked outlet with another appliance it worked drained water from pump filter still nothing door locked and nothing on control panel
Feb 23, 2009 | GE WSXH208A Front Load Washer
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Frigidaire  Electric Dryer Logo
75 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
