Question about Koldfront Portable Counter Top Ice Maker White
Says ice full
Tried to turn on and it says ice full but its not what can I do
I have a GE refrigerator, model TPX24BPDA, that has an ice maker that won't stop making ice! Whatever mechanism that senses when the hopper is full isn't working. I can't locate any sensor either.
Ice Maker Doesn't Turn Off If your ice maker keeps making ice, even when it is full:
1Lift the bail wireto shut off the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Oct 05, 2016 | GE Refrigerators
Whirlpool side by side s20erww2v american f/freezer
Is the ice bucket still full? Ice makers have built in mechanism to cut itself off when ice bucket is full.
Sep 12, 2017 | Whirlpool Freezers
Freezer not making ice in Fridgidaire model PLH269ZDB2
There is a lever in the ice bin that detects when it is full. if that lever is locked in the"up" position, the maker stops making ice. Many times a previous owner or a shipper will turn off the icemaker this way. especially if the water to the home or freezer is turned off, so it won't keep trying to make ice.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
My newair A1200ss stopped making ice. i tried recycling the unit and it has ample water, but the ice tray just stays in the down position. thanks.
I have had the same problem with two different portable ice makers, the ice tray inside is broken so you will have to send it to them and get it fixed. Hopefully eventually they will make the tray out of a stronger plastic.
Nov 29, 2008 | NewAir AI-200SS Ice Cream Maker
LFX25960ST Ice maker problem
As long as switch on icemaker is on then your i/m died. It needs to be replaced. I can get LG parts if you need one. Please leave feedback. Thanks
Nov 22, 2008 | LG LFX25960ST Stainless Steel French Door...
Ice maker makes ice and won't stop when full
this icemaker has an electronic control. it could be simple micro switch or the board.
Jul 22, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working properly
could be the air damper. try adjusting air control for more air at icemaker.
May 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
In my freezer, there's an infrared beam positioned over the top of the ice bin. If the bin is full of ice, it blocks the beam and no ice can be made. In addition, when you open the freezer door, a small (2x3") door opens in the freezer to block the beam, again to prevent ice from being made while the door is open. Is anything blocking the path of this beam from one side of the freezer to the other?
Mar 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker won't stop making ice
OK, there's two possible issues but you have to figure out what is happening. Does the ice maker continue to make ice forever and would fill up the whole freezer section in time OR does the ice maker just "over make" ice that overfills the bin which then falls out? If the ice maker just keeps making ice you need the motor module replaced but if it can be turned off by moving the lever up then you need the "modified lever assy." that is on our service bulletins.
Dec 23, 2006 | Kenmore 55693 Side by Side Refrigerator
Koldfront Portable Counter Top Ice Maker White Logo
67 people viewed this question
Top Koldfront Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Koldfront Kitchen Appliances - Other Expert? Answer questions, earn points and help others
